Aileron/Flap Hinge Mount Fit?
David Ricker
Hi Folks
We are in the process of building the first wing of our Elite and have a question about
the fit of the Aileron/Flap Hinge Mount (W125), I am pretty sure this applies to all
Rebels and not just the Elite though.
Specifically the manual tells us to drill the hinge mounting points in the backing plates
out to #11, presumably to match the hinges. The problem comes in the match up to the
hinges, the centre distance of the existing holes in the rear spar is 3.940" while the
mounting holes in hinge are 3.968 a difference of .028", which is the correct spacing and
how have you resolved this? I see the options to be: a) file the spar centres out to the
correct spacing of the hinges since the holes are still "40, or b) bend the hinges to
meet the spar. I am concerned at making the wrong adjustment and having a poor fit of
the flap/ailerons.
Any suggestions? Has anyone else had this problem and how did you resolve it? Wayne,
you have probably built more Rebel wings as anyone here, any suggestions? (Murphy should
give you something for the time you spend helping builders but perhaps more about that
later...)
Dave R.
David A. Ricker P. Eng.
DARTEC Engineering Inc.
Fall River, Nova Scotia
Canada
the flap/ailerons.
later...)
Dave R.
Canada
Hi Dave !
I don't know the best solution, but I sure <wouldn't> recommend
trying to bend those aileron hangers ! They're pretty heavy extrusions,
and I'd really be afraid of stress cracks developing ....
-------------------------------orig.---------------------------------------
question aboutHi Folks
applies to allthe fit of the Aileron/Flap Hinge Mount (W125), I am pretty sure this
backing platesRebels and not just the Elite though.
up to theout to #11, presumably to match the hinges. The problem comes in the match
3.940" while thehinges, the centre distance of the existing holes in the rear spar is
correct spacing andmounting holes in hinge are 3.968 a difference of .028", which is the
centres out to thehow have you resolved this? I see the options to be: a) file the spar
hinges tocorrect spacing of the hinges since the holes are still "40, or b) bend the
poor fit ofmeet the spar. I am concerned at making the wrong adjustment and having a
it? Wayne,the flap/ailerons.
(Murphy shouldyou have probably built more Rebel wings as anyone here, any suggestions?
about thatgive you something for the time you spend helping builders but perhaps more
---------*later...)
Dave R.
Canada
Your following message has been delivered to the 162 members of
the list murphy-rebel@dcsol.com at 21:42:40 on 4 Nov 2000.
Dave, I know it's hard for us engineering types, but you need to set aside
your vernier and use it just to verify sheet thickness', when making parts
from unmarked sheets. I think to quote Darryl is "we are not building a
Swiss watch, but we are not building a bridge either!"
As for the hinges, I always drill the top hole and then bolt the hinge
bracket in place. Then I use the hinge bracket as a guide to drill the
bottom hole to #12. It is not a necessity if you don't have a full # bit
set, but you will find a #12 leaves no "slop" for a bolt compared to a #11
hole. I always use a #12 drill for bolts and a #11 for rivets.
Since you have not drilled your holes out yet, you have nothing to worry
about. Drill the top hole, bolt the bracket in place and, using the bracket
as a guide, drill the bottom hole the .028 lower than that predrilled #40
hole (that will be gone once you drill the #12 or #11 hole).
As for MAM "giving" me something for my time spent helping builders, Colleen
is pretty good to me when I need stuff for refurbs and rebuilds (and that
covers a <VERY> small portion of my time spent on this list server),
although what I would really like is a link from MAM's website to mine to
sell finished/flying Rebels, but Darryl can't be bothered to respond to my
requests or e-mails. Sometimes I wonder why I bother, but it is a GREAT
little aircraft and I just can't seem to turn my back on it!
Blue skies,
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Sent: Saturday, November 04, 2000 1:35 PM
Subject: Aileron/Flap Hinge Mount Fit?
