wing mounting
rebel
wing mounting
Post by rebel » Sat Feb 18, 2012 3:01 am
Hi Rallph
When putting the wings on the Elite the idea is to set the for and aft
location based on the rear spar fitting as you do not want any bending or
preload of the fittings. It is best to put the tail up and to level the
airplane as the weight of the wing will cause it to slide back. You may find
that the wings have different front and rear gaps inside the cage main spar
attach points don't worry about it the airplane will not know the difference
and it will fly just fine. Make your spacers up so they fit snug between the
front spar and the cage as you do not want to bend the attach points on the
fuselage or have the wing move
Sean
11/19/2003 11:51 AM, REBAKER@FTC-I.NET wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.8)
-> for murphy-rebel@dcsol.com; Wed, 19 Nov 2003 09:52:35 -0900
-> Received: from smtp04.infoave.net ([165.166.0.29]) EHLO=smtp04.infoave.net
-> by dcsol.com (Wildcat! SMTP v5.6.450.8) with SMTP
-> id 143902640; Wed, 19 Nov 2003 09:52:34 -0900
-> Received: from oemcomputer ([216.218.88.81])
-> by SMTP00.InfoAve.Net (PMDF V6.1-1IA5 #30771)
-> with SMTP id <01L37UMM2JWS94EM4V@SMTP00.InfoAve.Net> for
-> murphy-rebel@dcsol.com; Wed, 19 Nov 2003 13:36:08 -0500 (EST)
-> Date: Wed, 19 Nov 2003 13:35:17 -0500
-> From: Ralph Baker <rebaker@ftc-i.net>
-> Subject: wing mounting
-> To: murphy-rebel@dcsol.com
-> Message-id: <003601c3aecb$e22e8700$5158dad8@oemcomputer>
-> X-Orig-MIME-version: 1.0
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1165
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1158
-> X-Orig-Content-type: multipart/alternative; boundary="----
=_NextPart_000_0033_01C3AEA1.F8320060"
-> X-Priority: 3
-> X-MSMail-priority: Normal
-> How much front to rear float, if any is permissible in the front wing
-> attachments? Am I correct that the front wing attach bolts are
-> tightened firmly but not meant to compress the carrythrough wing
-> attachment plates?
-> Thanks,
-> Rallph Baker
wing mounting
Post by Ralph Baker » Sat Feb 18, 2012 3:01 am
attachment plates?
Rallph Baker
wing mounting
Post by Wayne G. O'Shea » Sat Feb 18, 2012 3:01 am
Sean's got it "pegged" there Ralph. Rear fittings tight and straight, and
spacers up front to keep it this way, then tightened. Some builds seem to
end up with the front wing fitting tight to the forward inside face of the
carrythrough and only a spacer at the rear, and others need spacers front
and back.
BUT, you Moose guys remember that the front spar attach fitting is to be
tight in the carrythrough and spaced so that the Rear attach fitting is
centered and >FLOATING< inside the fuselage fittings. NOT HELD TIGHT!
Bolt/nut is to be tightened only to be snug, allowing the fuselage fittings
to stay parrallel to each other. This leaves a small float gap on either
side of the wing fitting and allows the loads to be transfered to the front
spar fus carrythrough, instead of the rear fuselage attach carrythrough.
Sent: Wednesday, November 19, 2003 4:00 PM
Subject: RE: wing mounting
Hi Rallph
find
spar
difference
Sean
-> X-Priority: 3
-> Thanks,
-> Rallph Baker
Murray Cherkas
wing mounting
Post by Murray Cherkas » Sat Feb 18, 2012 3:01 am
Ralph:
I shimmed the front wing attach point with washers.I filed a washer down so
that it fit snuggly in but not to tight. this allowed me to tighten the
bolt. BTW MAM's 16 bolt is not long enough. I used a 17 length bolt here.
Good luck
Murray
Sent: Wednesday, November 19, 2003 11:35 AM
attachment plates?
Rallph Baker
