Bruce
I believe Wal Mart is the supplier of choice for the imported bent stem
tubes if you are using the 600 tires but as you have already seen the
quality of these tubes seems to be less than stellar...
I had a problem with one of my original tubes but I think it was because
it was for the 800 tires and they were folded or wrinkled in the 600
tires. Upon removal I found the tube cracked at the wrinkle.
OTOH for about cdn$10. at Wally Mart, one can afford to keep a spare I
guess.
There are tire and tube discussions in the archives as well.
tire tubes
rebelair
tire tubes
Hi Ken
Are you kidding about WalMart? I never thought of going there for that. I
also had trouble sourcing those tubes with the bent stems. Thanks for the
thought.
Brian #328R
klehman@albedo.net
Sent: Tuesday, June 05, 2001 4:47 PM
Subject: tire tubes
Bruce
guess.
murphy-rebel mailing list.
thought.
Brian #328R
klehman@albedo.net
Subject: tire tubes
Bruce
guess.
tire tubes
Brian, also you local Goodyear dealer, or tire shop. That is were I go to
get new tubes/tires for the amphibs Cheng Chin tires (fronts and mains),
UTVA tail wheel tubes, etc. The tubes they stock just about all have the 90*
stems.
Blue skies,
Sent: Saturday, June 09, 2001 11:28 PM
Subject: RE: tire tubes
stems.
Blue skies,
IHi Ken
*-------------------------------------------------------------------------*also had trouble sourcing those tubes with the bent stems. Thanks for the
thought.
Brian #328R
klehman@albedo.net
Subject: tire tubes
*-------------------------------------------------------------------------*Bruce
guess.
klehman
tire tubes
Absolutely.
I can't seem to find the size but it was listed oddly on the package,
possibly as a 15 cm. tube which would cross to 6". (2.54 cm to the
inch)
inch)
rebelair wrote:
Hi Ken
thought.
rebelair
tire tubes
HI Wayne
Thanks for your thoughts. Sorry you could not make the meeting today. We
had a good turn out.
Brian #328R
Sent: Saturday, June 09, 2001 11:54 PM
Subject: Re: tire tubes
stems.
Blue skies,
Brian #328R
stems.
Blue skies,
IHi Ken
thought.
Brian #328R
klehman@albedo.net
Subject: tire tubes
guess.
rebelair
tire tubes
HI Ken
Thanks again. Nice to see you again today. Still owe you a ride. Should
try to link up over the summer.
Brian #328R
klehman@albedo.net
Sent: Sunday, June 10, 2001 11:11 AM
Absolutely.
inch)
Brian #328R
klehman@albedo.net
Absolutely.
inch)
rebelair wrote:
IHi Ken
thought.
tire tubes
Brian, I did have it in the back of my mind to jump in one of the Rebels and
make the meeting for 1 PM. I had started cleaning some bird nests out of the
two UTVA's GSO-480 engines at 9 am, figuring I would get that done and then
head down to Brampton in the Amphib. Unfortunately I spent 6 hours sitting
on a ladder, with a vacuum cleaner and a small hooked wire, pulling all the
twigs etc up out of the cooling fins and I have the bright red back to prove
it! (should have listened to Leah and put my shirt back on earlier!). Next
time I think I will just have a controlled burn fire, to get the stuff out
of there!
Maybe next meeting I can make it, to sell some parts and shoot the --it. I
still haven't seen you aircraft either!!!
Take care,
Sent: Sunday, June 10, 2001 11:30 PM
of there!
Take care,
*-------------------------------------------------------------------------*HI Wayne
Brian #328R
90*Brian, also you local Goodyear dealer, or tire shop. That is were I go to
*-------------------------------------------------------------------------*stems.
Blue skies,
theIHi Ken
Are you kidding about WalMart? I never thought of going there for that.also had trouble sourcing those tubes with the bent stems. Thanks for
*-------------------------------------------------------------------------*thought.
Brian #328R
klehman@albedo.net
Subject: tire tubes
guess.
list-server@dcsol.comYou have received this message because you have subscribed to the
*-------------------------------------------------------------------------*with "unsubscribe murphy-rebel" in the body of the message.
