knew it was a U/L, but just wanted to be sure you did know so you wouldn't
run into problems later.... NOW, I know it ISN'T a U/L anymore !!
The tail will likely be about 70 lb - and I think you should order the
'full-swivel' upgrade kit to convert the old tailwheel, for better ground
handling - given that you'll only be flying the time off, then going to
floats. It's not a lot of money, and will save you some grief later !
Without the full-swivel, you can put some pretty high side loads on the
rear fuselage - which is one reason for Ontario Mod. #1 !
I guess you already know about all of the Ontario Mods, and
the FUS-10 to FUS-70 upgrades, all of which will be good if you use the
big engine on floats .... So carry on building, and enjoy your Rebel !
On Thursday 11 August 2005 09:20 pm, Jesse Jenks wrote:
I didn't mean to imply that I got a bum deal. I am happy with what I got
from Wayne. A small correction though: I started with a standard Rebel tail
kit from Murphy, and bought the rest from Wayne.
I plan to be on amphibs with at least 150 hp. So maybe the old non-swivel
tailwheel will be ok for a while. How heavy is the tail when ground
handling? can you lift it up for pushing backward?
Jesse
