[rebel-builders] Moose tailwheel
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 11:06 pm
I put an Alaskan Bushwheel ABI 3410-05 assembly on (10" wheel). Works
great!
http://www.akbushwheel.com/index.php?op ... le&id=60&I
temid=76
I found the AK Bushwheel people great to deal with; They answer all
questions promptly.
Dalgleish
Sent: Friday, October 22, 2010 6:00 PM
Subject: [rebel-builders] Moose tailwheel
At 04:55 PM 22/10/2010 -0400, you wrote:
Hello Gentlemen (Ladies?): I'm new in this list; I've built a Moose and
I've
flown 298 hours till today; It's a great aircraft, tricky to land and the
factory support stinks, like they never cared what happens after they sold
the aircraft kit, no response to e.mails and worse even, phone calls. The
tail wheel's mechanism is weak and I cannot get a decent response from
Chilliwack for a set of parts. I am thinking about adapting a Scott 3400
which I assume will be strong enough for the size of this aircraft. I fly
in
South America, mainly Bolivia, Argentina and Brazil. Any comments? Regards,
Eduardo
Hello Eduardo Welcome to the list. I hope you stick around and share your
expiriences building and flying in south America. I think the only day
you'll regret having a scott tailwheel is the day you have to pay for it.
They're pricy but worth it. Another choice might be a Matco wheel. I saw
some large heavy duty ones fron them at Oshkosh this year.
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:06 pm
Yep.. can't beat dealing with Wup and Bill !
Sent: Friday, October 22, 2010 10:26 PM
Subject: RE: [rebel-builders] Moose tailwheel
great!
temid=76
questions promptly.
Dalgleish
I've
in
Regards,
Eduardo
Eduardo Gutierrez Sosa
Post by Eduardo Gutierrez Sosa » Sun Feb 19, 2012 11:06 pm
Hi Drew: I ordered the Alaskan Bushwheel Tailwheel, the one with the 10"
wheel, p/n 06-01149 from Aircraft Spruce,
http://www.aircraftspruce.com/catalog/l ... lwheel.php My only
doubt is whether the one inch "head spacer" p/n 06-01158 is suitable to
install in the Murphy tail spring which is a solid 1" round steel stock
(works very well), considering the tailwheel head is made to hold a flat
spring steel. I'm sort of confused with this issue, and if anyone could give
me ideas who to look for advise, this would be great.
Bolivia, Brazil and Argentina have a wide array of landscape; there
Eduardo.. I would cancel your order with Spruce and buy it and the required
spacer DIRECTLY from Alaskan Bushwheel. The way you'll get proper customer
service if you have any issues with it, or have any questions when ordering.
There are no better people in the aircraft parts world than Bill and Wup at
ABW.
http://www.akbushwheel.com/index.php?op ... &Itemid=58
From: "Eduardo Gutierrez Sosa" <lopeco.eduardo@gmail.com>
Sent: Saturday, October 23, 2010 10:41 AM
[quote]Hi Drew: I ordered the Alaskan Bushwheel Tailwheel, the one with the 10"
give
Hi Wayne: That's exactly what I've done, but today is Saturday and they work
Monday through Friday only so I couldn't get them on the phone; I've sent
them and e.mail message with this problem. Thanks very much, regards,
Eduardo
-----Mensaje original-----
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de Wayne G.
O'Shea
Enviado el: s
Ted Waltman
Eduardo,
I also recommend that you order directly from AK Bushwheel.
A couple of key points that you need to know:
- If you have the solid Murphy stinger, it is 1 1/16" which is of course
1/16" larger diameter than the hollow, original Murphy stinger
- The 2-bolt attach pattern on both the original Murphy hollow round stinger
and the newer solid stock round stinger are spaced 1 3/16"
center-to-center. The bolt pattern on the AK Bushwheel (and Scott and every
other assembly by all other manufacturers) is spaced at 1 1/4"
center-to-center.
On Sat, Oct 23, 2010 at 8:49 AM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
ordering.
ABW.
only
give
Bolivia, Brazil and Argentina have a wide array of landscape; thereæ„€
plenty
of dense jungle, high mountains and extensive uninhabited areas, so your
aircraft must be prepared for hot humid, high elevation and short dirt
airstrips, must be able to carry lots of fuel and be absolutely reliable.
Thanks for your welcoming words, regards, Eduardo
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de Drew
Dalgleish
Enviado el: viernes, 22 de octubre de 2010 08:00 p.m.
Para: rebel-builders@dcsol.com
Asunto: [rebel-builders] Moose tailwheel
I've
sold
in
Regards,
Eduardo
Nancy Puff
Post by Nancy Puff » Sun Feb 19, 2012 11:06 pm
Happy Halloween everyone
Nancy
Sent: Saturday, October 23, 2010 8:15 AM
Subject: Re: [rebel-builders] Moose tailwheel
Eduardo,
stinger
every
center-to-center.
required
customer
ordering.
at
ABW.
10"
only
flat
give
Hi Ted: I've written an e.mail message directly to Wup. Alaskan Bushwheel is closed for the weekend but I'll catch him on Monday. Thanks for the support, regards, Eduardo
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de Ted Waltman
Enviado el: sábado, 23 de octubre de 2010 11:16 a.m.
Asunto: Re: [rebel-builders] Moose tailwheel
Eduardo,
center-to-center.
ordering.
ABW.
only
give
plenty
Dalgleish
I've
sold
in
Regards,
Eduardo
