engine cooling
brian amendala
engine cooling
Post by brian amendala » Sat Feb 18, 2012 12:02 am
Builders, we just finished our murphy rebel on floats and are having
cooling problems. we are running a 160 horsepower O-320 and can only taxi
for about five minutes at around 1300 rpm and the engine temp will rise to
220 degrees C. we baffled with standard side and rear baffling, but also
ran baffling over the top front of the enging (just behind the fly wheel).
we also cut two reverse scoops in the bottom of the cowling for more air
escape, but haven't tested it yet. we are wondering how the rest of the
builders have baffled their 0-320's and if they ran the baffling over the
top of the engine like we did, or ran it down below the fly wheel and left
the top more open, like Cessna does. if anyone has had cooling problems and
has found fixes for them, whether it be with baffling or changes in the
cowling, we would appreciate it if you would let us know.
thanks,
Brian and Brian
Get your FREE download of MSN Explorer at http://explorer.msn.com
brian amendala
engine cooling
thanks,
Brian and Brian
engine cooling
Post by Bob Patterson » Sat Feb 18, 2012 12:02 am
Hi B & B !!
Gee, 220 degrees isn't much for CHT !! Or is that OIL temp ??
Do you by any chance have that cursed "Speed Cowl" ?? If so,
you will need a LARGER opening at the bottom, and possibly a lip
added at the back. Some have made a hinged bottom to the whole
channel behind the carb, as a 'cowl flap'.
Do you have an oil cooler - it is absolutely necessary !
Don't know ANYONE who has baffled on top - how tight are
you to the tops of the cylinders ???
If you have the speed cowl, make sure that there is no gap
in front of the carb filter, as air entering there will reverse-
pressurize the cowl.
Last thought - if it's a brand-new engine, you will have to
fly it HARD for a couple of hours to seat the rings. Temperatures
will then come down ....
....bobp
PS
One more thought - you might want to check your guages by
putting the temp. probe into a pail of boiling water. It wouldn't
be the first time a guage was inaccurate !! ;-)
-------------------------------orig.------------------------------------
At 12:10 PM 6/17/01 -0700, you wrote:
thanks,
Brian and Brian
murphy-rebel mailing list.
engine cooling
Post by Walter Klatt » Sat Feb 18, 2012 12:02 am
Bob, I thought the same initially, but then I noticed that he said 220 C not
F. There's a lot that has been said before on this subject, and I also had
this problem with the speed cowling. I just had to make the bottom opening
much bigger, add lips, and also remove the inside top lips from my inlets at
the front. It's running cooler now, but still heats up on a hot day in climb
out. The other thing for me still to try is fairing the bottom firewall
flange where the hot air exits out the bottom.
Sent: June 17, 2001 7:23 PM
Subject: Re: engine cooling
Hi B & B !!
....bobp
PS
thanks,
Brian and Brian
engine cooling
Thanks Walter !!
My eyes saw Centipede, but my brain registered Frankenstein !!
Duuuh !! Sorry about that !! 220 C <IS> pretty warm !!
Many builders have had great improvements from fairing that
lip at the bottom of the firewall - good luck !
----------------------------------orig.----------------------------------
Hi B & B !!
....bobp
PS
thanks,
Brian and Brian
Drew and Jan
engine cooling
Post by Drew and Jan » Sat Feb 18, 2012 12:02 am
Brian At 1300 rpm are you in a plowing attitude? Nose high and low speed
won't get much air going over your engine. I had problems with my rebel
overheating and found a few things to lower my temps.
1. I moved my oil cooler from the firewall to the rear baffle. This helped
a lot I wasn't getting enough air through the oil cooler before.
2. I installed baffles between the cylinder heads to make sure the air has
to flow through the fins
3. I sealed every gap and joint in the baffles and between the baffles and
engine block with high temp silicon seal.
4. I treated the engine with slick 50. It helped a bit but I wouldn't do it
before your engine's broken in.
