Moose window cutouts
Mike Rapoport
I am at the point where I will soon be cutting out the door windows and I was wondering how others did this. I am considering using a router. Did anyone else us a router? Any problems with this?
Jones, Michael
mike
i used jig saw, trouble with the lexan is it melts as friction builds up,
sure others have used other methods too
mike#007
Mike Rapoport
Sent: Wednesday, November 02, 2005 10:22 AM
Subject: Moose window cutouts
mike#007
Mike Rapoport
Haven't used a router on my Moose yet... but I have cut holes in aluminum
many times using a Formica bit on my router... works great, leaves nice
clean edges.
Sent: Wednesday, November 02, 2005 6:21 AM
clean edges.
Scott Aldrich
Mike are you talking about cutting the lexan or just the aluminum opening on
the door window? I used a dremel tool on the lexan window, and just old
fashioned snips on the aluminum, after drilling a few holes to get the snips
in.
My door windows were actually about an inch smaller(in height) than they
were supposed to be, I should have sent them back but instead just made the
frame smaller. Figured it out before starting the door or it would have
been a pain.
FWIW
Scott
Rapoport
Sent: Wednesday, November 02, 2005 8:22 AM
in.
been a pain.
FWIW
Scott
Rapoport
Mike Rapoport
I was only thinking about cutting the aluminium I assume the you opted for
the buble windows? What do you think of them?
Sent: Wednesday, November 02, 2005 8:26 AM
Subject: RE: Moose window cutouts
on
snips
in.
been a pain.
FWIW
Scott
Rapoport
Scott Aldrich
I have the bubble windows on the doors only. I like them. However these
are what I was talking about that came too small. I haven't heard of anyone
else having this problem though.
I did not get the rear bubble windows. The flat are fine but the bubbles
look really nice back there too.
If I remember correctly the aluminum window frame becomes a real flimsy
noodle when you cut it out. You'd have to have some way to hold it down
real good if trying a router.
Scott
Rapoport
Sent: Wednesday, November 02, 2005 11:26 AM
Subject: Re: Moose window cutouts
Scott
Rapoport
As with all inside cutouts that are required for the Super Rebel, I just
used thin cut-off wheels in my Dremel.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Scott
Aldrich
Sent: Wednesday, November 02, 2005 9:46 AM
Scott
Rapoport
Aldrich
Scott
Rapoport
Gilles St-Pierre
Just use a good pair of (metal) scissors, thats what we use allthe time
gilles
e717
gilles
e717
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
To: "'rebel-builders@dcsol.com'" <rebel-builders@dcsol.com>
Date: Wed, 2 Nov 2005 10:25:34 -0500
mike
mike#007
Mike Rapoport
