[rebel-builders] prop spacer with nosebowl cowl?
Angus McKenzie
Post by Angus McKenzie » Sun Feb 19, 2012 11:06 pm
Yes
Subject: [rebel-builders] prop spacer with nosebowl cowl?
Date: Sat, 13 Nov 2010 07:31:18 -0800
Hi all,
I'm planning to build a 2 or 4 door cowl using the MC-3b nose bowl (Piper style with starter blister) from ACS. Can I get away without using a prop spacer?
Thanks.
Jesse
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:06 pm
Thanks Angus,
That's funny that you answered...I was just looking at a picture of your plane that I have saved on my desktop. It's bobbing on a lake somewhere with a bikini clad woman on the float...I think that's yours anyway. If not, hopefully your wife doesn't read your email.
Thanks again.
Jesse
Subject: RE: [rebel-builders] prop spacer with nosebowl cowl?
Date: Sat, 13 Nov 2010 15:54:55 +0000
Yes
Hi all,
Thanks.
Jesse
Angus McKenzie
We're safe Jesse, that's her (my wife) standing on the float.
Found a couple of good pics of our plane, and nose-bowl, on www.airliners.net search Murphy Rebel CFTUJ
Our nose-bowl is from a PA18, so's Ken's.
Best regards, Angus
Date: Sat, 13 Nov 2010 08:08:08 -0800
Thanks Angus,
Thanks again.
Jesse
Jesse Jenks
Good pics, thanks. How does your cowl work? It looks like the bottom half comes off as one piece.
Date: Sat, 13 Nov 2010 16:34:57 +0000
Best regards, Angus
Thanks Angus,
Thanks again.
Jesse
Angus McKenzie
Hi Jesse,
Yes, bottom cowl is one piece, .025, I'd use .032 next time. Top centre section bolts to the boot-cowl and nose-bowl, is about 10" wide with angle stiffeners and doublers. It hinges the two opening side doors. 4 full length piano hinges for the doors top and bottom and the lower full length stainless hinge pins pull out from the front to allow opening and access. Should/would have made those panels out of .032 as well.
PA18 nose bowl is modified for the landing light.
In the picture of my plane departing St.Thomas you can see the 4130 diagonal float-braces that I ran from the top rear engine mount stiffener I added, through the fire-wall and dash to the forward wing pick-ups. They make quite a difference on a torsional dimension.
If you need or want pics let me know...........Angus
Date: Sat, 13 Nov 2010 12:49:23 -0800
Jesse Jenks
Cool, that's the first one I've seen with a one piece bottom like that. .032 seems like it would be pretty hard to work with, and I don't have a roller either. Guess I might need to use one for the side panels...even with .025?
Date: Sun, 14 Nov 2010 02:28:03 +0000
Hi Jesse,
kpierson
Post by kpierson » Sun Feb 19, 2012 11:06 pm
Jesse: I have shaped .032" 2024 aluminum, which is stiffer then
6061, over various size auto tail pipes clamped in a vice with
the aid of a rubber mallet.
Keith P. Taildraggers forever.
On 11/13/2010 6:08 PM, jessejenks@hotmail.com wrote to rebel-builders:
-> Cool, that's the first one I've seen with a one piece bottom like that. .032
-> > From: angus.mckenzie@sympatico.ca
-> > To: rebel-builders@dcsol.com
-> > Subject: RE: [rebel-builders] prop spacer with nosebowl cowl?
-> > Date: Sun, 14 Nov 2010 02:28:03 +0000
-> > Hi Jesse,
-> > Yes, bottom cowl is one piece, .025, I'd use .032 next time. Top centre
-> > PA18 nose bowl is modified for the landing light.
-> > In the picture of my plane departing St.Thomas you can see the 4130
-> > If you need or want pics let me know...........Angus
-> > > From: jessejenks@hotmail.com
-> > > To: rebel-builders@dcsol.com
-> > > Subject: RE: [rebel-builders] prop spacer with nosebowl cowl?
-> > > Date: Sat, 13 Nov 2010 12:49:23 -0800
-> > > Good pics, thanks. How does your cowl work? It looks like the bottom
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:06 pm
Jesse build it with 4 easily opened doors and you will maintain that engine
like a top. Make the access any more difficult and the pre-flight,
"curiosity inspections", etc come to a halt. Amazing what gets neglected
behind the two piece speed cowling and it's numerous screws/camlocks or what
ever means you hold it on with, it's just not convenient (especially at a
dock!)
JMHO..
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Saturday, November 13, 2010 10:08 PM
with .025?
Hi Jesse,
Angus McKenzie
That's a really valid suggestion Wayne!
I guess I'm just so used to zipping out the 30/or/so plastic washered stainless no.8's that I don't even think about it anymore.
And it is a major pain at the dock (due to lack of ferrous content) usually involves a mask and snorkel..Angus
Subject: Re: [rebel-builders] prop spacer with nosebowl cowl?
Date: Sun, 14 Nov 2010 00:17:24 -0500
dock!)
JMHO..
Post by Ken » Sun Feb 19, 2012 11:06 pm
I just knew there had to be some reason why I was using cad plated steel
screws on my cowl - now I know ;)
dock!)
JMHO..
snowyrvr
Post by snowyrvr » Sun Feb 19, 2012 11:06 pm
Angus,
Did you fly to St thomas? If you did, where did you leave the US from?
Date: Sun, 14 Nov 2010 17:50:09 -0500
dock!)
JMHO..
Post by Drew Dalgleish » Sun Feb 19, 2012 11:06 pm
Angus is based in St. Thomas Ontario.
At 06:15 PM 14/11/2010 -0800, you wrote:
Angus,
engine
what
dock!)
JMHO..
snowyrvr
Oops! My bad! Are the two places similar? lol CW
Date: Sun, 14 Nov 2010 21:49:01 -0500
Angus,
engine
what
dock!)
JMHO..
Jesse Jenks
I think I am going to go with the 4 door. Do you actually open the lower doors very often though?
dock!)
JMHO..
with .025?
Hi Jesse,
Post by Bob Patterson » Sun Feb 19, 2012 11:06 pm
Hi Jesse !
i open my bottom doors every oil change ! i have a quick drain
valve on the oil tank, and a tube running from it to the rear,
fastened to the bottom of the fuselage aft of the firewall.
The tube means I don't have to carry or fool with a hose
for oil changes.
The 4 door cowl is THE best way to go ! Birds can build
nests while you have lunch - just pull the wire out, and
have a peek, and check the oil while you're there !!
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
engine like a top. Make the access any more difficult and the
pre-flight, "curiosity inspections", etc come to a halt. Amazing what
gets neglected behind the two piece speed cowling and it's numerous
screws/camlocks or what ever means you hold it on with, it's just not
convenient (especially at a dock!)
JMHO..
