[rebel-builders] Fus 9 L
Post by Ken » Sun Feb 19, 2012 9:24 pm
119R came with a matched pair. Both the same size. I made new ones with
the top rear extending farther aft rather than adding the "float fix"
bulletin doublers that the bulletin says to do on all Rebels. I don't
know whether the originals had the 5 degree bend but you will need the
bend as I recall.
Roland Kriening wrote:
Could someone confirm that Fus 9L is different in shape than Fus 9R. These
are the triangular pieces forward of the doors. They both have the forward
bend (for the windshield I assume) but the Fus 9l is larger and has a 5
degree bend one inch from the door attach point. The fus 9r is completely
flat other than the forward bend. Logic seems to tell me that these parts
should be the same shape, just reversed ??? Plans make no mention of the
difference. I hope this is not yet another mismatched part from the early
kits.
Roland
R56
Cabin almost complete, just doing roof.
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 9:24 pm
Thanks Ken,
What thickness material did you use?
If you are around on Saturday, I would like to take some more pics of your
Rebel, to help me out during the build. You can reach me off line at
Kriening@rogers.com
Roland
R56
Sent: Thursday, June 24, 2010 5:31 PM
Subject: Re: [rebel-builders] Fus 9 L
bend as I recall.
kits.
Roland
R56
Same thickness 0.062"
It would seem to be the same bend radius as the main wing spar but it is
thick enough to a bit difficult to bend.
Thanks Ken,
Kriening@rogers.com
Roland
R56
bend as I recall.
kits.
Roland
R56
Curtis Langholz
Post by Curtis Langholz » Sun Feb 19, 2012 9:24 pm
Roland,
You are correct. Fus 5 are L & R, they should be mirror images of each other. I put mine on a couple of months ago on 175R and they were correct. They must have missed trimming and bending one of yours.
Curtis
Date: Thu, 24 Jun 2010 18:45:38 -0400
Thanks Ken,
Kriening@rogers.com
Roland
R56
bend as I recall.
kits.
Roland
R56
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
Roland Kriening
Hi Curtis,
So the correct shape would be a 90 degree bend on the forward end and a 5
degree bend (on the back ) where it attaches to the door post?
Roland
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Curtis
Langholz
Sent: Thursday, June 24, 2010 10:24 PM
To: REBEL BUILDERS
Subject: RE: [rebel-builders] Fus 9 L
Roland,
Curtis
Thanks Ken,
your
Kriening@rogers.com
Roland
R56
bend as I recall.
These
forward
completely
parts
early
kits.
Roland
R56
http://www.windowslive.com/campaign/the ... MTAGL:ON:W
L:en-US:WM_HMP:042010_1
Curtis Langholz
Roland,
Yes. Have fun....
Curtis
175R
Date: Fri, 25 Jun 2010 08:16:26 -0400
Hi Curtis,
Roland
Langholz
To: REBEL BUILDERS
Roland,
Curtis
Thanks Ken,
your
Kriening@rogers.com
Roland
R56
bend as I recall.
These
forward
completely
parts
early
