weight!! Stuff that gives designers insomnia!! I'm sure Erikson knows what
he's doing... but based on design lowers the allowable g loading by almost
25% ie from 4 to 3.1 operational (6 down to 4.7 for ultimate)...but then
again the air is lighter in Alaska according to the FAA based on the
modified rules for certified stuff in that state. Considering what was done
to take the moose from the 3000lb SR to the 3500lb Moose I'd have to see
some major changes the structure to be comfortable with 4500lb daily useage.
Sent: Thursday, December 09, 2004 7:35 AM
Subject: Re: Moose yoke?
last night similar to the Cessna 185 setup. He has made some similar setupsWarren,
Excuse me for jumping in here, Paul Erikson and I discussed using yokes
on the throttle quadrants too. I don't have the web site here but you want
to do a search using his name and Moose and should show some pictures of the
Moose. If you would like to compare notes I have his number but you can
find it on the web site. He's put Alaska doors on the one that is finished
and float doors on teh pilot/copilot doors. Paul is in the Anchorage area.
Cheers!
Chuck
Found it...
http://www.murphymoosealaska.com/Plane.html
