Received: from MMoreho699@aol.com
by imo30.mx.aol.com (IMOv14_b1.1) id EFZDa26167
for <murphy-rebel@dcsol.com>; Tue, 21 Jul 1998 02:08:55 -0400 (EDT)
Message-ID: <74ef3e52.35b43078@aol.com>
Date: Tue, 21 Jul 1998 02:08:55 EDT
Mime-Version: 1.0
Subject: EA81 vs Rotax 912
X-Mailer: AOL for Macintosh sub 161
Hello!
I believe Bobp suggested the Subaru EA81 was 80 hp and weighed twice as much
as the Rotax. My figures show about 220 vs. 170. Also is this 80hp for stock
cams? Using the worse case scenario (80hp) I get 50# less useful load, which
to my eyes doesn't sound like it is under powered.
Comments?
Dan
R280
EA81 vs Rotax 912
EA81 vs Rotax 912
Received: from [204.191.150.191] (helo=ts18-16.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0yyl6X-00019m-00; Tue, 21 Jul 1998 18:41:53 -0400
Mime-Version: 1.0
Subject: Re: EA81 vs Rotax 912
Message-Id: <E0yyl6X-00019m-00@mail2.toronto.istar.net>
Date: Tue, 21 Jul 1998 18:41:53 -0400
My Rotax manual says the 912 weighs 128 lb. complete. Subaru weights
vary depending on the converter... (most seem to weigh MORE than claimed
by the time they get installed.)
The EA-81 is no longer in production, and parts will become more
scarce as time goes on. There are many claims as to the horsepower of
modified EA-81's - buyer beware !! (I believe the stock hp is in the 60's)
In any case, you are completely ON YOUR OWN for engine mounts, cowling
radiators, wiring, and plumbing. This is a FORMIDABLE JOB for an
EXPERIENCED BUILDER, and not to be undertaken lightly. This is why the
Murphy factory does NOT recommend you try to use the EA-81. You can't
expect them to answer ANY questions regarding YOUR custom installation.
(Don't forget, your prop will likely turn the opposite direction to the
factory supported engines, as well as at a much different speed - this
may effect fin offset, ground handling, and flight characteristics.)
If you go with any auto conversion, be prepared to spend the best
part of ONE EXTRA YEAR working on engine-related details, as mentioned
above, PLUS fiddling with different cowling entry & exit holes, oil
coolers, radiators, propellers, spinners, etc. , etc. ....
........bobp
----------------------------------orig.----------------------------------
Mime-Version: 1.0
........bobp
muchHello!
stockas the Rotax. My figures show about 220 vs. 170. Also is this 80hp for
whichcams? Using the worse case scenario (80hp) I get 50# less useful load,
Comments?
Dan
R280
EA81 vs Rotax 912
Received: from chk1a10.dial.uniserve.ca [204.244.143.105]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0z0wTN-0005AZ-00; Mon, 27 Jul 1998 16:14:29 -0700
Message-Id: <2.2.16.19980727160659.37e7417a@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Date: Mon, 27 Jul 1998 16:14:29 -0700
At 06:41 PM 7/21/98 -0400, you wrote:
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Mime-Version: 1.0
muchMy Rotax manual says the 912 weighs 128 lb. complete. Subaru weights
........bobp
At 02:08 AM 7/21/98 EDT, you wrote:Hello!
Murphy Aircraft Mfg. Ltd.to my eyes doesn't sound like it is under powered.
Comments? No Comment!
Dan
R280
Ph: 1-604-792-5855
Fax: 1-604-792-7006
