Lycoming
mbetti
Lycoming
Hi all,
I'm still looking at whether to buy a new clone engine or a mid-time. A friend of mine sells used parts for a salvage yard and come across a 1998 Lycoming 0360A1A wide deck 180HP. It came out of a Glastar, has all acc on it, dynofocal, 120 hr since new. The engine has had a prop strike and it is bent. The engine is guaranteed to only have only a bad crank and other components ok. I would do my own engine repairs with some assistance from an IA friend. I have been in the engine rebuilding business all my life, not aircraft though but an engine is an engine when it comes down to it.
Looking for any advice from the group. I don't know what wide deck means, is that ok for the Elite?
Mike Betti
771E
Mike Betti
771E
Lycoming
I'm by no means a Lycoming expert Mike, my aviation maintenance history is
on jets, and I'm only an 80 hour pilot... but most if that time is in a
Cherokee 180, and there's a tickling in the back of my mind that says the
A1A model has a hollow crank for constant speed props... and to go along
with that whether using the CS prop or not, there are some operating
limitations involved with this engine in certain RPM ranges due to
viabrations that are not there on the non-hollow crank engines.
What sticks in my mind about this was that the range to avoid was right
where I usually found myself cruising in the Cherokee, which thankfully did
not have this model engine, therefore did not have the limitation. I just
remember thinking it sure would suck not to be able to fly at what appeared
to be a real sweet spot for both the engine and airplane.
I don't know if you can use a different crank when you rebuild or not... but
I'm sure somebody here does.
Sent: Friday, January 13, 2006 8:19 AM
Subject: Lycoming
Subject: Lycoming
Hi all,
Mike Betti
771E
mbetti
Lycoming
MAM has used this model for their Elite as did Al H. There was a fixed pitch prop on this one also. I've heard about the balance problem and that maybe you can have it balanced during rebuild. I know some of the clone builders are doing that, but I don't know what's involved. I just found out all later model Lycomings are wide deck.
Mike Betti
Mike Betti
Subject: Lycoming
Hi all,
Mike Betti
771E
lawsondj
Lycoming
Mike,
The RPM limitation only applies for certain props (Hartzell). I use a McCaully borer prop on the Super Cub without limitation--same engine.
Jack Joos
Jack Joos
Mike Betti
On Fri, 13 Jan 2006 08:35:47 -0900, rebel-builders@dcsol.com said:I'm by no means a Lycoming expert Mike, my aviation maintenance history is
To:
Subject: Lycoming
Hi all,
Mike Betti
771E
lawsondj
Lycoming
Hi Mike,
Presumedly the "bad"crank is from the prop strike? Lycomming is recalling certain IO360 and O360 engines for faulty cranks but the A1A series is not on the list.The A1A has the hollow crank for constant speed prop usage, if you ever want to implement that feature. Don't forget a new crank constitutes a major part of the engine's value.
As far as I recall "narrow deck" or "wide deck" refers to the amount of flange area existing where the cylinders attach to the block. Narrow deck engines aren't made new or remanufactured anymore, only wide deck, so narrow deck engines have no core value for the factory anymore.
Anyway, I have the same O360-A1A hung on the front of a Super Cub. Works great.
Good luck,
Jack Joos,SR193
Original message ----------------
Good luck,
Jack Joos,SR193
Hi all,
Mike Betti
771E
Rebflyer
Lycoming
Mike,
The wide deck is fine. As for an engine is an engine, how many automotive
engines have silk thread between the case halfs? Did you know if you don't
install it, it will pinch the bearings?Are you aware of the various crankshaft
AD"s? If your going to do your own, at least make a seminar or get an
experienced aircraft engine mechanic to guide you through the lower end. The
cylinders are a breeze. IMHO
Curt N97MR
Curt N97MR
Mike Betti
Lycoming
I just talked to a rebuilder I know and he has a tagged crank to install and
will reassemble the bottom end for a reasonable amount. For about $14K I
could have a good engine 140 hr snew. I just need to work out the conditions
before purchase to prevent being stung by something.
Sent: Friday, January 13, 2006 2:41 PM
Subject: Re: Lycoming
Mike,
automotive
don't
crankshaft
The
Curt N97MR
Rebflyer
Lycoming
Mike,
That sounds great! The things that are required for the sudden stoppage AD
are available on the lycoming web site. It also includes inspection of the
crank gear, but if you have someone who is familiar with lycomings that should
be a normal part of it!
Good luck, Curt N97MR
Mike Betti
Lycoming
Does anyone use a fuel pump on the engine in your Murphys? I have one that came with my engine but not planning on putting it on.
Mike Betti
771E
Mike Betti
771E
pequeajim
Lycoming
I have the fuel pump setup on mine as a back up. I was in the same
situation as you and decided to leave it on as insurance.
If mine had not come with the fuel pump, I don't know that I would have
gone out and bought one, but since yours came with it...?
Jim!
On 2/26/2006 4:00 PM, mbetti@up.net wrote to rebel-builders:
-> Does anyone use a fuel pump on the engine in your Murphys? I have one
-> Thanks,
-> Mike Betti
-> 771E
Jim!
-> Thanks,
-> Mike Betti
-> 771E
