[rebel-builders] horizontal stab install
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:07 pm
I don't use a 2 x 4.. a 6 foot x 2 or 3inch wide strip of .025 or .032. that
way it will go under the fin! You end up with it a couple inches back from
the rear spar edge.. but tape it down parallel to the edge on one side and
then play and adjust to get the other side the same before setting those
front attach brackets.
http://www.irishfield.on.ca/gallery/stabset.jpg
Sent: Sunday, December 05, 2010 7:45 AM
Subject: [rebel-builders] horizontal stab install
Good morning everyone,
I've been searching through the archives in vain for a particular post
(probably
Wayne's) on the use of a 2x4 clamped to the rear spar of the horizontal
stabs as
you position the front attach brackets for drilling through the bulkhead
doubler. When I try to implement this method, I see no alternative but to
notch the 2x4 to accommodate the vertical fin. Not difficult to do,
obviously,
but I just want to check with the group if there was a 'best-practice' for
this
step.
Rob
schaumr
Post by schaumr » Sun Feb 19, 2012 11:07 pm
Thanks Wayne,
So.....you don't use anything to keep the two stabs rigidly 'connected' or
horizontal throughout the procedure?
Rob
On 12/5/2010 7:30 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> I don't use a 2 x 4.. a 6 foot x 2 or 3inch wide strip of .025 or .032. that
-> way it will go under the fin! You end up with it a couple inches back from
-> the rear spar edge.. but tape it down parallel to the edge on one side and
-> then play and adjust to get the other side the same before setting those
-> front attach brackets.
-> http://www.irishfield.on.ca/gallery/stabset.jpg
-> From: <schaumr@dcsol.com>
-> Sent: Sunday, December 05, 2010 7:45 AM
-> Subject: [rebel-builders] horizontal stab install
-> > Good morning everyone,
-> > I've been searching through the archives in vain for a particular post
-> > (probably
-> > Wayne's) on the use of a 2x4 clamped to the rear spar of the horizontal
-> > stabs as
-> > you position the front attach brackets for drilling through the bulkhead
-> > and
-> > doubler. When I try to implement this method, I see no alternative but
-> > to
-> > notch the 2x4 to accommodate the vertical fin. Not difficult to do,
-> > obviously,
-> > but I just want to check with the group if there was a 'best-practice' for
-> > this
-> > step.
-> > Thanks,
-> > Rob
For that.. I make a stack of what ever junk I have lying around and shim it
to get both of the stabs perfectly level with the smart level. In this case
a ladder and milk crates, supplimented with some SM and some thin shims.
http://www.irishfield.on.ca/gallery/stablevel.jpg
Sent: Sunday, December 05, 2010 11:37 AM
Subject: Re: [rebel-builders] horizontal stab install
Thanks Wayne,
Rob
that
from
those
post
-> > (probably
horizontal
-> > stabs as
bulkhead
-> > and
but
-> > to
-> > obviously,
'best-practice' for
-> > this
-> > step.
-> > Thanks,
-> > Rob
schaumr
Thanks Wayne....those photos help.
Rob
On 12/5/2010 7:46 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> For that.. I make a stack of what ever junk I have lying around and shim it
-> to get both of the stabs perfectly level with the smart level. In this case
-> a ladder and milk crates, supplimented with some SM and some thin shims.
-> http://www.irishfield.on.ca/gallery/stablevel.jpg
-> Sent: Sunday, December 05, 2010 11:37 AM
-> Subject: Re: [rebel-builders] horizontal stab install
-> > Thanks Wayne,
-> > So.....you don't use anything to keep the two stabs rigidly 'connected' or
-> > horizontal throughout the procedure?
-> > Rob
-> > On 12/5/2010 7:30 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> > -> I don't use a 2 x 4.. a 6 foot x 2 or 3inch wide strip of .025 or .032.
-> > that
-> > -> way it will go under the fin! You end up with it a couple inches back
-> > from
-> > -> the rear spar edge.. but tape it down parallel to the edge on one side
-> > and
-> > -> then play and adjust to get the other side the same before setting
-> > those
-> > -> front attach brackets.
