restored and modified Rebel
karl hipp
Post by karl hipp » Sun Feb 19, 2012 11:41 pm
fellow rebel builders
Here is a link to some pics of my Rebel. It was built in 1996 but had
not flown since 2003. I bought it last spring and brought it home on a
trailer.
It has a 160 HP Subaru engine and Warp Drive prop.
The original wheel on the left "broke" while I was taxiing on rough
ground and it jammed and the plane flipped on it's back.--before I even
flew it-- Bob Patterson told me then that the running gear I had was "recalled"
--apparently go kart stuff--really way too lightweight--
I used front running gear from a Kawasaki Brute Force 4 wheeler. Some machining to make bearing housings
and modification of the axle housing and some welding. The rims are aluminum 4 wheeler rims
Farm implement tires that cost about $60 each. I had the tread
machined off by a local re-capping company. This is way cheaper than Alaska Bush tires and you have a heavier
duty system including the brakes.
A few panels got wrinkled in the flipover so I incorporated some mods while replacing them. I added
VG's. The aluminum tailspring had been bent straight by the previous owner
due to a hard tail landing. When I put it in a press to rebend it I found it had no "spring"
so I made a spring from some trailer springs. It now has good bounce to fix landing "mistakes"
I also could not stand the door setup--it seemed I was always "fighting"
the door while getting in the airplane. I like the flip up conversion much better. Thats the way the kits should be
produced in my opinion.
I like to fly with doors open as I used to do in Kitfox I once had but there is too much
buffeting with the Rebel. I installed a solid bulkhead per Bob Pattersons suggestion and it did help some
http://www.flickr.com/photos/59852993@N02/
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
karl hipp
trailer.
cut and paste
flickr.com/photos/59852993@NO2
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
karl hipp
My Rebel was built in 1996 but had not flown since 2003. I bought it last spring and brought it home on a
trailer.
The original wheel on the left "broke" while I was practicing taxiing on rough
I have some photos on the flickr website or I can send them to anyone
interested
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
khipp@99victor.com
bransom
Post by bransom » Sun Feb 19, 2012 11:41 pm
Karl ...Good to hear of all your practical and innovative solutions.
Thanks for posting!
-Ben 496R
On 2/23/2011 6:25 AM, khipp@99victor.com wrote to rebel-builders:
trailer.
was "recalled"
had no "spring"
landing "mistakes"
is too much
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
