Jean,
I recall seeing the word "ream" in MAM used as in "ream the holes out with a
#11 drill". I don't know how general this is, but it seems MAM simply means
that if the holes were started as a smaller hole to get better position
accuracy, reaming really means to open it up to it's final diameter, and
possibly doing this in small drill size increments to avoid wobbled holes,
but not necessarily done with a reamer. I'll double check my MAM on this
tonight.
As for Proseal, I recently ordered the version of it sold by
vansaircraft.com. It looks like Proseal, ...and smells, feels, tastes like
it :) ...and it is almost 1/2 the cost I've seen for Proseal at typical
suppliers. An option at least -- just go to their online catelog and search
on proseal.
-Ben Ransom
-> Wayne
-> I do not remember part number (I am at my office), but one of the first
-> job. You make 12 holes in a "part" than you put it on the main spar, use
-> the "part" as template, drill both to 5/32", reame them to 3/16, deburred
-> and assemble with AN3 bolt and proseal instead of primer ..... Anyway I
-> have order a reamer but do you use it by hand...?
-> Thanks again
-> Jean
-> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> Sent: Tuesday, March 23, 2004 12:09 PM
-> Subject: Re: ProSeal....
-> > Jean, what are they referring to that needs to be reamed??
-> > There isn't much that needs that kind of precision on the Rebel. If it's
-> > bolt hole drill it #12 for a nice tight fit and if a rivet #11 is fine
-> > (solid rivet you might need #10 if it's a deep hole but this only applies
-> > building the SR).
-> > Wayne
-> > ----- Original Message -----
-> > From: "Jean Poirier" <oxyport@globetrotter.net>
-> > To: <murphy-rebel@dcsol.com>
-> > Sent: Tuesday, March 23, 2004 8:49 AM
-> > Subject: ProSeal....
-> > > Hello...
-> > > Do you know where I can find ProSeal in Eastern Canada (Ontario or
-> > Quebec)?
-> > > Do have info on the products: Manufacturer, part number, size
-> > > available, mil
-> > spec, etc.
-> > > On the first parts to be fabricate on the wing, manual say to drill
-> 5/32"
-> > and then use a rimer to go to 3/16". Standard 3/16" reamer for machinist
-> > that Acklands sale for $18.00 is ok? Do you use them in a drill or by
-> > hand?....
-> > > Jean
-> > > Rebel 747R
-> > > To unsubscribe from this list go to:
-> > > https://www.dcsol.com/public/code/html-subscribe.wcx
-> > > Archives located at https://www.dcsol.com/default.htm
-> > > Archives public username "rebel" password "builder"
-> > > To contact the list admin, e-mail mike.davis@dcsol.com
-> > https://www.dcsol.com/public/code/html-subscribe.wcx
-> > Archives located at https://www.dcsol.com/default.htm
-> > Archives public username "rebel" password "builder"
ProSeal....
Jean Poirier
ProSeal....
Hello...
Do you know where I can find ProSeal in Eastern Canada (Ontario or Quebec)?
available, mil spec, etc.
On the first parts to be fabricate on the wing, manual say to drill 5/32" and then use a rimer to go to 3/16". Standard 3/16" reamer for machinist that Acklands sale for $18.00 is ok? Do you use them in a drill or by hand?....
Jean
Rebel 747R
Jean
Rebel 747R
ProSeal....
There isn't much that needs that kind of precision on the Rebel. If it's a
building the SR).
hand?....
building the SR).
Quebec)?Hello...
spec, etc.Do have info on the products: Manufacturer, part number, size
available, mil
and then use a rimer to go to 3/16". Standard 3/16" reamer for machinistOn the first parts to be fabricate on the wing, manual say to drill 5/32"
hand?....
*-------------------------------------------------------------------------*Jean
Rebel 747R
David Stroud
ProSeal....
Giday, Jean. Here is a link to a product similar to Proseal. I sloshed my glass tank two years
ago with Por-15 and it seems to work fine. Available in Montreal too.
I am not stating that it is equal to or better than Proseal as I have never used Proseal.
http://www.por15.com/
By the way, Jean..will you be at Sun n Fun on Friday the 16th?
Dave Stroud, Ottawa, Canada
Christavia C-FDWS
Fairchild 51 early construction
Christavia C-FDWS
to go to 3/16". Standard 3/16" reamer for machinist that Acklands sale for $18.00 is ok? DoHello...
Jean
Rebel 747R
Jean Poirier
ProSeal....
Thanks again
Jean
Thanks again
Jean
5/32"Jean, what are they referring to that needs to be reamed??
building the SR).
Quebec)?Hello...
Do you know where I can find ProSeal in Eastern Canada (Ontario orspec, etc.Do have info on the products: Manufacturer, part number, size
available, milOn the first parts to be fabricate on the wing, manual say to drill
*-------------------------------------------------------------------------*and then use a rimer to go to 3/16". Standard 3/16" reamer for machinist
hand?....Jean
Rebel 747R
klehman
ProSeal....
PS890 B2 is the spec for what Murphy supplied me with and the one that
Aircraft Spruce sells.
1422 B2 might be slightly preferable for mogas and I think Leavens sells
that one. There should be some info in the archives from around August
2000. In the past Bob has said that the cheapest place to get the stuff
was from Murphy?? It doesn't matter who manufactures it as long as it
meets the spec. There must be some Montreal suppliers because the
airlines use the stuff and maybe Bombardier as well.
I also have had good results with imported 0.001" undersize reamers in a
battery drill. Mine were only about $7. or $8. each from KBC tools. 3/16
and 1/4, 5/16 and 3/8 (all .001 undersize) is all I've needed and I'm
not certain I've used the 5/16 one. I used them for wing bolts, strut
fittings, stabilzer attach bolts, landing gear hinge bolts, and things
where I wanted a tight fit. I just used a drill bit on things like the
wing spar laminations where I don't expect any movement.
Jean Poirier wrote:
Hello...
Jean
Rebel 747R