-> > -> http://www.irishfield.on.ca/gallery/stabset.jpg
-> > -> ----- Original Message -----
-> > -> From: <schaumr@dcsol.com>
-> > -> To: <rebel-builders@dcsol.com>
-> > -> Sent: Sunday, December 05, 2010 7:45 AM
-> > -> Subject: [rebel-builders] horizontal stab install
-> > -> > Good morning everyone,
-> > -> > I've been searching through the archives in vain for a particular
-> > post
-> > -> > (probably
-> > -> > Wayne's) on the use of a 2x4 clamped to the rear spar of the
-> > horizontal
-> > -> > stabs as
-> > -> > you position the front attach brackets for drilling through the
-> > bulkhead
-> > -> > and
-> > -> > doubler. When I try to implement this method, I see no alternative
-> > but
-> > to
-> > -> > to
-> > -> > notch the 2x4 to accommodate the vertical fin. Not difficult to do,
-> > -> > obviously,
-> > -> > but I just want to check with the group if there was a
-> > 'best-practice' for
-> > -> > this
-> > -> > step.
-> > -> > Thanks,
-> > -> > Rob
-> > -> > List archives located at: https://mail.dcsol.com/login
-> > -> > username "rebel" password "builder"
-> > -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > -> > List administrator: mike.davis@dcsol.com
If you do it in a similar situation that I show there Rob.. be sure to slap
the level across the fus door sills for reference... so that the stabs are
parallel to it! It may not be sitting level on wheels.
Sent: Sunday, December 05, 2010 11:48 AM
Rob
shim it
case
shims.
-> > Thanks Wayne,
'connected' or
-> > Rob
.032.
-> > that
back
-> > from
side
-> > and
-> > those
particular
-> > post
-> > -> > (probably
-> > horizontal
-> > -> > stabs as
-> > bulkhead
-> > -> > and
alternative
-> > but
-> > to
-> > -> > to
do,
-> > -> > this
-> > -> > step.
-> > -> > Thanks,
-> > -> > Rob
Also keep in mind, if you haven't seen the posts, I have found over the
years that a stab incidence of 0.7 to 0.8 degrees is what is needed vs the
1.0 spelled out in the manual. At 1.0 you'll be flying with a hint of up
elevator all the time. You can see same in all my float flying videos.
Elevator tip is always down slightly compared to the stab leading edge on
mine, that is mounted at 1.0 All the ones I've built since have 0.7 or 0.8
and they seem to fly with the tip pretty much flush in cruise.
Sent: Sunday, December 05, 2010 12:01 PM
slap
Rob
shim it
case
shims.
-> > Thanks Wayne,
'connected' or
-> > Rob
.032.
-> > that
back
-> > from
side
-> > and
setting
-> > those
particular
-> > post
-> > -> > (probably
-> > horizontal
-> > -> > stabs as
-> > bulkhead
-> > -> > and
alternative
-> > but
-> > to
-> > -> > to
do,
-> > -> > this
-> > -> > step.
-> > -> > Thanks,
-> > -> > Rob
schaumr
Thanks for the reminder Wayne.
Rob
On 12/5/2010 8:05 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Also keep in mind, if you haven't seen the posts, I have found over the
-> years that a stab incidence of 0.7 to 0.8 degrees is what is needed vs the
-> 1.0 spelled out in the manual. At 1.0 you'll be flying with a hint of up
-> elevator all the time. You can see same in all my float flying videos.
-> Elevator tip is always down slightly compared to the stab leading edge on
-> mine, that is mounted at 1.0 All the ones I've built since have 0.7 or 0.8
-> and they seem to fly with the tip pretty much flush in cruise.
-> Wayne
-> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> Sent: Sunday, December 05, 2010 12:01 PM
-> > If you do it in a similar situation that I show there Rob.. be sure to
-> > slap
-> > the level across the fus door sills for reference... so that the stabs are
-> > parallel to it! It may not be sitting level on wheels.
