[rebel-builders] Fw: moose brake cylinders
Post by Ken » Sun Feb 19, 2012 11:06 pm
I believe all these things use standard industrial O-rings. Nothing special.
Mike Davis wrote:
To: <mike.davis@dcsol.com>
Sent: Wednesday, November 24, 2010 6:33 AM
Subject: moose brake cylinders
mike:
Bought my moose kit 2006. Can't reach factory by phone or email.
Replaced slave brake system with cylinders for each pedal and a remote
reservoir. Need to replace all seals in each cylinder. no info stamped
on cylinders
ie: part or model #. I heard they may have been making their own back
then and maybe getting parts from matco in USA?
Any ideas on info about seal kits- suppliers-model #'s of cylinders etc.
thx
evan fisk
winnipeg, Canada
evanfisk@shaw.ca
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 11:06 pm
The type of fluid that you will be using is the critical question that needs
to be addressed
Vegetable based, such as used in most automotive applications.
Mineral based, such as most general aviation planes use (5606 red in color)
Synthetic, as used in the big systems (Skydraul, higher combustion
temperature) on the bigger airplanes.
Not all seals will hold up to all of the many types of fluids.
Dick
On Behalf Of Ken
Sent: Thursday, November 25, 2010 3:39 AM
mike:
remote reservoir. Need to replace all seals in each cylinder. no info
stamped on cylinders
thx
evan fisk
winnipeg, Canada
evanfisk@shaw.ca
password "builder"
Yes there is a bit more to it but IMO it makes no sense to use anything
but a mineral oil based product like 5606, dexron tranny fluid, or
hydraulic fluid in a light airplane. That makes common buna-N o-rings
the first choice. Cost, availability, low temperature characteristics,
environmental resistance, toxicity, etc. The common MS orings are buna.
I would use nothing else but buna for my rebel brakes and hydraulics. I
would consider viton to be acceptable but more likely to leak at below
freezing temperatures.
to be addressed
Dick
On Behalf Of Ken
mike:
thx
evan fisk
winnipeg, Canada
evanfisk@shaw.ca
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:06 pm
Back to the brake cylinders, this is interesting
http://www.aircraftspruce.com/catalog/lgpages/mc-4.php
these are the cylinders that came with my kit, and it specifically says not to use DOT 3 or 4 as that will damage the buna-N seals....I thought I remember DOT 3 being recommended here on the list, but I could easily be mistaken.
Incidentally, they advertise replacement seals Evan, if these are the ones you have.
Subject: RE: [rebel-builders] Fw: moose brake cylinders/buna-N in the fuel system
Date: Sat, 27 Nov 2010 07:35:24 -0800
Hi Ken,
Since you have done the research, what about buna-N in the fuel system? Thinking about auto gas in the future, and I got a gascolator from Vans. I asked the tech guy if it was ok for auto gas and he said yes, and that the gasket was buna-N. I did a quick google search, but didn't find anything to confirm what he said. I guess alcohol would be bad for it, and probably the o-rings in the quick-drains too. I know my selector valve is ok..it's the Andair one. I should have spent the $$ and got the Andair gascolator as well.
Thanks.
Jesse
Date: Thu, 25 Nov 2010 20:54:36 -0500
Subject: Re: [rebel-builders] Fw: moose brake cylinders
to be addressed
Dick
On Behalf Of Ken
Post by Bob Patterson » Sun Feb 19, 2012 11:06 pm
Hi Jesse !
We've used ONLY Automatic Transmission Fluid (Deltron/Dextron ??)
in the Rebels, since about 1992, at least..... No problems !
We use it in the regular brakes, and also in the amphib floats for
brakes and retraction/extension.
Robin started using it because spills were a lot less aggressive
attacking the paint, it was kinder to the rubber seals & clear plastic
hoses, and there was no chance of getting the wrong kind when travelling ....
Suspect it might be less expensive too ... ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
mistaken. Incidentally, they advertise replacement seals Evan, if these
DOT3 is alcohol based. It will indeed destroy buna.
Don't know about DOT4 which I think is silicone??
http://www.aircraftspruce.com/catalog/lgpages/mc-4.php these are the
be mistaken. Incidentally, they advertise replacement seals Evan, if
Jesse Jenks
OK, thanks guys. Sounds like my memory was off. I guess it was the ATF that I remember being recommended, and it sounds like that is the obvious choice.
Date: Sat, 27 Nov 2010 15:56:27 -0500
Hi Jesse !
bobp@prosumers.ca
bobp@pattersys.com
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:06 pm
It is Jesse - Dextron III ATF... not a leak or rotted seal/o-ring in 15
years using it for brakes and all amphib components.
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Saturday, November 27, 2010 6:50 PM
choice.
Hi Jesse !
bobp@prosumers.ca
bobp@pattersys.com
persons.
not
be
I should add.. it always stays "clean". I find 5606 get gummy over time..
Sent: Saturday, November 27, 2010 6:53 PM
choice.
Hi Jesse !
bobp@prosumers.ca
bobp@pattersys.com
persons.
