control rod end spacers
Jones, Michael
hi all
guess this question is really for Wayne since i think he posted the pics of
the rod end spaces.
i think i see you put small spacers above and below the rod end, is this to
allow the rod end to twist full without bottoming out on the bell crank or
penny wash above, by doing this the rod ends stop twisting on their threads
in the control tube, i assume this is only done at the bell crank end since
the other end of this control rod is inside the main control tube, is this
correct Wayne, if so do you recall the length of the spacers required
thank
mike#007
the rod end spaces.
thank
mike#007
Hi Mike !
You're right - the small spacers (cut-down washers, or tube
pieces) stop the rod-end from hitting the larger penny washers,
which would cause the whole thing to turn on the threads.
The spacers are usually added on the control column end,
where they are visible, although putting them on the other end
as well wouldn't hurt.
hi all
the rod end spaces.
thank
mike#007
Yes
Yes
and Yes ;)
Mine are I believe at most 1/8" long and made from 5/16 OD steel fuel
line tubing.
Yes
and Yes ;)
line tubing.
hi all
the rod end spaces.
thank
mike#007
Alan Hepburn
A much better solution (though it costs a few bucks) is to use the ACS rod
end swivel bearing (Part No 05-01021). You also need an HF-4 bearing to go
with it. Thanks to Ralph Baker for this one.
Al Hepburn
Al Hepburn
Jones, Michael
hi all
so i am picking up some bolts today and am at work already, can someone tell
me the bolt sizes for the bellcrank with these spaces or even the original
size and will get a couple of sizes but i need this info before lunch
thank
mike#007
thank
mike#007
rickhm
I must be brain dead. I cannot find the posted pictures, or I deleted the email with the reference. Can someone point me to these?
RIck Muller
SR70
RIck Muller
SR70
Yes
Yes
and Yes ;)
line tubing.
hi all
the rod end spaces.
thank
mike#007
Jones, Michael
its under rebel and then controls section, top two pics on the list, cant
miss them, their names are totally different than any others in that section
mike#007
rickhm@comcast.net
Sent: Thursday, May 19, 2005 8:32 AM
Subject: Re: control rod end spacers
RIck Muller
SR70
mike#007
rickhm@comcast.net
RIck Muller
SR70
ofYes
Yes
and Yes ;)
line tubing.
hi all
tothe rod end spaces.
orallow the rod end to twist full without bottoming out on the bell crank
threadspenny wash above, by doing this the rod ends stop twisting on their
sincein the control tube, i assume this is only done at the bell crank end
thisthe other end of this control rod is inside the main control tube, is
thank
mike#007
When the tubular spacers ar used to minimize the rod ends turning in the
aluminum tube end fittings it is important to orient the rod ends in the
tube so they are in the same plane at each end. If this is not done
before final adjustment and locking the jam nuts there will not be a
full range of rod end motion (even with the spacers).
Jones, Michael
ralph
how do you make both ends in same plan, one is vertical the other is
horizontal, i don't follow
mike
Sent: Thursday, May 19, 2005 9:54 AM
Subject: control rod end spacers
mike
Poor choice of words on my part and incorrect. What my brain was trying to
say is to set them so the maximum amount of rotational travel is available
at each end so you dont have one rod end bind in one direction and the other
bind in the opposite direction.
Mea Culpa
Ralph
Sent: Thursday, May 19, 2005 9:55 AM
Subject: RE: control rod end spacers
Mea Culpa
Ralph
ralph
mike
Ken's got it for you Mike! See I can go away permanantly!
) I use about
3/16" to a 1/4" x 5/6" stainless brake line. It lets the rod end rotate that
extra bit needed so you can lock nut both ends of the push pull. Don't
bother playing with this until you have set your up and down stops for the
elevator.
Sent: Wednesday, May 18, 2005 2:43 PM
elevator.
ofYes
Yes
and Yes ;)
line tubing.
hi all
thank
mike#007
Only applies to the Rebel and Elite Rick...carry on! Wayne
Sent: Thursday, May 19, 2005 8:31 AM
email with the reference. Can someone point me to these?I must be brain dead. I cannot find the posted pictures, or I deleted the
pics ofRIck Muller
SR70
Yes
Yes
and Yes ;)
line tubing.
hi all
this tothe rod end spaces.
thank
mike#007
