MP-14 air start question
mike.davis
Post by mike.davis » Sat Feb 18, 2012 12:13 pm
Robyn (MAM's test pilot) will tell you that they did the same thing... for a
while. After several hundred hours with no problems, they quit carrying the
scuba tanks.
On 5/6/2004 6:46 AM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
Another "friend" of mine <grin> told me that if I purchase a Moose with
the MP-14 (air start version) that I would need to carry one or perhaps
even two spare air bottles (used scuba tanks) with me if I go to remote
strips where there are no services available. Heck, even if I go to
many small-town strips I should have a spare bottle as no pressurized
air may be available.
Thoughts, comments?
I'm starting to feel guilty using so much list bandwidth...
Archives located at http://www.dcsol.com:81/default.htm
Ted Waltman
Post by Ted Waltman » Sat Feb 18, 2012 12:13 pm
Thoughts, comments?
Scott & Leere' Aldrich
Post by Scott & Leere' Aldrich » Sat Feb 18, 2012 12:13 pm
The way most of our Moose systems (and Pitts 12) are hooked up you can shut
the valve off right at the air reservoir. Highly unlikely it is going to
leak at all through this one valve. I would say your chances of a dead
battery on an electric start are greater.
Just my opinion.
Scott
Waltman
Sent: Thursday, May 06, 2004 7:55 AM
Subject: MP-14 air start question
Thoughts, comments?
David Stroud
Post by David Stroud » Sat Feb 18, 2012 12:13 pm
Giday, Ted. I currently doing research into the air start system for my Housai installation
and have been following the Yak list to gain some knowledge. They seem to recommend
carrying an aux bottle too but there are some choices of methods of filling them in the field.
Some recommend a scuba type arrangement and others recommend a Scott air bottle as
found in fire fighters supplementary air systems. The thought on the latter is that a dive shop
might not be handy to those in need but a willing fire station may be able to help.
Dave Stroud, Ottawa, Canada
Christavia C-FDWS
Fairchild 51 early construction
Sent: Thursday, May 06, 2004 9:55 AM
Thoughts, comments?
Don Boardman
Post by Don Boardman » Sat Feb 18, 2012 12:13 pm
Hi Ted,
If you listen to the Yak guys you will always hear one who says he carried a
scuba tank around for three years or so and finally took it out and put it
in the corner of the hanger. The conclusion, once the system proves its
reliability (especially with an isolation valve just downstream of the tank
that is closed at the end of flight) there is very little incentive to carry
around the extra tank. I think I would still carry a back up if going into
the boondocks.
Randy and I hope to be in the air in the next month or so. Will give a full
report of our experiences.
Regards,
Don Boardman
& Partner, Randy Bowers
N622D Double Duce Delta Moose
#130 M-14PF 400HP, MT-Prop/Beta, Aerocet 3500 amphibs
Delta Lake, Rome, NY
Dick Shotwell
Post by Dick Shotwell » Sat Feb 18, 2012 12:13 pm
Hi Ted,
When we first ran the M-14, we too used quite a bit of air. But after
learning the art of priming, we find that it starts real easy. I just takes
some time to learn and during that time, have plenty of air. Also, it seems
that every engine is a little different. Another thing we learned is that
timing is very important. We have two CJ-6's on the field that have the
same air start systems. They were having difficulty starting and found that
the magneto timing was off quite a bit. Although the engine seemed to run
OK, starting was hard. After correcting the timing, they are easy to start.
Of course, those are not M-14's but the same thing would apply. All that
said, we plan to carry some extra air the first times we venture into the
outback!
Disk and Dave Shotwell
Moose 096
N235DS
Thoughts, comments?
David Stroud
Dick, could you please say what type of valve is on the main system to accept
aux compressed air for emergency refill? Do you simply walk up to that filler port,
attach the two mating fittings and then open the aux compressed air tank with a
valve and watch the receiving tank get up to it's normal full pressure then shut off
and remove the filler tank? Thanks.
