Prop
BILNEWKIRK
Prop
Post by BILNEWKIRK » Fri Feb 17, 2012 11:48 pm
Guy Lamarche,
In case I screwed up my e-mail to you, the prop went UPS today.
Bill N
Peter Cowan/Lexi Cameron
prop
Post by Peter Cowan/Lexi Cameron » Sat Feb 18, 2012 12:22 am
Anyone have an 80x 45 or larger prop (wood or metal) you want to sell, trade (have a couple of 75x 56 and 60 metal), or rent?
Peter
Legeorgen
prop
Post by Legeorgen » Sat Feb 18, 2012 12:22 am
Peter,
Are you planning on putting an 80" prop on the Rebel?
prop
Peter,
If possible, eventually, yes. Right now I am working with a Mazda rotary
installed and flying in another airframe with a view to putting it or a
similar one in a Rebel. I am linked up with a fellow who has the airframe
mostly done. My contribution will be to finish it and install the engine.
Peter.
Legeorgen
prop
Peter,
There is an outfit in Washington that re-engines super Cubs with with 0360
and 0320's. The're putting on Sensenich 80" certified props with great
results. The owners really love them. I checked my Rebel and would need 8.50
tires in place of the 8.00 to gain the extra 3 or 4 inches of the required 9"
clearance with ground. What have you found in this regard?
Bruce G
prop
Peter,
8.50
9"
Bruce G
My main interest is for float use so aside from spray considerations I think
the length would not be a problem.
Peter.
Murray and Carol Cherkas
prop
Post by Murray and Carol Cherkas » Sat Feb 18, 2012 1:46 am
Hello All
Yes, I finally put laid down my hard earned cash for an 0-320 A2B 160hp.
I am now looking for a prop. If anyone has any info on a Sesenich 74" x 56
pitch, please let me know. I may consider an Ivo prop also.
Murray Cherkas
REBEL 505
If all goes well I may just be ready to join the REBEL RAMBLE for a portion
of the trip.
edderd
prop
Post by edderd » Sat Feb 18, 2012 1:46 am
With the 160 hp why not go with a 74 x 58, an enjoy the 128 mph cruse. It
will still out climes most of the other aircraft at the airport. I use a
wooden Sensenich W74EM-58. I also know Roland uses a Sensenich 74 x 58
Metal prop on his Rebel and gets the same results. By the way my pretty wood
prop cost $735.00 us new. R109 Edwin...
Sent: Sunday, February 09, 2003 3:34 PM
Subject: prop
Hello All
Murray Cherkas
REBEL 505
portion
of the trip.
Dale Kopff
prop
Post by Dale Kopff » Sat Feb 18, 2012 2:02 am
Does anyone know of a used Sensenich 74-56 prop for sale?
I would like to check the difference between it and the Prince prop.
Dale
N295RT
prop
Post by Murray and Carol Cherkas » Sat Feb 18, 2012 2:02 am
Dale; Call Gary at MGK AERO (204) 324-6088. I bought my 74" x 58 pitch from
him. Looks like new.
Good Luck
Murray
Dale Kopff
Sent: Thursday, May 08, 2003 5:17 AM
Subject: prop
Dale
N295RT
LisaFly99
PROP
Post by LisaFly99 » Sat Feb 18, 2012 2:08 am
In a message dated 5/16/03 7:12:06 AM Central Daylight Time,
micreb@bellsouth.net writes:
A friend in Argentina did a nice job putting together a 76 X 58 wood prop
with a three-piece nickel leading edge and four layers of glass. Anyone
flying a Subaru with a Ross PSRU that wants a prop custom made for that
combination,
PAUL
What ever happened to the prop deal you where trying to put together?
Phil&Lisa Smith
#460R
N414D
Paul Michel
PROP
Post by Paul Michel » Sat Feb 18, 2012 2:08 am
Phil:
I forwarded both yours and Mikes emails to Deigo. He was given your email
addresses and hopefully will contact you soon. I'm headed for Santiago
tonite. I will email him on Tuesday to rattle his cage and see what's up.
No excuses but the guy is really busy. Just had his second kid, is moving
the wood prop shop and is Chief Inspector for his Dad's metal Prop Shop.
Mike....did he contact you?
Paul
Sent: Sunday, June 01, 2003 11:46 PM
Subject: Re: PROP
prop
combination,
PAUL
Phil&Lisa Smith
#460R
N414D
PROP
Post by Mike Davis » Sat Feb 18, 2012 2:08 am
I haven't contacted him directly... just the one e-mail I sent to you off
list.
Sent: Monday, June 02, 2003 1:19 PM
Subject: Re: PROP
Phil:
Paul
Subject: Re: PROP
prop
Anyone
that
combination,
PAUL
Phil&Lisa Smith
#460R
N414D
Dale Kopff
prop
Post by Dale Kopff » Sat Feb 18, 2012 11:52 am
I want to sell my Sensenich 74-56 prop with only two hours since overhaul.
The hub is 7/16 bolt pattern.
$1,300.00 U.S. Dale Kopff, 573-3484873
Murray Cherkas
prop
Post by Murray Cherkas » Sat Feb 18, 2012 11:52 am
Dale:
What are you using in place of the Sensenich. I have a 74"x58 pitch right
now with a 160 hp.
I'm going to pitch it to 60 maybe even 62. I would like a little faster
cruise at the expense of take off and climb performance.Takes off like a
jack rabbit with a kick in the ass anyway.
29 hrs. and really starting to get the feel of it. Doing touch and goes, I
have taken off from a three point position. Gotta keep the nose down to get
a little speed before climb. This takes about 2 seconds. Bob says ,"it just
keeps getting better".
Good luck selling your prop.
Murray
Dale Kopff
Sent: Monday, January 19, 2004 8:17 AM
Subject: prop
