Inspection covers
Mike Betti
Inspection covers
Thanks all for your input on tools and deburring. I was wondering, what
is the best option for those inspection covers. I have 3 to install on
stab and I can't see putting them in with just sheetmetal screws.
Mike Betti
Mike Betti
inspection covers
Mike,
This is a specific case where MAM's cost cutting got the better of good
practice. ALL the inspection covers should be easily removable. This
can be accomplished best with nutplates or Tinnerman nuts. The supplied
covers have 6 holes for rivets. You can either install 6 nutplates or
Tinnermans (less attractive but easier/cheaper) or remake them with 3
holes. Where rivets are required under remade covers they should be
countersunk. Don't forget the pulled Avex are 120 degree heads.
Our Elite rudder did not come with access holes to the rudder hinges. I
suggest that you consider all future maintenance and provide easy access
to all the threaded fastener locations from both sides. Also, get from
Wayne O'Shea the 10-32 nutplates for wing hinges. This is IMPORTANT!
Don't ask how I know. In all cases read the manual ahead and consider
providing easy access by whatever means. If you are building an Elite
taildragger read the rudder installation section before building the
rudder to avoid rework in adding the steering horn on the rudder bottom
(it steers the tailwheel).
regards,
Ralph Baker/Sue Scouten
Elite 611E
regards,
Elite 611E
Ryan Mowat
Inspection covers
An option for covers that so far has worked really very well is to have
MAM punch out rings 3/4 wide - then cut them in one spot - place them
as a doublers behind every inspection hole - I think there is about 26
of them all together. The tiny nuts grab the two pieces of sheet and
with pro seal between the AL pieces it absorbs all the vibrations so
they do not come out. The cost is min as MAM can make them out of
scrap.
Ryan
Mike Betti
Sent: Sunday, January 23, 2005 4:43 PM
Subject: Inspection covers
Mike Betti
scrap.
Ryan
Mike Betti
Mike Betti
Mike Betti
Inspection covers
You know, I think my Cessna is like that on some covers. There is a ring
with 3 tinnermans held in with 3 rivets through the other 3 holes.
Sent: Sunday, January 23, 2005 8:38 PM
Subject: RE: Inspection covers
scrap.
Ryan
Mike Betti
Mike Betti
Mike Betti
inspection covers
You mentioned flush rivets. There was an extra page in the stab instructions
that was hand drawn and showed where the flush rivets should go, different
from the normal page in the manual. They are showing the whole leading edge
done in flush. The original drawing shows flush rivets only where the fin
comes into play. I don't know what the purpose is? Cleaner air? Any input on
that out there?
Mike Betti
Elite 771
Sent: Sunday, January 23, 2005 8:03 PM
Subject: inspection covers
that out there?
Mike Betti
Elite 771
Mike,
regards,
Elite 611E
inspection covers
Mike,
My comment on flush rivets was only to remind that nutplate rivets (or
Rivnuts) under the inspection covers would have to be flush so the covers
would lay flat. Other than that, the only flush rivets I recall (danger
here!) in the horizontal stabilizer are at the outboard ends where the
fiberglass caps slip over.
Regards,
Subject: Re: inspection covers
Regards,
instructionsYou mentioned flush rivets. There was an extra page in the stab
edgethat was hand drawn and showed where the flush rivets should go, different
ondone in flush. The original drawing shows flush rivets only where the fin
that out there?
Mike Betti
Elite 771
Mike,
regards,
Elite 611E
inspection covers
At least on a Moose, there are a number of flush rivets in the center as
well where you're fuselage to stab fairing will eventually go.
195SR
Sent: Tuesday, January 25, 2005 5:51 AM
195SR
Mike,
Regards,
David Ricker
inspection covers
Did your Elite come with a vertical to horizontal stablizer fairing? It sounds
like the flush rivets should be placed under that area. BTW, our Elite didn't
come with the fairing.
elite 583.cjb.net
Mike Betti wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
elite 583.cjb.net
Mike Betti wrote:
--You mentioned flush rivets. There was an extra page in the stab instructions
that out there?
Mike Betti
Elite 771
-----------------------------------------------------------------Mike,
regards,
Elite 611E
David A. Ricker
Canada
Mike Betti
inspection covers
I don't think I seen a fairing in the parts here either. According the
drawing the flush rivets are in the fairing areas and also in all the
leading edge ribs. I need to see what the deal is there.