-> > ----- Original Message -----
-> > From: <schaumr@dcsol.com>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Sunday, December 05, 2010 11:48 AM
-> > Subject: Re: [rebel-builders] horizontal stab install
-> >> Thanks Wayne....those photos help.
-> >> Rob
-> >> On 12/5/2010 7:46 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> >> -> For that.. I make a stack of what ever junk I have lying around and
-> >> shim it
-> >> -> to get both of the stabs perfectly level with the smart level. In this
-> >> case
-> >> -> a ladder and milk crates, supplimented with some SM and some thin
-> >> shims.
-> >> -> http://www.irishfield.on.ca/gallery/stablevel.jpg
-> >> -> ----- Original Message -----
-> >> -> From: <schaumr@dcsol.com>
-> >> -> To: <rebel-builders@dcsol.com>
-> >> -> Sent: Sunday, December 05, 2010 11:37 AM
-> >> -> Subject: Re: [rebel-builders] horizontal stab install
-> >> -> > Thanks Wayne,
-> >> -> > So.....you don't use anything to keep the two stabs rigidly
-> >> 'connected' or
-> >> -> > horizontal throughout the procedure?
-> >> -> > Rob
-> >> -> > On 12/5/2010 7:30 AM, oifa@irishfield.on.ca wrote to rebel-
builders:
-> >> -> > -> I don't use a 2 x 4.. a 6 foot x 2 or 3inch wide strip of .025 or
-> >> .032.
-> >> -> > that
-> >> -> > -> way it will go under the fin! You end up with it a couple inches
-> >> back
-> >> -> > from
-> >> -> > -> the rear spar edge.. but tape it down parallel to the edge on
one
-> >> side
-> >> -> > and
-> >> -> > -> then play and adjust to get the other side the same before
-> >> setting
-> >> -> > those
-> >> -> > -> front attach brackets.
-> >> -> > -> http://www.irishfield.on.ca/gallery/stabset.jpg
-> >> -> > -> ----- Original Message -----
-> >> -> > -> From: <schaumr@dcsol.com>
-> >> -> > -> To: <rebel-builders@dcsol.com>
-> >> -> > -> Sent: Sunday, December 05, 2010 7:45 AM
-> >> -> > -> Subject: [rebel-builders] horizontal stab install
-> >> -> > -> > Good morning everyone,
-> >> -> > -> > I've been searching through the archives in vain for a
-> >> particular
-> >> -> > post
-> >> -> > -> > (probably
-> >> -> > -> > Wayne's) on the use of a 2x4 clamped to the rear spar of the
-> >> -> > -> > stabs as
-> >> -> > -> > you position the front attach brackets for drilling through the
-> >> -> > bulkhead
-> >> -> > -> > and
-> >> -> > -> > doubler. When I try to implement this method, I see no
-> >> alternative
-> >> -> > but
-> >> -> > to
-> >> -> > -> > to
-> >> -> > -> > notch the 2x4 to accommodate the vertical fin. Not difficult
-> >> to
-> >> do,
-> >> -> > -> > obviously,
-> >> -> > -> > but I just want to check with the group if there was a
-> >> -> > 'best-practice' for
-> >> -> > -> > this
-> >> -> > -> > step.
-> >> -> > -> > Thanks,
-> >> -> > -> > Rob
-> >> -> > -> > List archives located at: https://mail.dcsol.com/login
-> >> -> > -> > username "rebel" password "builder"
-> >> -> > -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >> -> > -> > List administrator: mike.davis@dcsol.com
-> >> -> > List archives located at: https://mail.dcsol.com/login
-> >> -> > username "rebel" password "builder"
-> >> -> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >> -> > List administrator: mike.davis@dcsol.com
-> >> List archives located at: https://mail.dcsol.com/login
-> >> username "rebel" password "builder"
-> >> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> >> List administrator: mike.davis@dcsol.com
