[rebel-builders] Rear wing attach
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 9:03 pm
Dave,
Rear attach is AN6 for the wing, all other bolts are AN10 (front wing attach
and strut attach points).
Jeff
On Sun, Feb 21, 2010 at 7:59 AM, David R. Greaton <dgreaton@maine.rr.com>wrote:
What is the final size of the rear wing attach bolt on the Moose?
Dave Greaton
Moose 189
Dale Fultz
[rebel-builders] Rear Wing Attach
Post by Dale Fultz » Sun Feb 19, 2012 9:15 pm
Dave the rear wing attach is to float in between the two attach brackets..
DO NOT TIGHTEN TOGETHER!Dale Fultz N260DF SR-033
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 9:15 pm
Directly cut-n-pasted from the manual, "CH 4 Fuselage rear spar attach
fittings", bottom of page 2 (note: this section is in the 3500 Mods):
8/ Drill out attach hole to 3/8" (AN6).
Please note the rear spar fittings are not bolted up tight when fitting the
wings. The wing fittings "float" inside the fuselage fittings.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
R. Greaton
Sent: Sunday, March 21, 2010 5:58 AM
To: rebel builbers list
Subject: [rebel-builders] Rear Wing Attach
Hi All,
This Question has been answered for me already, but I just want to make sure
I'm not doing something wrong. The rear wing attach has about a quarter inch
space where it slides into the fuselage brackets the wing bracket is resting
on the rear fuselage tab on both sides. Ted said that no spacers are used
in this area and I assume that he is correct, but it sure seems weird to
me. with no spacer I cannot tighten up the bolt without bending the tabs. Do
I use a castellated nut and snug up the bolt or what?
Sorry about second guessing but I just need a little reassurance I'm doing
the right thing.
Thank you so much,
Dave Greaton
Moose189 Maine
David R. Greaton
Post by David R. Greaton » Sun Feb 19, 2012 9:15 pm
Thanks Ted,
I guess I should stop over thinking this stuff. Did you use a nylok or
castellated nut.
Dave Greaton
Moose189 Maine
Sent: Sunday, March 21, 2010 11:36 AM
Subject: RE: [rebel-builders] Rear Wing Attach
David
R. Greaton
Hi All,
sure
inch
resting
Do
the right thing.
Thank you so much,
Dave Greaton
Moose189 Maine
Ted Waltman
I'm pretty sure it is a nyloc nut. I'd have to pull off the fairing and
look, but I think, again, it is a std nyloc nut. There's nothing
moving/rotating that is around the nut/bolt, so no need for a castellated
nut.
R. Greaton
Sent: Sunday, March 21, 2010 11:14 AM
Subject: Re: [rebel-builders] Rear Wing Attach
Thanks Ted,
castellated nut.
Dave Greaton
Moose189 Maine
David
R. Greaton
Hi All,
sure
inch
resting
Do
the right thing.
Thank you so much,
Dave Greaton
Moose189 Maine
Post by Mike Kimball » Sun Feb 19, 2012 9:15 pm
Just in case there are any old SR2500 builders still out there, the SR2500
does not have extra room between the tabs and the bolt should be tightened
right up, no float. The floating attachment is on the Moose. (I wonder why
the change?)
044SR
N744MK
Waltman
Sent: Monday, 22 March 2010 2:37 AM
R. Greaton
Hi All,
the right thing.
Thank you so much,
Dave Greaton
Moose189 Maine
