PreKote
Scott Aldrich
PreKote
Post by Scott Aldrich » Sat Feb 18, 2012 5:06 pm
Britt recommended the PreKote to me. It worked well. Cost is about a wash
with the etch and alodine but it is less steps and you can hose it down the
driveway. I used just under two gallons on the entire airplane.
Mike, no, I used the PPG DP primers.
Okay Britt I just updated my painting pictures. Still don't have one with
the cowls all on.
www.goflyamoose.com
or direct http://www.goflyamoose.com/painting.htm
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jones,
Michael
Sent: Wednesday, October 26, 2005 10:46 AM
To: 'rebel-builders@dcsol.com'
Subject: RE: Everbrite
britt
did he use everbrite as a primer ??
mike#007
Reed Britt Civ 309 MXSG/MXRIE
Sent: Wednesday, October 26, 2005 12:23 PM
Scott Aldrich used it and loved it!! His paint also came out sweet - Still
waiting for him to share the pictures -
Britt
Mike Betti
PreKote
Post by Mike Betti » Sat Feb 18, 2012 5:06 pm
What's the consensus for paint prep? For painting the interior is it
necessary to do the metal prep procedure or just a skotchbrite and laquer
wash? I definately will do the prep wash on the exterior.
Mike Betti
771E
Sent: Wednesday, October 26, 2005 11:25 AM
Subject: PreKote
the cowls all on.
www.goflyamoose.com
Scott
Jones,
Michael
britt
mike#007
Britt
PreKote
Post by Wayne G. O'Shea » Sat Feb 18, 2012 5:06 pm
...are you anywhere near salt water Mike or do you have any intentions of
flying on it. Why add this weight to the interior of your airplane if you're
not??
Sent: Monday, October 31, 2005 8:18 PM
Subject: Re: PreKote
Mike Betti
771E
Subject: PreKote
wash
with
the cowls all on.
www.goflyamoose.com
Scott
Jones,
Michael
britt
mike#007
Still
Britt
Mike Betti
PreKote
No salt water, live between lake MI and lake Superior. I guess instead of
installing some sort of fabric interior I decided to paint.
Sent: Monday, October 31, 2005 7:23 PM
you're
not??
Mike Betti
771E
Subject: PreKote
wash
with
the cowls all on.
www.goflyamoose.com
Scott
Jones,
Michael
britt
mike#007
Still
Britt
jean.poirier
PreKote
Post by jean.poirier » Sun Feb 19, 2012 7:22 pm
Hello
I have just strip (with the help of my ame) my C-150 wings (a
rognal
PreKote
Post by rognal » Sun Feb 19, 2012 7:22 pm
Hi Jean,
I used PreKote prior to painting my Rebel. The wings were painted early
summer 2006. The fuselage was painted late summer 2006. It's been flying
since June 2007 with approximately 55 hours tach time so far and the paint
is still attached.
I applied the PreKote per the instructions. I found that after the final
rinse there was a fine aluminum residue remaining on the surface which
didn't rinse off. At least it didn't rinse off with garden hose/city tap
water pressures. To get this residue off I would wash the surface with
PolyFiber 310 Alkaline Detergent Cleaner and rinse again. This would leave
the surface clean and 'bead free'. Washing with the PolyFiber alkaline
detergent is not part of the application instructions for the PreKote, but
I did it anyway to get the residue off.
I'm not convinced the PreKote itself really does anything. Their literature
indicates that the etching of the metal is done by scrubbing the metal
surface with maroon Scotchbrite pads and that the PreKote leaves a coating
that helps the paint coat adhere. Personally, I think the paint adheres to
the surface because it has been etched (roughened) by use of the
Scotchbrite pad.
So far I am happy with the results, but only time will tell. It was
certainly easier (and safer) than acid etching and alodine, IMO.
I used all Poly Fiber paint products throughout. EP420/430 Epoxy Primer
followed by Poly Fiber Aerothane color coats.
Hope this helps,
Roger Hoffman
Eugene, OR USA!
