[rebel-builders] Dynon remote compass location
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:35 pm
Hi Jesse
I ended up installing mine behind the cabin about 3 feet into the tailcone
after discovering the magnets in my headset were making the compass turn as
I moved my head... brain bending when I first saw it !!!
Nig
745E
Jenks
Sent: 17 January 2011 19:25
To: Builders list
Subject: [rebel-builders] Dynon remote compass location
What is the best (easiest that works well) location for the Dynon remote
compass? Eric, are you here? I was thinking on the ceiling behind one of the
bulkheads in the baggage area, or possibly right above the pilot's head next
to the torque tube support. Not sure just how isolated or far away from
ferrous stuff this thing really needs to be.
Thanks.
Jesse
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:35 pm
Behind the baggage wall, up near the ceiling is where I put my magnetometers
too. (Search http://n254mr.com for "magnetometer" for several pics) As I
recall the mfgr. manual wanted 30" from any ferrous material. I think that's
a little overkill, but where I put them was about as far away from anything
ferrous as I could get them, and relatively easy to align with the
centerline, etc. Research at the time raised concerns about being near a
swarm of steel rivet mandrels in the area, but that has proved to be not a
problem.
Ron
Ron Shannon
Incidentally, the photos at http://n254mr.com/node/922 remind me the
magnetometers are Crossbow brand. Although these were supplied by AFS for
their EFIS's, I wouldn't be surprised if Dynon uses the same ones.
Of course, you want to use only brass or stainless hardware in the mounts.
Ron
magnetometers too. (Search http://n254mr.com for "magnetometer" for
several pics) As I recall the mfgr. manual wanted 30" from any ferrous
material. I think that's a little overkill, but where I put them was about
as far away from anything ferrous as I could get them, and relatively easy
to align with the centerline, etc. Research at the time raised concerns
about being near a swarm of steel rivet mandrels in the area, but that has
proved to be not a problem.
Ron
Jason Beall
Post by Jason Beall » Sun Feb 19, 2012 11:35 pm
Hey Ron,
Where is the AHARS in the Dynon system? Is it an external box in the tailcone, or is it integral to the display in the panel? I was debating building a shelf in the back big enough to mount both a magnetometer and an AHARS.
-Jason
--- On Mon, 1/17/11, Ron Shannon <rshannon@cruzcom.com> wrote:
Subject: Re: [rebel-builders] Dynon remote compass location
Date: Monday, January 17, 2011, 12:50 PM
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 11:35 pm
Jason (and others),
I'm putting a Dynon Skyview system in my Moose at the end of
February--working with the folks at Aerotronics in Billings, Montana to do
it with me. I'll take pictures of everything and ask any questions that you
can think of during the install. I'll post pictures to the list (well some
anyway).
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jason
Beall
Sent: Monday, January 17, 2011 3:22 PM
Hey Ron,
AHARS.
-Jason
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
Ron Shannon
Sorry Jason, I don't know specifics about the Dynon gear. I assume the data
is available on their web site though. I have dual EFIS/AHRS from Advanced
Flight Systems (AFS).
Ron
254R
On Mon, Jan 17, 2011 at 2:21 PM, Jason Beall <super_rebel131@yahoo.com>wrote:
Hey Ron,
AHARS.
-Jason
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 11:35 pm
Dynon installation manuals are very well written with all the recommended
locations spelled out. On my Dynon D100 the remote compass is mounted in the
tailcone aligned with the longitudinal and lateral axes.
N645E
Shannon
Sent: Monday, January 17, 2011 4:42 PM
Ron
254R
Hey Ron,
an
AHARS.
-Jason
B-L Pollock
Post by B-L Pollock » Sun Feb 19, 2012 11:35 pm
Ted do you have any pictures of your cabin heat box and carb heat on your
M14
Thanks Bill
Sent: Monday, January 17, 2011 5:45 PM
Subject: RE: [rebel-builders] Dynon remote compass location
Jason (and others),
you
some
anyway).
Jason
Beall
Hey Ron,
an
AHARS.
-Jason
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
craig
Post by craig » Sun Feb 19, 2012 11:35 pm
Dynon's AHARS and magnetrometer are in one box and it is to be loacated
remotely away from the panel. CW
Sent: Monday, January 17, 2011 1:21 PM
Hey Ron,
an AHARS.
-Jason
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
craig
I installed the new Dynon Skyview in my rebel. I made a tray that attaches
to one of the tailcone top bulkheads and is adjustable in the front to match
the plane's attitude. The ADHARS unit bolts in there and the static and
pitot and AOA tubing connects there.
I guess I could have put it in the area at the back where the elevator horn
is but I thought it'd get exposed to water there especially with floats.
Dynon has good manuals AND customer service. Craig
Sent: Monday, January 17, 2011 5:55 PM
Be careful using stainless in any mount or hardware in any magnetically
sensitive area. There are magnetic stainless steels.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:35 pm
Thanks for the replies guys. I guess I'll put it in the baggage area overhead. It would be nice to put it all the way back behind the aft end of the baggage area behind the fabric bulkhead that will eventually be there, but I have my battery/contactor and elt there and would worry that would cause magnetic interference. Having it in the baggage area means I will have to be careful what I load in there....
Date: Mon, 17 Jan 2011 18:49:04 -0900
Hey Ron,
an AHARS.
-Jason
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
Ron Shannon
Interesting. The add'l. requirement to get pitot/static to the same
non-magnetic place presents a different can of worms (kettle of fish?)
FWIW, with AFS gear only the magnetometers are remote. The AHRS (pitot
static, etc.) and AOA air ports are integral to the panel units. Both
brands are good systems... no argument there.
Hmm. Come to think of it, squeezing (jamming?) the pitot/static plumbing
behind my overbuilt panel wasn't easy either. ;-)
Ron
Eric Fogelin
I mounted my Dynon remote compass and ELT on the floor. Do it again, I'd
make a bracket up on the ceiling. That would leave the floor available for
skis, fishing rods, and other light and long back country gear. I located
mine to the side, has not been a problem with the camping I've done, but
easy to rivet up a support in the ceiling. Using a compass to detect
magnetic objects is good. Didn't notice anything from my ELT or support.
Picture of my setup:
http://efogelin.com/aviation/murphy/lig ... 080614_010
_large.html
Long link may need to be put back together to view.
N645E
Jenks
Sent: Monday, January 17, 2011 8:12 PM
To: Builders list
Hey Ron,
an AHARS.
-Jason
As I
away from anything
with the
being near a
proved to be not a
problem.
Ron
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 11:35 pm
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Eric
Fogelin
Sent: Monday, January 17, 2011 5:01 PM
N645E
Shannon
Ron
254R
Hey Ron,
magnetometer and
an
AHARS.
-Jason
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 11:35 pm
When we had our EFIS running on the test bench and I happened to notice
the displayed heading changing randomly by one degree, or so it seemed.
Then I remembered that I had one of those little six inch steel rulers
in my shirt pocket and the shift happened every time I sat down at the
bench. A further experiment with a small screw driver, the size for the
D connectors was able to move the heading from several inches away. Then
I tried a line of 1/8th Avex rivets in a scrap of material right up
against the mag with only a slight flicker in heading indication. We
decided to put the mags out one in each wing.
Bob.
On 1/17/2011 6:55 PM, Ralph Baker wrote:
Be careful using stainless in any mount or hardware in any magnetically sensitive area. There are magnetic stainless steels.
