want to buy WARP DRIVE PROP
Post by Walter Klatt » Sat Feb 18, 2012 11:59 am
Why a 4 blader? My 72 inch 3 blader worked very well with the 150
hp Lycoming on 1800 amphibs. More climb and cruise than the
Sensenich metal 2 blader, and no cracking on mine. And no, I'm
not selling mine.
Jerry Purdom
Sent: Saturday, February 14, 2004 3:34 PM
Cc: rick porteous
Subject: want to buy WARP DRIVE PROP
Hi a freind RICK PORTEOUS is looking for 4 BLADE WARP
DRIVE PROP with nickel leading edge for REBEL 150 h
lycom. on full lotus floats.Phone number is
250-675-4714,email is dtajbl@telus.net
THANKS
jerry
Jerry Purdom
Post by Jerry Purdom » Sat Feb 18, 2012 11:59 am
Hi a freind RICK PORTEOUS is looking for 4 BLADE WARP DRIVE PROP with nickel leading edge for REBEL 150 h lycom. on full lotus floats.Phone number is 250-675-4714,email is dtajbl@telus.net
THANKS
jerry
Jerry Purdom
Hi Walter
He talked to Darrell at Warp Drive and apparently they only sell 4 blade
for the 150 and 180 h. and that is what he recommends!!!!!! so if you know
of any for sale let Rick know
THANKS
jerry
Sent: Saturday, February 14, 2004 3:33 PM
Subject: RE: want to buy WARP DRIVE PROP
not selling mine.
Jerry Purdom
Cc: rick porteous
THANKS
jerry
I assume that is Warp's recommendation now to avoid the cracking.
The 180 hp would require 4 blades just to absorb all the hp. I do
know there were some on this list that were switching out their
Warps because of the cracking fears, so maybe someone here might
still have one for sale. Also, if he's going to a 4 blade Warp, I
would expect the efficiency to drop a little, and with the extra
blade, you're getting closer to the weight of a 2 blade metal
Sensenich. With hauling those Full Lotus floats out of the water,
he might want to try a Borer.
Jerry Purdom
Sent: Saturday, February 14, 2004 5:05 PM
Subject: Re: want to buy WARP DRIVE PROP
Hi Walter
THANKS
jerry
with the 150
And no, I'm
not selling mine.
Jerry Purdom
Cc: rick porteous
THANKS
jerry
No, but that sounds like a pretty good deal. Sure would like to
hear about someone trying a Borer on an amphib Rebel. There is
one here locally that I could borrow, but unfortunately my
Sensenich spacer won't fit it. It would work well on a non-spacer
regular cowl.
Legeorgen@aol.com
Sent: Saturday, February 14, 2004 5:25 PM
Did you ever talk to Sensenich in Florida (wood prop
factory)? They told me
several years ago they would make me an experimental
Borer prop on my Rebel for
1200 or 1800 US. I can't remember now what the exact
amount was.
I might buy one after I get some experience with the
Amphibs. Or an
adjustable pitch. Borer would be less $$$ I'm sure.
Bruce
Jerry Purdom
Hi again,he has a Sensenich 74x56 now and finds that slow,another freind of
ours has a 4 blade WARP on 150hp with full lotus on his Rebel and he
cruises a little faster than him.He figures the warp will be way lighter
than his Sensenich,I have no idea the weight diff. Also he has flown my
Rebel with 180 hp. and 4 blades and seemed to like it.
Sent: Saturday, February 14, 2004 5:07 PM
Jerry Purdom
Hi Walter
THANKS
jerry
with the 150
And no, I'm
not selling mine.
Yeah, I guess even with 4 blades, he should still be about 20
pounds lighter than the Sensenich as long as he doesn't use that
harmonic balancer. If he likes the Warp 4 blader on the 150 hp,
he would like the 3 blader even better.
I am using the 74 X 54 Sensenich right now. While not quite as
good in climb and cruise as the Warp, I think my take-offs are
slightly faster. That's because the Sensenich turns 2500 on
take-off while my Warp only did 2450. However, after lift off,
the Warp would turn 2600 in climb while the Sensenich only did
2550. My Warp would also redline over 2700 at that pitch setting,
and had to throttle back a bit at the top end. The Sensenich just
hits 2700 at full throttle straight and level.
Too bad Warp doesn't make an 82 inch 2 blader! I guess they would
need to engineer a humongous hub and clamping set-up with all
that inertia.
180 hp on a Rebel, heh? Must be pretty good performance!
Jerry Purdom
Sent: Saturday, February 14, 2004 5:50 PM
his Rebel and he
will be way lighter
the cracking.
the hp. I do
switching out their
someone here might
blade Warp, I
with the extra
of the water,
Jerry Purdom
Hi Walter
THANKS
jerry
with the 150
cruise than the
And no, I'm *------------------------------------------------------
Jerry Purdom
Walter we have 2 Bush Masters on floats in the Okanagan with Borer and the
word is they climb like a dam but slow on cruise
THANKS
jerry
Sent: Saturday, February 14, 2004 5:36 PM
regular cowl.
Legeorgen@aol.com
amount was.
Amphibs. Or an
Bruce
Jerry Purdom
Not that good really,I'm low time hrs.on floats 400 and have only flown one
other Rebel,Ricks 150hp.so I couldn't really judge that well. I'm running
Edo 2000 on my Rebel so hard to tell ???But I second that 82" I would giver
a try
Sent: Saturday, February 14, 2004 5:59 PM
that inertia.
Jerry Purdom
his Rebel and he
will be way lighter
the cracking.
the hp. I do
switching out their
someone here might
blade Warp, I
with the extra
of the water,
cruise than the
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 11:59 am
Did you ever talk to Sensenich in Florida (wood prop factory)? They told me
several years ago they would make me an experimental Borer prop on my Rebel for
1200 or 1800 US. I can't remember now what the exact amount was.
I might buy one after I get some experience with the Amphibs. Or an
Bruce
Terry Dazey
Post by Terry Dazey » Sat Feb 18, 2012 11:59 am
on 2/15/04 4:25 PM, Keith Oliver at kboliver@adelphia.net wrote:
Is there a web site for Prince Props ???
Keith:
Try this for starters (no pun intended).
http://www.tntlandinggear.com/store/sho ... rcraft.htm
Prince Aircraft Co.,
Jerry Purdom
Hi Keith:
The web site is www.princeaircraft.com
THANKS
jerry
Sent: Sunday, February 15, 2004 4:25 PM
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Dale Kopff
Sent: Sunday, February 15, 2004 6:03 PM
Cc: "rick porteous" <dtajbl@telus.net>
Sent: Saturday, February 14, 2004 5:34 PM
number
THANKS
jerry
My prince prop (wood-carbon fiber) out performes the 4-blade warp that
developed cracks in two blades and my newly overhauled Sensenich prop (for
sale, $1300.00 US), and weighs only 8lbs.
Dale >
Jerry Purdom
Hi Dale
Is the prince a 2 blade or---- and what are you hanging it on Rebel,what
hp.,cruise,climb,and any other info you have.Rick Porteous might be
interested in your sensenich,his email address is dtajbl@telus.net, phone is
1-250-675-4714
THANKS
jerry
Sent: Sunday, February 15, 2004 3:02 PM
number
THANKS
jerry
Dale >
Dale Kopff
Post by Dale Kopff » Sat Feb 18, 2012 11:59 am
THANKS
jerry
Dale >
Keith Oliver
Post by Keith Oliver » Sat Feb 18, 2012 11:59 am
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Dale Kopff
THANKS
jerry
Dale >
