If anyone is looking for a 912 for their Rebel or other kit I"m looking at the possibility of going to a 912S since I'm on floats and could use the extra H.P.
My 912 was a certified engine that came out of a Katana from Diamond aircraft and was pulled for overhaul about two years ago at 950 hours TT and was re-registered U/L for my purposes. I have the original logs and less than 150 hours SMHO. The engine was overhauled by Rotech Research in B.C.
I will consider any serious offers.
Aurele Lavigne
Rebel 063
912 engine
912 engine
Hi Aurele !
I just learned that Rotech have some overhauled 912S's for sale
- maybe you could trade yours in to them ....
---------------------------------orig.-------------------------------------
At 10:14 PM 6/2/01 -0700, you wrote:
extra H.P.
the possibility of going to a 912S since I'm on floats and could use theIf anyone is looking for a 912 for their Rebel or other kit I"m looking at
extra H.P.
aircraft and was pulled for overhaul about two years ago at 950 hours TT andMy 912 was a certified engine that came out of a Katana from Diamond
floatsI will consider any serious offers.
Aurele Lavigne
Rebel 063
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2614.3500" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>If anyone is looking for a 912 for their Rebel or
Rotechand could use the extra H.P.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>My 912 was a certified engine that came out
Research in B.C.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>I will consider any serious offers.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>Aurele Lavigne</FONT></DIV>
<DIV><FONT face=Arial size=2>Rebel 063</FONT></DIV></BODY></HTML>
Aurele Lavigne
912 engine
Bob, I spoke Gerry and they did'nt appear to be interested in a trade. I
sure would appreciate it if you gave it a try, maybe you have a better
chance.
By the way, what's your opinion on the performance difference? Do you know
waht my 912 is worth on the market, say a low and a high range.
Thanks, Aurele
I have just finished installing my stainless exhaust, went straight pipe
since I could't use the four in one muffler due to my radiator position in
the cowling. A little loud but seems to run fine. Also just installed the
Ivo, 3 -blade inflight adjustable but no real chance to try it out. A friend
with a Kitfox 1V and 912 setup reports significant take-off improvement with
some increase in cruise also.
Sent: Sunday, June 03, 2001 9:49 AM
Subject: Re: 912 engine
chance.
Thanks, Aurele
-Hi Aurele !
atAt 10:14 PM 6/2/01 -0700, you wrote:If anyone is looking for a 912 for their Rebel or other kit I"m looking
andthe possibility of going to a 912S since I'm on floats and could use the
extra H.P.aircraft and was pulled for overhaul about two years ago at 950 hours TTMy 912 was a certified engine that came out of a Katana from Diamond
Rebel orwas re-registered U/L for my purposes. I have the original logs and less
than 150 hours SMHO. The engine was overhauled by Rotech Research in B.C.I will consider any serious offers.
Aurele Lavigne
Rebel 063
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
came outfloatsother kit I"m looking at the possibility of going to a 912S since I'm onand could use the extra H.P.</FONT></DIV>
<DIV> </DIV>
yearsof a Katana from Diamond aircraft and was pulled for overhaul about two
offers.</FONT></DIV>Rotechago at 950 hours TT and was re-registered U/L for my purposes. I have the
original logs and less than 150 hours SMHO. The engine was overhauled byResearch in B.C.</FONT></DIV>
<DIV> </DIV>
*-------------------------------------------------------------------------*<DIV> </DIV>
murphy-rebel mailing list.
912 engine
Hi Aurele !
I doubt I'd have more luck with them - guess you'll have to
put an ad in COPA. Not sure of pricing - I've seen them from $6,000
to $13,500, with different hours, though.
I think you'll be amazed at the improvement in performance,
but you must use the 912-S mufflers AND intakes to get the power,
even if you have to move the radiator, although it should fit ....
(Those straight pipes are likely costing you at least 4-6 hp, over
the 4-into-1 muffler !!)
The prop should help quite a bit - keep us posted !
-----------------------------------orig.------------------------------------
chance.
Thanks, Aurele
*-------------------------------------------------------------------------**-------------------------------------------------------------------------*The list archives are located at:
-Hi Aurele !
---------------------------------orig.------------------------------------atAt 10:14 PM 6/2/01 -0700, you wrote:If anyone is looking for a 912 for their Rebel or other kit I"m lookingandthe possibility of going to a 912S since I'm on floats and could use the
extra H.P.aircraft and was pulled for overhaul about two years ago at 950 hours TTMy 912 was a certified engine that came out of a Katana from DiamondRebel orwas re-registered U/L for my purposes. I have the original logs and less
Aurele Lavigne
Rebel 063
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=Arial size=2>If anyone is looking for a 912 for theircame outfloatsother kit I"m looking at the possibility of going to a 912S since I'm onand could use the extra H.P.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>My 912 was a certified engine thatyearsof a Katana from Diamond aircraft and was pulled for overhaul about twooffers.</FONT></DIV>Rotechago at 950 hours TT and was re-registered U/L for my purposes. I have the
<DIV> </DIV>
<DIV><FONT face=Arial size=2>I will consider any serious*-------------------------------------------------------------------------*<DIV> </DIV>
