You mean the factory can't help by supplying the part (or the diagrams)?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Reid
Huzzey
Sent: Monday, May 10, 2010 8:23 PM
To: rebel-builders-d@dcsol.com
Subject: [rebel-builders] SR/Moose Elevator Horn Bell Crank
Anyone have two spare elevator horn bell cranks FUS-304 and two bearings
MI-25. I am missing these parts from my kit. The figure in Chapter 9.2 step
45 shows the part but there are no dimensions. the part should be easy to
make if I knew the thickness of the aluminum and the distance between the
end holes. The bearing part should be able to be purchased.
If anyone can help with a part or a scale diagram posted to the archives or
dimensions, from a part not yet installed, it would be most appreciated.
Reid
Yukon 013Y
craig
Hi Reid,
I have two of the bearings, MI-25. Yours if you want them. Craig
To: <rebel-builders-d@dcsol.com>
Sent: Monday, May 10, 2010 6:22 PM
step 45 shows the part but there are no dimensions. the part should be
easy to make if I knew the thickness of the aluminum and the distance
between the end holes. The bearing part should be able to be purchased.
or dimensions, from a part not yet installed, it would be most
appreciated.
Reid
Yukon 013Y