Blue skies,
match up to theout to #11, presumably to match the hinges. The problem comes in the
the hinges tocorrect spacing of the hinges since the holes are still "40, or b) bend
more about thatgive you something for the time you spend helping builders but perhaps
*---------------------------------------------------------------------------later...)
Dave R.
Canada
*---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
David Ricker
Hi Wayne
Yeah, it is hard to not approach this like an Engineer since we are programmed to think
that way! That said, it does seem unusual that the spar and the hinge would be
fabricated on CNC (very precise) tooling and not come out with the same spacing.....I am
sure these things would save Murphy some time on the tech support line.
Your answer though is exactly what I was looking for, a method that has been proven to
work. I was concerned that if the hinge was biased one way or the other there would be
interference problems etc. I was also doing the Engineer thing and being cautious before
cutting metal! I'll try your suggestion for the #12 drill for the bolts also. By the
way, do you also do this where a reamed hole is called for, since it would be quicker?
Interesting your comment about Murphy responding to inquires, lately I have been
disappointed in the quantity and quality of response I have received to tech inquiries
via e-mail. I'll leave it at that but perhaps a gentle question or two from Bob P., our
"inside" connection would shed some light on this.......is that possible Bob? (Bob, if
you want to talk details, we can do it off - line.)
BTW, nice write-up in the latest COPA News, by the sound of it not only are you
cultivating a good flock of Rebels but the other amphib fliers have found a nice home
there too!
Thanks again,
Dave R.
Elite 583
Canada
there too!
Thanks again,
Dave R.
Elite 583
--Dave, I know it's hard for us engineering types, but you need to set aside
Blue skies,
We are in the process of building the first wing of our Elite and have aapplies to allthe fit of the Aileron/Flap Hinge Mount (W125), I am pretty sure thisbacking platesRebels and not just the Elite though.
Specifically the manual tells us to drill the hinge mounting points in thematch up to theout to #11, presumably to match the hinges. The problem comes in the3.940" while thehinges, the centre distance of the existing holes in the rear spar iscorrect spacing andmounting holes in hinge are 3.968 a difference of .028", which is thecentres out to thehow have you resolved this? I see the options to be: a) file the sparthe hinges tocorrect spacing of the hinges since the holes are still "40, or b) bendpoor fit ofmeet the spar. I am concerned at making the wrong adjustment and having ait? Wayne,the flap/ailerons.
Any suggestions? Has anyone else had this problem and how did you resolve(Murphy shouldyou have probably built more Rebel wings as anyone here, any suggestions?more about thatgive you something for the time you spend helping builders but perhaps*---------------------------------------------------------------------------later...)
Dave R.
Canada
--------**---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
Canada
David Ricker
Bob
The extrusions are made from an alloy which permits a certain amount of ductility
otherwise they wouldn't extrude well. If they were cast rather than extruded I would be
more concerned about them. The bending would also be much less than is done to the
spring gear legs (made from bar stock) if you want to use that as a point of reference.
Sorry about the Engineerese but I can't help that, we are just programmed that way!
Actually, I was expecting the solution would be along the lines that Wayne has suggested
but knowing whether to bias the position up or down was an important concern.
Dave R
Canada
Dave R
--Hi Dave !
At 02:35 PM 11/4/00 -0400, you wrote:question aboutHi Folks
Specifically the manual tells us to drill the hinge mounting points in theup to theout to #11, presumably to match the hinges. The problem comes in the match3.940" while thehinges, the centre distance of the existing holes in the rear spar iscorrect spacing andmounting holes in hinge are 3.968 a difference of .028", which is thecentres out to thehow have you resolved this? I see the options to be: a) file the sparhinges tocorrect spacing of the hinges since the holes are still "40, or b) bend thepoor fit ofmeet the spar. I am concerned at making the wrong adjustment and having ait? Wayne,the flap/ailerons.
Any suggestions? Has anyone else had this problem and how did you resolve(Murphy shouldyou have probably built more Rebel wings as anyone here, any suggestions?about thatgive you something for the time you spend helping builders but perhaps more---------*later...)
Dave R.