Are you just using the pop rivet dimpler with the nail? Seems to work good
but the hole comes out a little larger than the size 30 it should be.
Mike Betti
Sent: Tuesday, January 25, 2005 7:18 PM
Mike Betti
soundsMike
didn'tlike the flush rivets should be placed under that area. BTW, our Elite
instructionscome with the fairing.
elite 583.cjb.net
differentthat was hand drawn and showed where the flush rivets should go,
edgefrom the normal page in the manual. They are showing the whole leading
findone in flush. The original drawing shows flush rivets only where the
input oncomes into play. I don't know what the purpose is? Cleaner air? Any
goodthat out there?
Mike Betti
Elite 771
Mike,
suppliedpractice. ALL the inspection covers should be easily removable. This
Icovers have 6 holes for rivets. You can either install 6 nutplates or
accesssuggest that you consider all future maintenance and provide easy
fromto all the threaded fastener locations from both sides. Also, get
bottomWayne O'Shea the 10-32 nutplates for wing hinges. This is IMPORTANT!
-------------------------------------------------------------------(it steers the tailwheel).
regards,
Elite 611E
David A. Ricker
Canada
David Ricker
inspection covers
The leading edge rib thing is curious, can't imagine why.
Yeah, we use the same dimpler & have the same concern about the holes but the
rivet does expand as it pulls so it is probably OK.
Mike Betti wrote:
David A. Ricker
Canada
Mike Betti wrote:
--I don't think I seen a fairing in the parts here either. According the
Mike Betti
soundsMike
Did your Elite come with a vertical to horizontal stablizer fairing? Itdidn'tlike the flush rivets should be placed under that area. BTW, our Eliteinstructionscome with the fairing.
elite 583.cjb.net
Mike Betti wrote:
You mentioned flush rivets. There was an extra page in the stabdifferentthat was hand drawn and showed where the flush rivets should go,edgefrom the normal page in the manual. They are showing the whole leadingfindone in flush. The original drawing shows flush rivets only where theinput oncomes into play. I don't know what the purpose is? Cleaner air? Anygoodthat out there?
Mike Betti
Elite 771
suppliedIaccessfrombottom------------------------------------------------------------------------------------------------------------------------------------
David A. Ricker
Canada
David A. Ricker
Canada
Dick Shotwell
Inspection covers
Just a note to anyone who wants to install more easily removable
inspection covers. We wanted to be able to easily remove the inspection
covers and we wanted them held in place with stainless steel screws
screwed into nut plates. We found that Keith Kinden at Montana Floats
can make these up. He fabricates a donut into which the nut plates are
installed as well as a cover with matching screw holes. The donut is
placed in the structure (wing, stab, fuse, or wherever) with proseal.
Makes a nice clean installation.
Dick and Dave Shotwell
Moose 096
N235DS
Twin Falls, ID
Moose 096
N235DS
Twin Falls, ID
Mike Betti
Inspection covers
Any ideas on the cost of these?
To: "Moose Builders" <rebel-builders@dcsol.com>
Sent: Monday, March 14, 2005 9:15 PM
Moose 096
N235DS
Twin Falls, ID
Dale Fultz
Inspection covers
what size are they being made in (Diameter) would like to find 6 inch ones
to put in lower fuselage to check motor mount nuts and rudder pedals from
underneath. Thanks Dale
Sent: Monday, March 14, 2005 10:22 PM
Subject: Re: Inspection covers
Moose 096
N235DS
Twin Falls, ID
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.7.2 - Release Date: 3/11/05
Scott Aldrich
Inspection covers
Give Keith a call at Montana Floats (406) 293-9026. I think they can make
just about whatever you want. I recall ours were 5 or maybe 6 inch and $12
for the ring and plate but that was a while ago.
Keith lurks on here but it is best to call him for fastest service.
Scott
Fultz
Sent: Monday, March 14, 2005 9:09 PM
Scott
Fultz
Moose 096
N235DS
Twin Falls, ID
Alan Hepburn
Inspection covers
I had some spares from my floats and used them at the tips. They are big
enough to remove a strobe power supply through. I might even have some more
spares left over...
Al
Sent: Monday, March 14, 2005 11:16 PM
spares left over...
Al
$12Give Keith a call at Montana Floats (406) 293-9026. I think they can make
inspectionfor the ring and plate but that was a while ago.
Scott
Fultz
arecovers and we wanted them held in place with stainless steel screws
Moose 096
N235DS
Twin Falls, ID