5. I reworked my bottom cowl to make the air exit larger but this made very
little difference.
6. I installed header tape on my exhaust. This is a ceramic cloth tape that
racers use to wrap their headers. It keeps the heat in the pipes and
prevents it from being radiated into the engine compartment. The package
also claims increased horsepower but I don't believe that. Wrapping the
exhaust made the biggest difference lowering my oil temp 15-20 deg. F
Good luck Drew
thanks,
Brian and Brian
engine cooling
Hi Drew !
I hope you have a stainless steel exhaust system ! There have
been several cases where the whole exhaust pipe under the header tape
was completely (!!) corroded away. This allowed exhaust gas to blow
onto the gascolator ! :-( (.... In only one year of flying !)
This insulating tape is not recommended for regular steel
exhaust systems for this reason.
--------------------------------orig.------------------------------------
little difference.
Good luck Drew
thanks,
Brian and Brian
LisaFly99
engine cooling
Post by LisaFly99 » Sat Feb 18, 2012 12:02 am
In a message dated 6/20/01 4:16:57 PM Central Daylight Time,
bob.patterson@canrem.com writes:
You're very right there Bob.
If you're going to rap regular steel exhaust you should have it aluminized.
If you send it to a good shop for aluminum coating it will last 3 times
longer under normal conditions.
Phil&Lisa Smith #460 N414D
engine cooling
One thing that you CAN do that will really lower temperatures
in the "engine room", AND lengthen the life of your pipes, is to
ceramic coat the insides of the pipes. This special coating is
sometimes called 'heat shielding'.
There is a fellow up here near Peterborough who has been doing
this for years for sports cars, and he is interested in doing aircraft
too. Besides the exhaust pipes, they also treat pistons and valves ...
greatly extends their service life under severe conditions.
---------------------------------orig.-----------------------------------
Drew and Jan
engine cooling
Hi Drew !
Yes Bob I have a stainless cross-over exhaust from a tri-pacer that I
modified to fit. I inspect it regularly and remove all the tape when I do
my annual inspection. So far I've had no problems at all. I wasn't aware
that corrosion is a problem. I thought that the high heat can cause
cracking and actually burn holes through the pipe.
brian amendala
engine cooling
What does it cost, Bob? I have been shaking out my Rebel and have heat
problems. I appreciate the tremendous help evryone is providing. I have
treid everything and after reading all the mail, I am now convinced that
this Rebel will be forced to run hot. Everyone seems to have heat problems.
I even talked with Robin Dyck at Oshkosh last year and he said he wished it
would run cooler. I have tried adding out ducts at the bottom, which helped
slightly, I have tried changing the baffling and I even cut a 1 inch high
gash out of the top cowling air inlet. I have a new engine so I have to fly
at 2500 and I am pegged at 470 Fahrenheit.
I have put my oil cooler on the firewall and directed a 2 1/2" blast tube to
it. I built a mini cowl over it so that the air has to go thru it. It does
not work. My oil is at 250 F. I guess from all the talk it will have to be
moved to the rear baffling, but I was wondering if extending the blast to to
the front inlet would help. I think the firewall mount is not working
because I just can't get the air to move thru the cowling- hence the high
CHTs and OIL Temp. I also fly a LONG EZ and the cooling there was a snap,
because it goes so fast on such low power settings, but this Rebel has been
a real eye opener as far as cooling problems. I just can't believe the air
won't move thru the cowl and am probably looking at a much shorter TBO
because if I have to run at 450 F the engine ain't gonna last long. Any help
as usual will be greatly appreciated. Do I need to fair the firewall, fair
the inlets?
Date: Wed, 20 Jun 2001 20:46:25 -0400
aluminized.
engine cooling
Hi Brian !
WOW !!! Sounds like you're running at the very top limits !!
It also sounds like you must have that stupid 'speed cowl' ! NOBODY
had cooling problems with the 'standard' cowling ! You definitely
should try everything to lower your temps !!!
