I have been fitting the channel for the torque tube hanger as well as the
torque tubes themselves. I have a couple of questions I hope someone may be
able to answer.
1. According to my manual (#687R), after fitting/rivetting the hanger bracket
to the channel, and the channel to bulkheads F&G, I'm to install a strap to
tie the two channels together BEHIND the hanger bracket. Also I'm to install
gussets at each end of the channels to tie the channel to bulkheads F&G. Would
anyone have a photo of how this was done? It seems to me there is very little
real estate left on bulkhead F to get this done. Would really appreciate a
photo.
2. With the wing attached to the fuselage, the flaperons attached to the wing,
and the flaperon in the NEUTRAL position, is the trailing edge of the flaperon
supposed to be even with the trailing edge of the fairing box? OR is the
trailing edge of the flaperon higher (approx 1 1/8") than the trailing edge of
the fairing box. My interpretation of the neutral position places the flaperon
trailing edge high. I'm trying to figure out if this is correct or not.
Thanks for any help.
Roger Hoffman #687R
Eugene, OR USA!
Rebel Flaperon Control Systems
rognal
Thanks Drew.
Hi Roger
Can't help with a picture but flaperon neutral is even with the fairing box.
bracketI have been fitting the channel for the torque tube hanger as well as the
able to answer.
Wouldto the channel, and the channel to bulkheads F&G, I'm to install a strap to
littleanyone have a photo of how this was done? It seems to me there is very
wing,real estate left on bulkhead F to get this done. Would really appreciate a
photo.
flaperonand the flaperon in the NEUTRAL position, is the trailing edge of the
edge ofsupposed to be even with the trailing edge of the fairing box? OR is the
flaperonthe fairing box. My interpretation of the neutral position places the
Drew Dalgleishtrailing edge high. I'm trying to figure out if this is correct or not.
Roger Hoffman #687R
Eugene, OR USA!
I set my neutral position the same as Drew, ie., even
with the fairing box and the wingtips. However, now
that I have been flying for a few years, I might do it
differently if I was building again.
Most of the flying is done in full reflex, and that's
also when you want to have the least drag to maximize
your cruise speed. So if you angled the fairing up from
the roof line to match the trailing edge in the reflex
position, that should reduce turbulence and drag at
that point. I would do the same with the tips.
Archives located at
cribe.wcx-----Original Message-----
Sent: Monday, September 08, 2003 9:44 PM
Subject: Re: Rebel Flaperon Control Systems
Hi Roger
At 07:29 PM 9/7/2003 -0800, you wrote:torque tube hanger as well as theI have been fitting the channel for thequestions I hope someone may betorque tubes themselves. I have a couple offitting/rivetting the hangerable to answer.
bracketbulkheads F&G, I'm to install a strap toto the channel, and the channel tohanger bracket. Also I'm to installtie the two channels together BEHIND thethe channel to bulkheads F&G.gussets at each end of the channels to tie
WouldIt seems to me there is veryanyone have a photo of how this was done?
littledone. Would really appreciate areal estate left on bulkhead F to get thisthe flaperons attached to thephoto.
wing,is the trailing edge of theand the flaperon in the NEUTRAL position,
flaperonof the fairing box? OR is thesupposed to be even with the trailing edge(approx 1 1/8") than the trailingtrailing edge of the flaperon higher
edge ofneutral position places thethe fairing box. My interpretation of the
flaperonout if this is correct or not.trailing edge high. I'm trying to figure------------------------------*Thanks for any help.
Roger Hoffman #687R
Eugene, OR USA!
*-------------------------------------------http://www.dcsol.com:81/public/code/html-subsTo unsubscribe from this list go to:
http://rebel:builder@www.dcsol.com:81/default.htmArchives located at
mike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