Canada
*-----------------------------------------------------------------------------------*The Murphy Rebel Builders List is for the discussion
Canada
Your following message has been delivered to the 161 members of
the list murphy-rebel@dcsol.com at 19:50:15 on 5 Nov 2000.
WHAT'S A REAMER??
Seriously, there really isn't anywhere on the Rebel/Elite to get too worried
about, or carried away, reaming holes. Mostly just a waste of time, if using
good drill bits. All those spar cap holes etc, just drill, debur, EP420 (or
what have you), coat the bolt shank, insert in hole, washer(s) and nut, then
tighten. The epoxy will fill the extra <minor> spaces and also keep the
moisture/corrosion out! The #12 hole may get a little tight on the 1/2" plus
distance on the spar cap strips so you may have to use a #11 drill, but #12
works really good on things like the stab attach brackets etc, that get
bolted in, to take any play out of the assembly. May not be too many of
these on the Elite's cantilever tail though, as compared to the Rebel's
"foldable" tail feathers.
Thanks for the comment about the Trumpeter Swan article. I found it read a
little choppy after Garth did his editorial "hacking", but I guess he had to
make it fit the page. I think the article was beneficial all around, for the
Swan program, for Homebuilders, free advertising for me AND Murphy Aircraft!
Also a good place for the story to be displayed to show the certified owners
some of the benefits to flying a high quality Homebuilt (if they bother to
read that section!). I don't know of any "Spam Can" that can do NINETY
degree bank turns to circle a swan, at a height that I probably could have
trolled for fish from, while the A/S indicator was pegged at ZERO (lets just
say that the picture of the swans <COULD> have been taken from the air,
<WITHOUT> a telephoto lens!). As long as the engine is making power in my
Rebel (and I presume most of the others), it will not stall or roll over on
it's back like a Cessna would!
Blue skies,
Sent: Sunday, November 05, 2000 3:01 PM
Subject: Re: Aileron/Flap Hinge Mount Fit?
WHAT'S A REAMER??
Blue skies,
programmed to thinkHi Wayne
would bethat way! That said, it does seem unusual that the spar and the hinge
spacing.....I amfabricated on CNC (very precise) tooling and not come out with the same
been proven tosure these things would save Murphy some time on the tech support line.
there would bework. I was concerned that if the hinge was biased one way or the other
cautious beforeinterference problems etc. I was also doing the Engineer thing and being
also. By thecutting metal! I'll try your suggestion for the #12 drill for the bolts
be quicker?way, do you also do this where a reamed hole is called for, since it would
have beenInteresting your comment about Murphy responding to inquires, lately I
tech inquiriesdisappointed in the quantity and quality of response I have received to
from Bob P., ourvia e-mail. I'll leave it at that but perhaps a gentle question or two
Bob? (Bob, if"inside" connection would shed some light on this.......is that possible
are youyou want to talk details, we can do it off - line.)
a nice homecultivating a good flock of Rebels but the other amphib fliers have found
asidethere too!
Thanks again,
Dave R.
Elite 583
partsyour vernier and use it just to verify sheet thickness', when making
#11from unmarked sheets. I think to quote Darryl is "we are not building a
brackethole. I always use a #12 drill for bolts and a #11 for rivets.
#40as a guide, drill the bottom hole the .028 lower than that predrilled
Colleenhole (that will be gone once you drill the #12 or #11 hole).
thatis pretty good to me when I need stuff for refurbs and rebuilds (and
tocovers a <VERY> small portion of my time spent on this list server),
mysell finished/flying Rebels, but Darryl can't be bothered to respond to
arequests or e-mails. Sometimes I wonder why I bother, but it is a GREAT
Blue skies,
Hi Folks
thequestion aboutapplies to allthe fit of the Aileron/Flap Hinge Mount (W125), I am pretty sure thisRebels and not just the Elite though.
bendbacking platesmatch up to theout to #11, presumably to match the hinges. The problem comes in the3.940" while thehinges, the centre distance of the existing holes in the rear spar iscorrect spacing andmounting holes in hinge are 3.968 a difference of .028", which is thecentres out to thehow have you resolved this? I see the options to be: a) file the sparcorrect spacing of the hinges since the holes are still "40, or b)
having athe hinges tomeet the spar. I am concerned at making the wrong adjustment and
resolvepoor fit ofthe flap/ailerons.
suggestions?it? Wayne,you have probably built more Rebel wings as anyone here, any
*---------------------------------------------------------------------------(Murphy shouldmore about thatgive you something for the time you spend helping builders but perhapslater...)
