Gas struts
Dale Kilbey
Gas struts
Hi All
I have decided to change my dors to gull wing . I know nothing about gas
struts . Does anyone know how strong a strut is required?
Dale 220 R
Dale 220 R
Jones, Michael
Gas struts
hi dale
you need a surprising amount of force to lift the doors so they need to be
made light
I used 2 gas struts on each door, each strut has 15 lbs, if you use one
strut you need at least a 30 lbs strut
also the strut location when mounted is critical for proper function
also the strut should be mounted with body side up, it makes difference
according to manufacturer
suppliers are not that easy to find, also finding the force of the strut can
be problem usnless it is marked on the strut or you take it home and measure
it
mike#007
Dale Kilbey
Sent: Tuesday, November 08, 2005 11:24 AM
Subject: Gas struts
Hi All
Dale 220 R
made light
it
mike#007
Dale Kilbey
Subject: Gas struts
Hi All
Dale 220 R
Scott Aldrich
Gas struts
On my Moose the doors use a 90 PSI strut. The door is probably a lot heavier
than a standard Moose or a Rebel door though. We upped the skin thickness
and have an interior on the door.
We bought all our door hardware from http://www.austinhardware.com/
I know of a Moose that has well over $3000 in just door and window hardware
(all certified stuff for Beavers). We have essentially the same set up for
well under $100.
FWIW
Scott
Moose 174
Kilbey
Sent: Tuesday, November 08, 2005 9:24 AM
Subject: Gas struts
Hi All
Dale 220 R
well under $100.
FWIW
Scott
Moose 174
Kilbey
Subject: Gas struts
Hi All
Dale 220 R
Scott Aldrich
Gas struts
Dale, you've probably been looking at others but it is a good idea to mount
the gas spring (or springs) so that they go over center as the door closes
then the piston holds the door closed. We only used one on the forward side
on the Moose because passengers would want to use the aft one as a grab
handle) http://www.goflyamoose.com/doors.htm
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Scott
Aldrich
Sent: Tuesday, November 08, 2005 9:56 AM
Subject: RE: Gas struts
well under $100.
FWIW
Scott
Moose 174
Kilbey
Subject: Gas struts
Hi All
Dale 220 R
Scott
Aldrich
well under $100.
FWIW
Scott
Moose 174
Kilbey
Subject: Gas struts
Hi All
Dale 220 R
mbetti
Gas struts
I found Napa to have gas struts in there big catalog. There is a whole page on them with lengths, pounds, etc. I am starting out with a single 20 pound for my gull wing windows, I had to start somewhere. The door will still be conventional hinged.
Mike Betti
771E
Mike Betti
771E
Hi All
Dale 220 R
Jones, Michael
Gas struts
mike
when i did my gull wing doors i had engineer at company i used do
calculations with special program they use to show the opening and closing
positions, mounting points, forces in hot & cold weather and for rebel door
they calculated for single strut 30 lbs was needed, you can try 20 but i bet
you will need 30 lbs
also the mounting points are critical, dont recall now but could look them
up for you, of course if you have different length strut then me your
mounting points will be different
mike#007
mbetti@up.net
Sent: Tuesday, November 08, 2005 3:54 PM
Subject: Re: Gas struts
Mike Betti
771E
mike#007
mbetti@up.net
Mike Betti
771E
Hi All
Dale 220 R
mbetti
Gas struts
It's just the window hooked to the strut and it doesn't have to open the window, just hold it open. I'll have the test strut in a couple days and see what happens, got to start somewhere.
Mike Betti
Mike Betti
mike
mike#007
mbetti@up.net
Mike Betti
771E
On Tue, 8 Nov 2005 11:23:51 -0500, rebel-builders@dcsol.com said:Hi All
Dale 220 R
Dale Kilbey
Gas struts
Hi Mike
I would appreciate that. at least I wiil know if I'm on the right track
Dale 220R
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Wednesday, November 09, 2005 7:19 AM
Dale 220R
mike
door
bet
mike#007
mbetti@up.net
page
pound
Mike Betti
771E
Dale 220 R
Jones, Michael
Gas struts
also look on builders web site, might be pdf posted with dimensions
Dale Kilbey
Sent: Wednesday, November 09, 2005 10:28 AM
Hi Mike
Dale 220R
Dale Kilbey
Hi Mike
Dale 220R
mike
door
bet
mike#007
mbetti@up.net
page
pound
Mike Betti
771E
Dale 220 R
Dale Kilbey
Gas struts
Thanks Scott and Mike. Also I found another source
http://www.lstechnologies.ca
I should be able to workk it out now.
Dale 220R
Dale 220R
