[rebel-builders] Question of Rebel Datum location/ Cof G ran
[rebel-builders] Question of Rebel Datum location/ Cof G range
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:35 pm
Gary.. the axle center line is not ahead of the leading edge! It is indeed
AFT of the wing leading edge.
Sent: Saturday, February 12, 2011 6:56 PM
Subject: RE: [rebel-builders] Fwd: Murphy Rebel baffles
I just finished re-measuring and weighing N52GG this past
weekend and after doing so, I decided to look at W&B emails
in the Murphy Rebel builders section. I came across the
following email which now bothers me from several days ago.
______________________________________________
On Date: 2/3/2011 4:33 PM the following email was posted by
Charlie E
Jesse
A couple years back I asked a similar question to MAM.
The answer I got from Darryl Murphy was:
Hello Charlie
I think the confusion is that the data point (center of axle)
is approximately 1.15" aft of the leading edge. 20% of 60" = 12",
12" - 1.15" = 10.85" A.O.D. (aft of datum).
Hope this helps.
Cheers Darryl"
The concern is that is 1.25" ahead of the leading edge of
the wing, not 1.15" aft of the leading edge. That is a difference
of 2.45". WOW. I had 2 certified aircraft mechanics doing the
measurements and they were done twice with almost (less than .2")
when the other person did his measurements. So did Darryl make a
mistake in his response??? My plane was built to the manual so
I do not understand that there could be that much difference.
Anyway this should promote an interesting discussion.
Gary G
