high speed drill
mike.davis
high speed drill
Post by mike.davis » Sat Feb 18, 2012 2:02 am
The drill I am looking at getting is 2800 RPM... but that's the fastest I've
found for a "reasonably" priced one... I saw a couple at 3200 and 3600 at over
3 times the price. The 13,000 - 17,000 rpm drill is only $85 from Aircraft
Spruce... just doesn't seem right.
On 5/19/2003 8:46 PM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
-> Hi Mike !
-> I think the 'cleaner hole' thing was based on local experiences
-> with 6,000 rpm air drills - that being a 'standard' (???) speed that
-> was readily available ....
-> 13,000 - 17,000 rpm !!!! Wooooow !!! Sounds like a
-> screamer !!
-> Only cautionary note I've heard about the faster drills -
-> "They're fast & light, and do produce a clean hole, BUT ......
-> they make a GREAT ROUTER if you're not VERY careful, and quick with
-> the OFF button !" ;-) ;-^) :-) ;-)
-> Might be very handy for oval holes - like skylights !! ;-^)
-> .....bobp
-> -------------------------------orig.---------------------------------
-> At 05:01 PM 5/19/03 -0800, you wrote:
-> >In the past it has been discussed that the faster your drill, the cleaner
-> >the holes, and the easier it is to debur. Well has anybody used the
-> >"pneumatic high speed drill" that Aircraft Spruce is offering with
operating
-> >speeds of 13,000 - 17,000 RPM. Check it out here:
-> >http://www.aircraftspruce.com/catalog/t ... tdrill.php
-> >The drill I was looking at runs at 2800 RPM, but then I stumbled across the
-> >one above... I would imagine that it doesn't have much torque, but thought
-> >it was worth looking at. I built my stab just using my electric drill
(2500
-> >RPM), but it gets aweful heavy after a while. Now with father's day coming
-> >up, a nice pneumatic drill is just the ticket for a present from my family.
-> >Thanks, Mike
high speed drill
Post by Bob Patterson » Sat Feb 18, 2012 2:02 am
Hi Mike !
screamer !!
"pneumatic high speed drill" that Aircraft Spruce is offering with operating
it was worth looking at. I built my stab just using my electric drill (2500
Thanks, Mike
high speed drill
Post by Mike Davis » Sat Feb 18, 2012 2:02 am
Thanks, Mike
Nielsenbe
high speed drill
Post by Nielsenbe » Sat Feb 18, 2012 2:02 am
I have a 18000 rpm drill......... wait they call it a rotozip. I think bobp
is right about the router theory. I am not sure you could keep an edge on a
bit turning that fast either. good luck.
Brad
Gordon Mohr
high speed drill
Post by Gordon Mohr » Sat Feb 18, 2012 2:02 am
The air turbine in an air tool spins around 20,000 rpm or more. The
difference in the output only depends on the gearing, usually a
planetary gear. I turned my 2500 rpm air drill into a 12,000 rpm drill
by locking the planetary. It sucked. No torque, and if the drill bit
doesn't start clean, it will "chatter" causing a ragged elongated hole.
I use a 2500 RPM skil or dewalt drill for 1/8" holes. It's quite light
and doesn't freeze your hand off like an air drill after a few dozen
holes. Also, dragging a heavy air hose is a pain. (I use a length of
1/4" fuel line as a leader for my pneumatic riveter to save weight) For
the pre-drilled 3/32" holes I use a dremel tool with a titanium drill
bit. It weighs next to nothing and it's so fast it's like poking a
needle through. Again, keep the speed down to maybe 15,000 or it will
chatter.
Gordon
-> Hi Mike !
-> screamer !!
Phil McGrogan
high speed drill
Post by Phil McGrogan » Sat Feb 18, 2012 2:02 am
Mike, I would think that this is a modified 90^ die grinder (from the speed
range and the drilling capacity). While it may indeed produce a cleaner
hole if used in a properly controlled way, I don't imagine that it has a
teasing trigger, hence it will be either on or off. When starting a hole it
will have tendency to walk from the desired location.
Phil McGrogan
SR32QB
<snip> . . . . The 13,000 - 17,000 rpm drill is only $85 from Aircraft
Rebflyer
high speed drill
Post by Rebflyer » Sat Feb 18, 2012 2:08 am
Well I bought a recon'd high speed air driven at osh a few yrs back for the
float building. 5000rpm. It worked well. to keep it from walking, it just took
a pressure push prior to starting, a tech learned on the airplane. The
deburring was some what less. That's all the good I have to say. I hated fighting
the hose, after a long continued use my hand would get cold, and I still had to
deburr. I wouldn't do it again. I like my 9.6v makita that I've owned since
1978. It still has one original battery. Survived the drop test a number of
times, from as high as 20 ft to turf. and 8ft to concrete. IMHO Curt
