Having looked through the archives, I cannot seem to find the info I am
looking for... the dimensions for the landing light kit from Trevor/MAM.
We want to install our own landing lights but would like to know the
dimensions of the lexan used, the aluminum trim around lexan,etc. Also,
does the kit use the existing rivet line of the front spar? I don't
suppose there are pictures of installation in progress that can be sent
to me directly or to archives??? Any info would be greatly appreciated.
Peter & Monica
SR003
landing light
wrayt
landing light
If you go to construction on my home page
http://wrayt.tripod.com/construction.html find the picture of the light
and click on it you should get a bunch more pictures (clicking on any
picture should give you a larger view)
"capete@golden.net" wrote:
Wray Thompson ...Rebel 306 ...home page http://wrayt.tripod.com/
My ICQ number is 29764664
--Having looked through the archives, I cannot seem to find the info I am
I don't
Peter & Monica
SR003
wrayt
landing light
I see your building the super, these pictures are of a Rebel
wrayt wrote:
--If you go to construction on my home page
landing light
Both wings are made from the same parts!! Especially the last 3 bays which
are all Rebel rib, spar and skin thickness'!
Sent: Wednesday, December 12, 2001 4:32 PM
Subject: Re: landing light
**I see your building the super, these pictures are of a Rebel
wrayt wrote:--If you go to construction on my home page
**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
**** To contact the list admin, e-mail mike.davis@dcsol.com
David Ricker
landing light
Peter & Monica
The Bezel around the lights is 11 - 3/16 x 8 - 1/2 with 1" rads outside and the
inside is 2" smaller in each dimension keeping the 1" rads. The Lexan is 1"
narrower in each dimension than the Bezel outer. The rivet line is about 2"
farther back than the front spar.
OK?
Dave R.
David A. Ricker P. Eng.
DARTEC Engineering Inc.
3 Tamarac Drive
Fall River, Nova Scotia
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
OK?
Dave R.
Peter & Monica
SR003
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
landing light
Hi Peter & Monica !
You might want to consider putting Halogen lights in the
wingtips, as Murphy now supplies tips set up this way ....
Of course, you'd use your present tips, and buy the lights from
Canadian Tire - they're easy to mount, and you just make a Lexan
cover as you would for the wing-mounted lights.
Saves cutting the wing, and makes lights a bit easier to
wire & change .... (Lights can be brighter, and a LOT cheaper !)
....bobp
-------------------------------orig.-------------------------------------
....bobp
Peter & Monica
OK?
Dave R.
Peter & Monica
SR003
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
