Hi guys, I'm contemplating a prop and right now I'm thinking of going with a Catto. I looked on the archives and there is only a little information there. Curt Martin has a 3 blade Catto that he loves. I wanted to go with a 2 blade but not sure if I have enough ground clearance. Catto is suggesting a diameter between 78"-82" and pitch from 42-46 (I have a 160hp O-320). I don't quite have the engine hung yet to measure from prop flange to the ground. I'm on 8.50 tires with Wayne's spring gear so I think I should be OK with a 78" prop anyway. Can anyone provide some data points on both prop clearance with longer props and or Catto props on a Rebel?
Thanks much.
Jesse
Catto props
allen.hewko
Catto props
I recently installed a Catto prop and went with 78" to give me a little more
clearance when on skis. I started out with 45 pitch, and had to get repitched
to 47.5, which is just right, about 2750 rpm WOT level flight. I have a 150 Lyc
with a Pmag electronic ignition, which is giving me more power than Craig
had calculated originally. Craig was great to deal with, the product is
excellent, and I would recommend his prop. I believe he just came out with a
nickel leading edge as well.
Allen H.
R151
On 11/10/2010 7:31 AM, jessejenks@hotmail.com wrote to rebel-builders:
-> Hi guys, I'm contemplating a prop and right now I'm thinking of going with
-> Thanks much.
-> Jesse
Allen H.
R151
-> Thanks much.
-> Jesse
kpierson
Catto props
Allen: Although I'm over a year away from needing a prop, I am
planning to purchase a "Catto" prop. Would you please tell what
you paid for it so I can budget for it. And also how much it weighs?
Thank you. Keith P. Taildraggers forever
On 11/10/2010 7:15 PM, Allen Hewko wrote to jessejenks@hotmail.com:
-> I recently installed a Catto prop and went with 78" to give me a little more
-> clearance when on skis. I started out with 45 pitch, and had to get
repitched
-> to 47.5, which is just right, about 2750 rpm WOT level flight. I have a 150
Lyc
-> with a Pmag electronic ignition, which is giving me more power than Craig
-> had calculated originally. Craig was great to deal with, the product is
-> excellent, and I would recommend his prop. I believe he just came out
with a
-> nickel leading edge as well.
-> Allen H.
-> R151
-> On 11/10/2010 7:31 AM, jessejenks@hotmail.com wrote to rebel-builders:
-> -> Hi guys, I'm contemplating a prop and right now I'm thinking of going
with
-> a Catto. I looked on the archives and there is only a little information
there.
-> Curt Martin has a 3 blade Catto that he loves. I wanted to go with a 2
blade
-> but not sure if I have enough ground clearance. Catto is suggesting a
-> diameter between 78"-82" and pitch from 42-46 (I have a 160hp O-320). I
-> don't quite have the engine hung yet to measure from prop flange to the
-> ground. I'm on 8.50 tires with Wayne's spring gear so I think I should be
OK
-> with a 78" prop anyway. Can anyone provide some data points on both
prop
-> clearance with longer props and or Catto props on a Rebel?
-> -> Thanks much.
-> -> Jesse
repitched
Lyc
with a
-> Allen H.
-> R151
with
there.
blade
OK
prop
-> -> Thanks much.
-> -> Jesse
allen.hewko
Catto props
It cost $1800 and the weight was about 14 lbs.
I had also considered an Ivoprop electric in flight adjustable, but decided to
keep it simple and reliable.
Allen H.
On 11/10/2010 9:14 PM, kpierson wrote to Allen Hewko:
-> Allen: Although I'm over a year away from needing a prop, I am
-> planning to purchase a "Catto" prop. Would you please tell what
-> you paid for it so I can budget for it. And also how much it weighs?
-> Thank you. Keith P. Taildraggers forever
-> On 11/10/2010 7:15 PM, Allen Hewko wrote to jessejenks@hotmail.com:
-> -> I recently installed a Catto prop and went with 78" to give me a little
more
-> -> clearance when on skis. I started out with 45 pitch, and had to get
-> repitched
-> -> to 47.5, which is just right, about 2750 rpm WOT level flight. I have a
150
-> Lyc
-> -> with a Pmag electronic ignition, which is giving me more power than
Craig
-> -> had calculated originally. Craig was great to deal with, the product is
-> -> excellent, and I would recommend his prop. I believe he just came out
-> with a
-> -> nickel leading edge as well.
-> -> Allen H.
-> -> R151
-> -> On 11/10/2010 7:31 AM, jessejenks@hotmail.com wrote to rebel-
builders:
-> -> -> Hi guys, I'm contemplating a prop and right now I'm thinking of
going
-> with
-> -> a Catto. I looked on the archives and there is only a little information
-> there.
-> -> Curt Martin has a 3 blade Catto that he loves. I wanted to go with a 2
-> blade
-> -> but not sure if I have enough ground clearance. Catto is suggesting a
-> -> diameter between 78"-82" and pitch from 42-46 (I have a 160hp O-
320). I
-> -> don't quite have the engine hung yet to measure from prop flange to
-> -> ground. I'm on 8.50 tires with Wayne's spring gear so I think I should
be
-> OK
-> -> with a 78" prop anyway. Can anyone provide some data points on both
-> prop
-> -> clearance with longer props and or Catto props on a Rebel?
-> -> -> Thanks much.
-> -> -> Jesse
Allen H.
more
-> repitched
150
-> Lyc
Craig
-> with a
-> -> Allen H.
-> -> R151
builders:
going
-> with
-> there.
-> blade
320). I
be
-> OK
-> prop
-> -> -> Jesse
