taper reamers are hand turned but you don't want a tapered hole! Also some
adjustable straight reamers available that can be hand or power driven. I
don't know what you've ordered!
...gotta get back to doing Rev Can year end T2's......what a way to spend a
day (or should I say week+!)....especially when it's my birthday today!
Sent: Tuesday, March 23, 2004 12:49 PM
Subject: Re: ProSeal....
aWayne
I do not remember part number (I am at my office), but one of the first
job. You make 12 holes in a "part" than you put it on the main spar, use
the "part" as template, drill both to 5/32", reame them to 3/16, deburred
and assemble with AN3 bolt and proseal instead of primer ..... Anyway I
have order a reamer but do you use it by hand...?
Thanks again
Jean
Sent: Tuesday, March 23, 2004 12:09 PM
Jean, what are they referring to that needs to be reamed??
There isn't much that needs that kind of precision on the Rebel. If it's
appliesbolt hole drill it #12 for a nice tight fit and if a rivet #11 is fine
(solid rivet you might need #10 if it's a deep hole but this only
machinist5/32"building the SR).
Sent: Tuesday, March 23, 2004 8:49 AM
Subject: ProSeal....
Quebec)?Hello...
Do you know where I can find ProSeal in Eastern Canada (Ontario orspec, etc.Do have info on the products: Manufacturer, part number, size
available, milOn the first parts to be fabricate on the wing, manual say to drilland then use a rimer to go to 3/16". Standard 3/16" reamer for
*-------------------------------------------------------------------------*that Acklands sale for $18.00 is ok? Do you use them in a drill or by
hand?....Jean
Rebel 747R
