Fibre glass rudder tip 818R
mikeh
Post by mikeh » Sun Feb 19, 2012 8:50 pm
Hi all,
I'm just starting to get my first tip under way and find I can't make
it fit. In order to fit the leading edge rib at the front, and to
accommodate the taper of the rudder at the rear I need to trim off the
joining flange/s and would then have a butt joint between the two halves,
which I would reinforce with fibreglass tape.
Have I missed something? or would anyone care to comment? I've done
some searches and have found some negative remarks but not much detail.
Any input would be appreciated. Cheers Mike
