I had a Maule (with VG's) before this Moose (no VG's). I could land the Maule very short. Thus far I'm a bit disappointed that I haven't mastered a real short-field landing in the Moose (yet). I can probably get it stopped in 1,000, maybe 1,200 feet, but I'd like to do far less.
Also, it seems to land best in a slight wheel-landing attitude (TW just a few inches, I suspect, off the ground). I always 3-pointed the Maule.
From: mike.davis@dcsol.com on behalf of Dick Shotwell
Sent: Mon 9/20/2004 7:22 PM
Cc:
Subject: Re: UP Elevator rigging
Ted,
What approach speed do you use? We have about 50 hours on Moose 235DS and
have had our best landings with an approach speed of 90 MPH indicated (no
flaps). This seems too high but at the same time seems to work well. We
are still experimenting. We've made some pretty bad landings using full
flaps and 75 MPH (indicated) approach speeds.
Still testing!
Dick
Sent: Monday, September 20, 2004 18:22 PM
Subject: RE: UP Elevator rigging
With 68 landings in my Moose, I can say that if one gets too slow on
final there's very little (if any) up elevator left for a flair/landing
fineness. This is particularly true with a (very) forward CG (e.g. full
fuel, pilot, no bags/other weight.
Adding some ballast to the baggage area when flying solo will help this
issue tremendously.
With about 600+ landings in a Maule prior to owning the Moose, I can say
that the Maule had the same issue--too slow on approach and you either
added power to flair or pancaked. Adding a bit of up elevator will, of
course, help a little. However, it would be my humble opinion that the
right approach speed is really the key.
rickhm@comcast.net
Sent: Monday, September 20, 2004 2:16 PM
Subject: Re: UP Elevator rigging and Murray's (unfortunate) offroad
adventure!
Unfortunate! What airframe, Rebel or SR/Moose. My reason for asking is
to understand if all of us building a SR/Moose will see this.
Rick Muller
SR70
List archives located at:
