[rebel-builders] Preventing Moose/SR stinger side-to-side mo
Dick Wampach
[rebel-builders] Preventing Moose/SR stinger side-to-side movement
Post by Dick Wampach » Sun Feb 19, 2012 11:34 pm
I must agree with Ted, Dale Fultz dfultz17086@embarqmail.com entire
tail stinger system is a very gooood way to go. At the forward end he uses
a rubber bushing to absorb the shock. I mounted mine using nut plates
riveted to a .032" plate to make installation and removal possible, also
added access panels below the Horizontal Stab in the tail cone area, there
are examples in the archives. Their have been a few reported problems in
that area and it will be easier to repair if/when it happens to your craft.
Does any one need an original SR-3500 Tail Stinger and mounting brackets?
Dick Wampach SR-108 N331RW
Waltman
Sent: Thursday, December 30, 2010 9:49 AM
Subject: RE: [rebel-builders] Preventing Moose/SR stinger side-to-side
movement
Use washers to insure a tight fit. You won't wear the bolt hole in the
stinger; you will, however, and almost inevitably regardless of how firm you
washer up the stinger to the FUS-360 (right # ?) mount, end up with
elongated holes in the FUS-360 holes. So while you're at it, install
nutplates/anchor nuts on the back side of each FUS-360 (right/left parts) so
it's easier to replace them later.
Or, create your own custom front stinger mount (as some have done) or buy
Dale Fultz's custom front mount.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jason
Beall
Sent: Thursday, December 30, 2010 10:21 AM
To: new list server
Subject: [rebel-builders] Preventing Moose/SR stinger side-to-side movement
Guys,
Quick question: I have a custom stinger purchased from another builder a few
years back. It's 1 inch in diameter, so there is a slight gap either side of
the stinger up in the tailcone where it mounts.
What have others done to take up this gap? I was thinking either delrin
spacers or some sort of rubber cushion. Thoughts and/or suggestions?
I can see if you don't prevent the side-to-side movement it will eventually
wear the bolt hole on the stinger.
Thanks, -Jason