Christavia C-FDWS
Sent: Friday, May 07, 2004 8:06 AM
Subject: Re: MP-14 air start question
Hi Ted,
outback!
Moose 096
N235DS
Thoughts, comments?
Dick Shotwell
Dave,
I just found out that I cannot send picture attachments on the list serve.
Can I send this reply to your e-mail address? If so, let me know what your
address is.
Dick
Sent: Friday, May 07, 2004 7:04 AM
accept
filler port,
with a
then shut off
Christavia C-FDWS
Hi Ted,
takes
seems
that
that
run
start.
that
outback!
Moose 096
N235DS
with
perhaps
remote
Thoughts, comments?
Don Boardman
Hi Dave,
A picture of a filler schrader valve can be found in the archives at:
https://www.dcsol.com/file/area62/Air%20Manifold.jpg
ACS part# 06-11700 GOOSENECK HOSE COUPLING # 6116
on page 215 of the 2002-2003 Catalog is what I plan to use on the aux fill
tank hose. It just arrived from ACS today. Still in the box. I have not used
it yet. Hope to be starting the engine is a few weeks.
Your description of the filling process is basically correct.
Hope this helps,
Don B
Reply-To: murphy-rebel@dcsol.com
Date: Sat, 08 May 2004 16:45:43 -0600
Dave,
address is.
Dick
accept
filler port,
with a
then shut off
Christavia C-FDWS
Hi Ted,
takes
seems
that
that
run
start.
that
outback!
Moose 096
N235DS
with
perhaps
remote
David Stroud
Don, thank you very much for this excellent clarification. I've just about got it. It's
interesting to see a few different approaches to the same goal. Two more questions
if I may. Near the bottom center of your photo, it says in small print...pressure relief valve.
What is that referring to, please? Also, it looks as if the item on the lower left labelled as
the ...Dump valve, water and compressor air when tank full...is to be set to the normal 800 or
850 lbs and it will continue to dump overboard any accumulated water or oil in the whole
air start system as well as the continuous excess air from the compressor? Thank you very
much again and also to you, Dick.
Christavia C-FDWS
Sent: Monday, May 10, 2004 11:52 PM
Hi Dave,
Hope this helps,
Don B
Dave,
address is.
Dick
accept
filler port,
with a
then shut off
Christavia C-FDWS
takes
seems
that
that
run
start.
that
with
perhaps
remote
Don Boardman
Good morning Dave,
For your information, the air system was purchased from:
http://www.jimkimballenterprises.com/h_ ... moose.html
It was physically rearranged a bit for installation and an isolation valve
was installed just down stream of the tank.
it. It's
questions
There are definitely different approaches. For example some Yak guys like to
have their back up tank plumbed into the system so that it is filled by the
compressor some like it independent ... etc. Matter of taste and outlook on
the pro's and con's. That is what is so great about building experimental.
With or without sprinkles! The Yak list has been a good source of
information. You can sign up at:
http://www.matronics.com/subscription/
I use the digest form. For electrical try AeroElectric.
This valve will automatically release pressure if the system reaches a
preset point. I think it is set for aprox 800 PSI.
left labelled as the ...Dump valve, water and compressor air when tank
full...is to be set to the normal 800 or 850 lbs and it will continue to
dump overboard any accumulated water or oil in the whole air start system as
well as >the continuous excess air from the compressor?
This valve is controlled by the pilot with a cockpit switch. After your tank
is full to say 800 PSI (will lower to normal 750ish on cooling) you open
this valve and the dump compressor air overboard. As to accumulated water or
oil, its location in the system is such that it will probably do little for
these which are down stream of the valve. Kevin Kimball says that in his
experience if the valve is open once the system is charged that water/oil
accumulation is the tank has not been a problem. The tank air is down stream
of a check valve and therefore stays charged when the dump valve is open.
Thank you very
You are welcome. Randy and I have had a million questions, OK thousands.
This list and others have been a real help. After flying, SOON, and we have
a chance to see how all the systems work in real life we look forward to
sharing what we find.
OFF to the MOOSE WORKS,
Don B.
