Complete with struts and fittings (but no steps) = 258 lbs with a c of g of
10.72" after of aircraft datum (wing leading edge)
My factory prebuilts.. 20 sides.. .040 step bottoms.. .032 rear bottoms and
all rigging = 267lbs ( I can't find all my notes.. may have lied by 11 lbs)
Mark Morin's Rebel.. weighed when I put the Lyco on it after removing the
Subasoris... 999 lbs with a Sensenich on the nose. Installed to amphibs last
spring... c/w my usual dual entry extruded steps both sides (10lbs)..
plastic lines, MAM pump and selector. 1239 lbs on amphibs. Dropped to 1221
with a Prince Prop... so increase of empty weight of 238lbs over
conventional gear. The gear coming off to go to amphibs is about 60 lbs for
main.. and 5lb for tailwheel... so that would put his amphibs, all attach
gear, pump, selector, steps, hydraulic fluid, etc at a total weight of
303lbs!
Sent: Monday, June 14, 2010 8:12 PM
Subject: [rebel-builders] amphib weight
Is anybody willing to post their true rebel weight on 1800 amphibs or
even better, their true weight increase when changing to 1800 amphibs?
Or has anybody weighed the assembled floats complete with all mounting
gear?
thanks
