[rebel-builders] threaded pushrod ends
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:55 pm
Big tube or small Roland... I'll have a look tomorrow.
Sent: Monday, September 26, 2011 9:19 PM
Subject: [rebel-builders] threaded pushrod ends
Does anyone know where I can get a couple of the threaded pushrod ends.
Looking for the piece that you rivet into the pushrod tube. the ones at
ACS
are not a good fit.
Roland
R56
streetpilot
Post by streetpilot » Sun Feb 19, 2012 11:55 pm
On 9/26/2011 5:23 PM, oifa@irishfield.on.ca wrote to rebel-builders:
tube is marked .75 X .35
inside measurement is 11/16
Roland
R56
Okay.. the smaller one. The large one is the one that goes from stick
bellcrank to mixer arm. I'll have a look in the morning.. heck.. I'll go
look now !
Sent: Monday, September 26, 2011 9:51 PM
Subject: Re: [rebel-builders] threaded pushrod ends
Roland
R56
Sorry Roland... as soon as I opened my parts filing cabinet, with such
beasts in it, I rememeber that every one I had went into a wreck rebuild a
winter ago. It had totally trashed the tail section and both push pulls in
the rear and I used the 4 new ends I had to make new push pulls. Now if I
could remember where I put the broken ones.. I can probably drill those off
and send you those.
Roland
R56
Dan Pare
Post by Dan Pare » Sun Feb 19, 2012 11:55 pm
Wayne just wondering if you sell spring loaded door latches wood like some for the windows
Date: Mon, 26 Sep 2011 21:56:10 -0400
look now !
Roland
R56
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 11:55 pm
Thanks Wayne, don't look too hard. I inadvertently drilled on the of the
tubes to accept the larger rivets (5604?). I haven't checked to see if I can
get shorter rivets yet, but the ones I have interfere with each other in the
tube. Obviously wasn't thinking when I did it... one of those "oh sh_t"
moments.
Roland
R56
G. O'Shea
Sent: Monday, September 26, 2011 10:16 PM
and send you those.
Roland
R56
Dan Pare
I need the one for the window on both sides
Subject: RE: [rebel-builders] threaded pushrod ends
Date: Tue, 27 Sep 2011 07:52:59 -0400
look now !
Roland
R56
