Read with interest re: engines. I found myself in a very similar
situation and like you I have looked into a number of different engine
options. You mention that Murphy would like to see everyone upgrade the
gross if they use the M-14P. Speaking with Bob Patterson he had mentioned
that you can use the engine and not do the upgrade except that you have to
watch your speeds and weight. (Personally I think this scenario can get you
in trouble). Like yourself I didn't want to pay a fortune for an engine and
even though I wanted the M-14 I didn't want to open up my wings again. What
I have purchased is the M-462 which is very similar to the M-14 only not
certified for inverted flight, has a different prop govenor and is rated at
315hp. As well it comes with a overhauled constant speed all metal prop
(V-520) (the Russian M-14 comes with a wooden prop with metal leading edges)
and new exhaust. Cost about 10,500 US exclusive shipping. You would still
need all the other accessories as with the M-14 but hopefully Murphy will be
making a firewall forward kit available. I did post some information to the
list earlier on this engine however let me know if you want some more
information .
Rob Helt
To: <agt@mosquitonet.com>
Sent: Monday, January 15, 2001 10:23 PM
Subject: RE: Engine Mount Fabrication
continuous.The complete LS-1 engine installation, including all accessories, is 490
lbs. It's rated at 350HP@5500rpm for takeoff and 300HP@4250rpm
suitableThat compares favorably to the M14P which allows 360HP for takeoff, but
lists cruise HP at only 200HP. Of course, the M14P only has to turn less
than 3000rpm for that, which is a huge advantage. The other engine of
interest is the Suburu from Crossflow in Ontario. They have three
andengine models ranging from 250HP to 320HP. Two of the three models are
turbocharged, which should be an advantage for high altitude operation.
Interestingly, the 300HP turbocharged model lists a fuel burn of 10.2gph
6050rpmthe 320HP high output engine lists 9.1gph. Also, the high output model
apparently gets the extra 20HP from rpm. It's rated 320HP occurs at
aversus the 300HP model at 5600rpm. The huge advantage of the Crossflow
engine is that they provide a firewall forward package, including engine
mount, radiators, and other stuff that would be a challenge to engineer
myself. But the scary thing about auto engine conversions for me is high
continuous rpm. At least the LS-1 has two extra cylinders and turns quite
cylindersbit slower than the Suburu. I've had more than one experience of
projectfailing for one reason or another on auto V8s and the engine keeps running
anyway.
I would dearly love to use the M14P, but Murphy is adamant about doing the
gross weight upgrade if the M14P is to be used. I have a lot of my
tocompleted already so that would mean tearing into parts that I don't want
exploringtear into, such as the sealed and tested wing tank. So off I go,
myother engine options. One thing for sure, I can't afford a $40,000 (or
more) Lycoming and I don't want to keep paying ridiculous prices for parts
to maintain it.
Sent: Wednesday, January 10, 2001 3:32 PM
Subject: Re: Engine Mount Fabrication
Hi Mike !
I'm sure the Murphy Tech. Dept. can supply all the needed
measurements - thrust line position, offset, etc. .... They have
done this for the Rebel for several builders.
How heavy is that complete installation, compared to an O-540 ??
How many HP. ?? Perhaps NWA can supply some info on the mounts
others are using ...
---------------------------------orig.---------------------------------
At 11:50 AM 1/10/01 -0900, you wrote:I am interested in using the Northwest-Aero Chevy LS-1 V8 conversion on
*---------------------------------------------------------------------------placeSuper Rebel. Does anyone have information about the positioning of the
center of thrust (i.e., prop hub location, how the prop shaft is angled,
whatever). I have heard things like 19 inches up from the bottom of the
firewall and angled such that the center of thrust passes through somebeginon the tail. Stuff like that. I have also heard that it is easier toofby suspending the engine from the ceiling over the firewall (or a mock upmountthe firewall). Any other tips or advice on how to fabricate an engine*--------------------------------------------------------------------------from scratch?
---------**--------------------------------------------------------------------------Contributors' page at:
Visit the book store at:
*---------------------------------------------------------------------------Contributors' page at:
