prop and oil temps
Angus McKenzie
prop and oil temps
Post by Angus McKenzie » Sat Feb 18, 2012 12:27 pm
Just a quick note to report the outcome of my changes.
I tried a friends 76-52 prop (way too fine) then repitched my 76-56 to
54" ----Works great.
Moved the oil-cooler from the lower left fire-wall to the left rear
engine baffle ---------Temps are now in the 195-210F range-----Perfect.
The 52" prop dropped my 75% power cruise to 80kts and had the 0-320 near
red-line on take-off, the 54" put me at 2500+ on take-off and 90kts
cruise power.
While pre-flighting after the Orillia float plane fly-in I found a
slight leak from my oil-cooler spraying onto the fire-wall and pulled it
off for a trip to the oil-cooler shop in Winnipeg,It was not repairable
nor was the second cooler we sent from a wrecked C-150 so I had to buy
an overhauled cooler and got it back on last Friday. The overhauled one
is not very pretty but it's tagged and has nice new paint on it.
Next chore for me is repairing a leak in an out-board float compartment
at the step, where the gear-hinge bolt goes.
Bob Fisher- It was great to finally get to meet you and see your really
nice Rebel,sorry we did not get to visit you at home but hope to do that
soon.
If anyone happens to be in this area on Saturday Sept.4 we are hosting
a huge bash here at our farm near London Ontario and you are invited to
attend. Pig-roast,band,lots of aviation types!
Regards to all, Angus
rebel
prop and oil temps
Post by rebel » Sat Feb 18, 2012 12:27 pm
Angus, I assume your prop diameters are 74 not 76. If so, your
numbers are bang on with my 74 X 54, with 2500 RPM take-off and
cruise at 90 knots (105 mph). My WOT top speed is about 2720 and
120+ mph. Again, this is with the 150 hp 0320 Rebel amphib.
"Angus McKenzie" <angus@lweb.net> wrote in message
news:006e01c48e98$2dbb7690$7305efd1@Thinkpad...
cruise power.
soon.
Angus McKenzie
prop and oil temps
You are correct,my mistake.
I will have to check and see what my WOT speed and RPM will be.
Angus
Sent: Tuesday, August 31, 2004 8:11 PM
Subject: Re: prop and oil temps
Jerry Purdom
prop and oil temps
Post by Jerry Purdom » Sat Feb 18, 2012 12:27 pm
Hi the speed are great,how is it off the water,and what type of prop Sen.,or
McCall.
THANKS
jerry
Sent: Tuesday, August 31, 2004 5:11 PM
cruise power.
soon.
Angus McKenzie
prop and oil temps
Hi Jerry
The 74-54 prop is a McCauley Klip-Tip that I bought with my 0-320 engine off
a buddy's 7GCB.So my engine and prop have been partners since 1960.
Sorry I can not say about the water take-off.I am still trying to feel out
the right spot on the floats for best performance. Maybe bobp could step in
here as he and Robin watched Jennifer and I depart from the water at
Orillia.
Regards, Angus
Sent: Wednesday, September 01, 2004 12:40 AM
Sen.,or
McCall.
THANKS
jerry
range-----Perfect.
near
cruise power.
it
repairable
one
compartment
really
that
soon.
hosting
Jerry Purdom
prop and oil temps
THANKS Angus
You know how it goes those high little lakes look to good sometimes
THANKS
jerry
Sent: Wednesday, September 01, 2004 6:24 AM
Hi Jerry
off
in
Orillia.
Regards, Angus
Sen.,or
McCall.
THANKS
jerry
range-----Perfect.
near
pulled
it
repairable
buy
one
compartment
really
that
hosting
rebel
prop and oil temps
Mine is the Sensenich. I don't have any actual measurements off the water,
and it ranges anywhere from about 10 seconds lightly loaded into a breeze to
upwards of 20 seconds as my load goes up. I can usually get 2 people and a
good load off in 25 seconds or less. Climb solo is 1100, and 800 loaded. Of
course, those numbers drop in hot weather and at higher altitudes.
"Jerry Purdom" <jerrygoneflying@shaw.ca> wrote in message
news:00bb01c48fdd$ce1762c0$34554718@ok.shawcable.net...
Sen.,or
McCall.
THANKS
jerry
range-----Perfect.
near
cruise power.
it
repairable
one
compartment
really
that
soon.
hosting
prop and oil temps
Post by Bob Patterson » Sat Feb 18, 2012 12:27 pm
Hi Angus !
Jumping in ! :-) Splash !!!
I didn't time your takeoff, but it was shorter than all of the other
takeoffs we watched - and the climbout was impressive too !! :-)
On Wednesday 01 September 2004 09:24 am, Angus McKenzie wrote:
Hi Jerry
Orillia.
Regards, Angus
Sen.,or
McCall.
THANKS
jerry
range-----Perfect.
near
it
repairable
one
compartment
really
that
hosting
prop and oil temps
Post by Walter Klatt » Sat Feb 18, 2012 12:27 pm
the water, and it ranges anywhere from about 10 seconds lightly
loaded into a breeze to upwards of 20 seconds as my load goes
up. I can usually get 2 people and a good load off in 25 seconds
or less. Climb solo is 1100, and 800 loaded. Of course, those
Jerry Purdom
Sent: Tuesday, August 31, 2004 9:40 PM
McCall.
THANKS
jerry
If so, your
take-off and
about 2720 and
to the left rear
take-off and 90kts
cruise power.
fly-in I found a
new paint on it.
soon.
