34.5 * 933 for mains = 32188 in-lbs
-72 * 291 for front = -20952 in-lbs
add those together to get 11236 in-lbs
divide 11236 by 1224 lb empty weight to get 9.18 inches aft
I'd probably leave the battery where it is or if it is not bolted down
yet perhaps move it forward a little to the first convenient place to
mount it.
I have examples of forward limits and rearward limits at 1730 lb gross
if you need them.
On 2/13/2011 9:24 PM, Wayne G. O'Shea wrote:
9.18 empty c of g.. bolt the sucker down, fill the tanks and go flying!
From: "Rebecca Brownell"<brownell@cottagecountry.net>
To:<rebel-builders@dcsol.com>
Sent: Sunday, February 13, 2011 9:17 PM
Subject: Re: [rebel-builders] Question of Rebel Datum location/ Cof G range
Lets give it a go.Here's the numbers;Right rear 476 left rear 457
fronts together 291
34.5'' from mains to door post
72'' from fronts to door post
Total weight 1224
total weight on mains 933
Battery is now at 106 aft of door post
battery weighs 15.5 lbs
It will need to come ahead but by how much?
On 13-Feb-11, at 9:03 PM, Ken wrote:
