Stringers damage Elete & SR's
Doug Martin
Post by Doug Martin » Fri Feb 17, 2012 8:27 pm
Need a "Caution note" in the manual when it tell you to drill the
stringers under the skin. To use a drill stop or tape around the drill bit
to keep from going too deep and damaging the curl flange on the stringer.
Has anyone put together a listing of this type of hints for the Elete yet?
Doug Martin
greyghost@powernet.net
