[rebel-builders] Re: Elevator tip weights
Posted: Sun Feb 19, 2012 8:36 pm
by Ken
Fred
Absolutely the weights go to the forward end of the tip in an effort to
improve the balance of the elevator on its hinges and reduce the
tendancy for the elevator to flutter like a tuning fork and destroy itself.
Fairly clear in fig 7.4.1 in the 1998 Rebel manual if you have that. I
don't recall any confusion in the older 1992 manual but I don't know
about anything newer or the figures you mention.
Fred Messinger (fredm) wrote:
Now that I the archives are back up, a search leads me to believe that the
weights do go towards the front of the tip? Which makes the diagrams in
the manual even more misleading.
On Sun, Oct 4, 2009 at 8:48 AM, Fred Messinger (fredm) <
fredmessinger@gmail.com> wrote:
Hi Guys,
I've had a debate in my head for a couple days.
I'm finishing up the elevator tips and to the point where I need to resolve
some ambiguity in the manual. Figures 3.6.2 and 3.6.3 show the tip weights
at the narrow end of the tip ribs - that is, at the elevator spar end of
the tip. Is this correct? Or do they go in the forward end of the tip
rib? The manual doesn't explicitly say, but it does hint that in the
diagrams...but then the diagram is incorrect in other ways, so I'm suspect.
I can see pros/cons for putting them at either end.
Second, less critical question...
It also says to to cut one of the weights in half and place the halves on
the outside rib of the tips. I'm assuming the weight get's cut along the
shorter dimension of the weight since a shorter piece of EL-412 is needed to
mount it. Is this correct?
Fred
by Fred Messinger (fredm)
Thanks, for the help Ken, and Jeff. Back on the trail now.
Fred
Man...where would I be without this forum!!
Time to send a little little something to Mr Davis!
On Sun, Oct 4, 2009 at 1:07 PM, Ken <klehman@albedo.net> wrote:
Fred
Hi Guys,
resolve
weights
suspect.
on
needed to
Fred
