My only concern with using engine oil for the PSRU also would be the
introduction of contaminants from one system to the other should either ever
have a problem. Both components are expensive items, I'd just hate to see
both placed at risk even if one itself has preformed flawlessly just because
of some unforseen problem with the other.
Sent: Thursday, June 26, 2003 7:54 PM
Subject: PSRU decisions to make
*-------------------------------------------------------------------------*Now that I've ordered my PSRU I thought I could relax and enjoy the fact
that I finally decided on one. (The Firewall Forward CAM 500 helical
gear drive.) Now I have two more decisions to make. Do I have a vacuum
pump drive installed or just go with a belt driven one or even a
venturi? I have the option of using engine oil to cool and lubricate
the gears in the PSRU or I can go with a dry sump system. Apparently,
there is some difference in how it's set up depending on which way to
go. It seems like a dry sump would be better since the only heat
introduced into the oil would be from the PSRU itself. But using engine
oil would be a simpler installation and I wouldn't have to find room for
the PSRU oil sump. I wonder if anyone has any thoughts about that? I'm
inclined to go with a simple venturi which would be in keeping with my
continued "keep it simple" philosophy, and I would not miss a knot or
two in cruise. I've never flown with a venturi for vacuum. Can anybody
fill me in on their performance? Do they work well through the entire
speed range of a Super Rebel? Aircraft Spruce sells a 9"Hg venturi.
Hopefully it will still produce the 4-5"Hg I will need for the gyros
even at low airspeed.
SR#044
