[rebel-builders] Rebel limmitations
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 11:35 pm
I do not believe that the FAA wants Va placarded these days, but that
is up to the individual examiner. There are some peculiarities that
individual examiners have and will create a punch list of minor things
to change before first flight. Mine had some odd items, but I did them
with laughs of hanger mates, recorded in log and then had my Rebel
flown for first time.
For what it is worth, I think the V speeds are as follows:
Va - Cruise speed - 110 mph
Vno - normal operating speed - 120 mph
Vfe - Full flaps extended speed - 80 mph
If not, someone correct.
Jenks
Sent: Tuesday, February 01, 2011 9:59 PM
To: Builders list
Subject: [rebel-builders] Rebel limmitations
I have my airworthiness inspection in less than 2 weeks and trying to scrape
together the required documentation to make the examiner happy. I can't find
Va, Vno, or Vfe.
can anyone help? I hear the FAA wants Va to be placarded these days
thanks.
Jesse
Subject: Re: [rebel-builders] First Flight # 719
Date: Tue, 1 Feb 2011 19:12:28 -0500
Like they say... you always remember your first !!!
Congrats!
Sent: Tuesday, February 01, 2011 7:10 PM
Congrats Rusty!! Must have been a great feeling/ Gotta pull more
rivets!
Sent: Tuesday, February 01, 2011 3:46 PM
Subject: [rebel-builders] First Flight # 719
Murphy Rebel N547A SER# 719 took to the air for first time . Liftoff
at
about 600 ft on the grass, I held it down a little for the airspeed to
come alive,more on that later. Aircraft seems to levitate rather than
rotate. Clime rate seems normal for this power ,LYC O-235 and wing
loading. Controls are VERY light with little feedback but are not
twitchy
and no tendency to over control. Very stable at cruise but seems to
have
neutral stability on this short flight. All engine ops normal ranges.
All
pitot and static instruments seem to wander quit a bit and could not be
trusted so more testing, and experimenting will be necessary. Landing
was
accomplished with no problems at KPLR after 33min of flight with use of
lift reserve indicator for airspeed control . Many THANKS to ALL my
aviation Buddies without which this project would not have been so much
fun. Many THANKS to the frequent posters of REBEL BUILDERS whose
experience kept the project rolling. Special thanks to Cris who !
got this ad
venture started.
Video of first flight http://www.youtube.com/watch?v=6aQMkiaM8uI
Aircraft description
Lyc O235C1
Culver 74X46 Prop (too much pitch, Max RPM 2375)
Grumman Yankee exhaust (very Quite)
B&C 8amp alternator
sky tec starter (Dick Waters supplies)
Odyssey 680 Battery
UMA steam gages
Garmin 296GPS/Docket mount
Icom 210a comm
Lift Reserve Indicator (very handy when airspeed ind inop)
Firgelli electric flap actuator
Second and third flights not nearly so exicing. GREAT plane, FUN to
fly.
Static system problem improved by sealing original static ports and
relocating 1/16th in. holes 2 in. from tip of STD MAM probe.
Performance
tests ongoing, so far follow MAM data.
Keep on pulling those rivets Thanks
Rusty
Post by Drew Dalgleish » Sun Feb 19, 2012 11:35 pm
I have the murphy pilots manual here in front of me and it says
never exceed Vne 131kts - 151mph
do not exceed
maximum structural cruising Vno or Vc 110kts - 125mph do not
exceed except in smooth air
maneuvering Va 95kts - 110 mph
no full or abrupt control movements above this speed
max flap ext. Vf or Nfe 70kts - 80mph
no flaps above this speed
Jenks
To: Builders list
Va, Vno, or Vfe.
thanks.
Jesse
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:35 pm
thanks Drew and Gary,
I forgot about the flight manual that is on cd. All the stuff is in there. I have so many things in my brain right now trying to get this thing airworthy that I can't keep things straight.
Jesse
Date: Tue, 1 Feb 2011 22:42:18 -0500
Subject: Re: [rebel-builders] Rebel limmitations
do not exceed
Jenks
To: Builders list
Va, Vno, or Vfe.
thanks.
Jesse