Does the outlet from your oil cooler face the firewall ??
If so, TURN IT it so the air flows down toward the bottom of the cowl.
Have no idea why anyone suggested having it blast against the f/w !
<I> wouldn't move my oil cooler to the back of the baffles - it
is much more vulnerable to vibration damage there.
Definitely add a fairing at the bottom of the firewall - the
lip there causes a LOT of drag on the airflow. Some builders have
seen 25 degree drops, just from rounding that off. The fairing is
just a strip of metal that starts about 3" up from the bottom, and
runs out over the lip and fastens to the outside bottom of the fuse.
Cut openings to go around mounts, etc.
The ceramic coating would be experimental for now for this
gentleman - he normally does race cars, but is willing to try an
aircraft exhaust. It would likely not be very expensive, and it
does carry the heat outside the cowl. His name is Rob Luke, and
you could reach him at : (705) 286-3682, or (705) 879-1138.
Some builders have had great results by cutting the whole
bottom out of the channel at the bottom that covers the carb, leaving
the vertical sides. They then form a large inverted channel of
aluminum, and fasten it at the front only, with a hinge. The
channel swings down at the back to help extract the air, and is
controled by a cable from the cockpit. This gives a very effective
cowl flap. It can be improved (as can the speed cowl) by adding
a 2" lip at the back bottom, at a fairly sharp angle - more than
45 degrees.
Do you have a rubber sleeve enclosing the front of the
air cleaner to the front of the cowl ? If not, air coming in here
will reverse-pressurize the cowl, killing cooling.
If your engine isn't broken in yet, just go up and fly wide-
open for a couple of hours. Once the rings seat, you should see a
drop of 20 degrees or more....
Keep working on it - it will definitely extend your
engine life !
the inlets?
aluminized.
A G Yeoman
engine cooling
Post by A G Yeoman » Sat Feb 18, 2012 12:02 am
I don't seem to have any of the cooling problems with my 'Speed cowled'
0-320 rebel,
My left rear cylinder runs at 330 deg F consistently with oil at about
180-210Deg C. depending on the day, I had to put a plate partly over the
intake of the oil cooler because it was running too cold, I can still leave
that on in summer.
The oil cooler is mounted on the left firewall and ducted with 3" tube.
I measured the intake of the cowl and cut the outlet approximately 1 1/2
times the size - and that's all.
My motor is quite high time so maybe the clearances are so big there is no
friction to generate heat :) :) !!
Alister
Sent: Saturday, June 23, 2001 3:08 AM
problems.
it
helped
fly
been
help
the inlets?
aluminized.
have
SWSLOANLK
engine cooling
Post by SWSLOANLK » Sat Feb 18, 2012 12:02 am
Sorry about your cooling problems. I have not had any cooling problems with
the speed cowling and my Cont. IO240, but just the opposite, the engine runs
to cool. On the ground taxing i typ. see 200 to 225 deg F CHT. In flight at
cruise i see 300 to 325deg F CHT with the oil temp at 180 to 190 deg F. The
highest temp. i have ever seen was 395 deg F CHT, with the oil temp. at 210
deg F at the end of a full power climb from sea level to 10500 ft on a 85 deg
F day at 75 mph IAS.
I have made two changes to the speed cowl, first i closed up the exit air one
inch and added a cowl flap to close the exit air a additional inch. the cowl
flap in the closed position is about one inch from the bottom of the
fuselage. The second change is the propeller was moved forward 1 1/2 in and
the engine induction air is pulled from inside the cowl (approx 160 CFM at
take off power.)
I for one like the speed cowl and as for maintance it takes me the same
amount of time to remove or install as my 182 Skylane.
Steve Sloan 536R
engine cooling
Hi Steve !
Of course ! Your speed cowl is DIFFERENT from the Lycoming
version. The cowl for the IO-240 is a completely different animal.
-------------------------------ORIG.-----------------------------------------
take off power.)
Steve Sloan 536R
