alodine and epoxy primer
Post by Mike Davis » Fri Feb 17, 2012 4:22 pm
Received: from albedo.net (ppp121.albedo.net [206.51.22.140]) by
juliet.albedo.net (8.9.0/8.6.9) with ESMTP id OAA20729 for
<murphy-rebel@dcsol.com>; Tue, 18 Aug 1998 14:59:29 -0400
Message-ID: <35D9CF0D.81B9D213@albedo.net>
Date: Tue, 18 Aug 1998 14:59:25 -0400
X-Mailer: Mozilla 4.05 [en] (Win95; I)
MIME-Version: 1.0
To: Murphy Rebel <murphy-rebel@dcsol.com>
Subject: alodine and epoxy primer
This is a repeat of the same question I have asked on RAH.
There is a great deal of written opinion that alodining the exterior of a
6061T6
aluminum airframe before applying the epoxy primer is the best way to go. I
would prefer not to use the alodine simply to avoid the environmental
impact,
but don't want to repaint for a looong time. (We drink well water and
spreading
chromate laden rinse water around doesn't seem like a good idea.)
Randolph for instance does not suggest alodining. They do suggest their
metal
cleaning product but the fine print says it is intended primarily to roughen
alclad and my 6061 is not alclad.
Has anyone had good results with just detergent cleaning and scuffing with
scotch brite pads?
thanks
Received: from tim - 153.34.164.222 by email.msn.com with Microsoft SMTPSVC;
Tue, 18 Aug 1998 18:38:08 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: alodine and epoxy primer
Date: Tue, 18 Aug 1998 18:29:05 -0700
Message-ID: <000401bdcb11$036d01c0$2a640a80@tim>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Importance: Normal
In-Reply-To: <35D9CF0D.81B9D213@albedo.net>
Return-Path: tlcarter@email.msn.com
Yes. I have had good results up to this point not using any alodine. I have
chosen not to alodine for the same reasons you mention.
I do, however, use a Scotchbrite pad (maroon color) as a rule, and in some
cases on the smaller stuff, phosphoric acid to help with the cleaning
process.
I have over the life of my project used three different primers:
1) System 3
2) PPG DP40
3) and now, because I live in the welfare state of California, PPG DP40LF
(lead free)
I quit using System 3 because of all things, I found out quite by accident
that it was not waterproof. That is the most tenacious stuff when it cures,
very durable, and not even a soak in acetone will get rid of it. But water
will. Soak it in water for a week, you can peel it off. When I called the
System 3 guys with this news, they didn't flinch. Their solution was to
topcoat the primer with their clearcoat, which is waterproof. Is that silly
or what?
Anyway, after that I moved on to PPG DP40 on the advice of an RV builder.
Good stuff, but not as abrasion resilient as the System 3 (except for it
appears to be more water resistant). And then I moved to the DP40LF, which
is not as good as the DP40 to spray thin, and it costs more. I am thinking
very seriously about going back to PolyFiber Epoxy Chromate for the
remainder of the build.
Anyway, the net net of this ramble is this:
I use Scotchbrite alone to rough the surfaces, and then I clean with PPG
acrylic cleaner (DX 330 is the formula number I think), and then I prime
with DP40LF. No problems. I have some pieces over three years old with
primed surfaces, and no chips, no fades, no paint coming off problems.
Some tell me I am doing the wrong thing, and just as many say my method is
OK. It will continue this way and then we will fly it.
Hope that helps.
Tim
#438R
From: klehman@albedo.net [mailto:klehman@albedo.net]
Sent: Tuesday, August 18, 1998 11:59 AM
To: Murphy Rebel
6061T6
impact,
spreading
metal
scotch brite pads?
thanks
Received: from [204.191.147.32] (helo=ts69-01.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0z8yFk-0007dz-00; Tue, 18 Aug 1998 22:45:37 -0400
Mime-Version: 1.0
Subject: Re: alodine and epoxy primer
Message-Id: <E0z8yFk-0007dz-00@mail2.toronto.istar.net>
Date: Tue, 18 Aug 1998 22:45:37 -0400
Alodine is not necessary for a good bond - it is just a surface
cover to prevent oxidation. You can get a good bond with the primer by
using a Scotchbrite pad & Alumiprep (a mild etch available from Leavens,
etc)
The Alumiprep is mildly caustic, and must be rinsed off thoroughly, but it
would not be violently toxic like the Alodine.
The secret is to get the primer on ASAP after etching, as the
aluminum is bare, and will oxidize rapidly, AND the airframe attracts oils
from handprints, dust, etc. Getting the primer on fast prevents many
problems.
The Polyfibre epoxy zinc chromate primer supplied with the kits
has been proven to be the best corrosion protection available. It 'may'
not be compatible with some newer paints, which are sold as "systems", but
I haven't heard of any problems with RM or PPG paints.
....bobp
----------------------------orig.---------------------------------
6061T6
impact,
spreading
metal
roughen
scotch brite pads?
thanks
Received: from mime3.prodigy.com (mime3.prodigy.com [192.168.253.27])
by clmout1-int.prodigy.com (8.8.5/8.8.5) with ESMTP id NAA30012
for <murphy-rebel@dcsol.com>; Wed, 19 Aug 1998 13:50:05 -0400
Received: (from root@localhost) by mime3.prodigy.com (8.6.10/8.6.9) id
NAA17448 for murphy-rebel@dcsol.com; Wed, 19 Aug 1998 13:49:05 -0400
Message-Id: <199808191749.NAA17448@mime3.prodigy.com>
X-Mailer: Prodigy Internet GW(v0.9beta) - ae01dm04sc03
Date: Wed, 19 Aug 1998 13:49:05, -0500
Ken There is a product that is called ACL 50 or something like
that might be what you are looking for. I have used it on some
acft. with good results. It is easy to use by a spray device but
would be
on the tempory side because the manf. recommends every five years.
Don
