I've seen Toluene at Ace Hardware and at a local specialty car paint supply
shop.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Roland
Kriening
Sent: Tuesday, September 14, 2010 2:38 PM
Subject: [rebel-builders] Toluene and Proseal Thinning
At one point someone mentioned thinning proseal (max 15%) with toluene.
Where is this product normally found? I have tried paint stores, hardware,
etc.
Roland
R56
Curtis Langholz
Roland,
I went on a tour of MAM when I got the new manuals for my Rebel. They showed me the thinning method using MEK for sealing the rivets on the inside of the tank. That is what I used and it made the proseal flow nicely over the rivets. I did not thin it for sealing the skins to the ribs.
Curtis
175R
Curtis
175R
Date: Tue, 14 Sep 2010 16:37:34 -0400
etc.
Roland
R56
Roland Kriening
MEK ? Remind me again what that is and where to get it.
R
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Curtis
Langholz
Sent: Tuesday, September 14, 2010 4:54 PM
To: REBEL BUILDERS
Subject: RE: [rebel-builders] Toluene and Proseal Thinning
Roland,
Curtis
175R
R
Langholz
To: REBEL BUILDERS
Roland,
Curtis
175R
etc.
Roland
R56
Dick Wampach
NO NOT MEK or lacquer thinner or paint thinners such as mineral spirits,
turpentine!!!
Toluene or some times marketed as Toluol, and Xylene, was the thinner of
choice for Zinc Chromate primer products. It is used in the tank sealants
such as PRC-1422- in the manufacturing process.
We...in the airline business used many quarts of the tank sealant. If it
was too thick to flow into places we needed it, it was thinned down. After
it has flowed down into the tight spots the thinners evaporate or are part
of the cure process. We often flew in under 12 hours with no leaks.
Can be found at most automotive paint suppliers, A/C Spruce, or home depot
in some areas
This is how I used some of my sealant on my Moose...of course no I have not
flown it...yet. Still building & trying to get it right
Dick Wampach SR-108 N331RW
Kriening
Sent: Tuesday, September 14, 2010 2:17 PM
R
Langholz
To: REBEL BUILDERS
Roland,
Curtis
175R
turpentine!!!
in some areas
Kriening
R
Langholz
To: REBEL BUILDERS
Roland,
Curtis
175R
toluene. Where is this product normally found? I have tried paint
stores, hardware, etc.
Roland
R56