Dave R.
Canada
Canada
Dave,
I would have suggested the same solution - but Wayne has done
a lot more of them than I have, and I figured he'd give you the
definitive answer.
Sorry - I knew <you'd> appreciate the qualities of the alloy,
but often I 'tailor' my comments to catch everybody, and not just
for this particular problem, but as a general approach ...
The steel gear legs are heat-treated before and after bending,
though, so again, I was aiming to cover a 'standard practices' kind of
approach.
The flap & aileron fit has a lot of leeway regarding the top
skin, as it can be trimmed quite a bit for clearance if needed. It
can also be bent upward - I seem to recall the old manual suggesting
using a long 2 X 4 with a sawed slot in it to bend the skin upward
if needed......
------------------------------orig.----------------------------------------
definitive answer.
approach.
if needed......
ductilityBob
extruded I would beotherwise they wouldn't extrude well. If they were cast rather than
done to themore concerned about them. The bending would also be much less than is
of reference.spring gear legs (made from bar stock) if you want to use that as a point
that way!Sorry about the Engineerese but I can't help that, we are just programmed
has suggestedActually, I was expecting the solution would be along the lines that Wayne
*---------------------------------------------------------------------------but knowing whether to bias the position up or down was an important concern.
Dave R
Hi Dave !
Dave R.
Canada
Canada
Hi Dave !
One reason Tech. might be slow these days is that they're
short-handed ! I know Brian Godden (head of Tech.) was scheduled
to go over to the Philipines for a month (!) this fall, to supervise
training on the crews who will be building the QUick-Build Super
Rebels .... So, if he's away, they will be working pretty hard
to keep up, and perhaps missing the guiding hand ....
I'd be happy to help, though, if there's more of a problem -
just drop me a private email ...
I haven't seen My COPA yet - what was the article about, and
in which section ???
....bobp
-----------------------------------orig.-------------------------------------
....bobp
spacing.....I amthat way! That said, it does seem unusual that the spar and the hinge would be
beenInteresting your comment about Murphy responding to inquires, lately I have
a nice homeyou want to talk details, we can do it off - line.)
*---------------------------------------------------------------------------there too!
Thanks again,
Dave R.
Elite 583
Blue skies,
Dave R.
Canada
Canada
Dave Klimas
Wayne,
Did I miss something in this thread or even worse my wing?
Are there hinge mount bolts inside the tank area?
Dave Klimas
Ramona, CA
Dave Klimas
Ramona, CA
----snip----Dave,
Even after you do the drill/bolt the top and use the bottom as a guide
thing, you can still run into skin interference from kit to kit. Some do and
some don't, due to minor pre-punch variances to the trailing edge etc. I
wish I hadn't waited, about 8 wings, to realize that the thing to do was to
install one lug anchor nuts on the inside of the rear spar, so the hinge
brackets can be removed and shimmed as required (instead of bolted in place
and the wing closed up). They are especially helpfull for the ones inside
the tanks where you definitely wouldn't want to cut a hole to access the
nuts.
Even minor "tweaking" of the trailing edge really messes up the looks of a
wing, because as soon as you touch one spot it will "wow" somewhere else. I
know, because I have been <STUPID> enough to try it!
Blue skies,
Wayne G.O'Shea
the list murphy-rebel@dcsol.com at 21:56:37 on 6 Nov 2000.
Dave,
nuts.
Blue skies,
Wayne G.O'Shea
Sent: Monday, November 06, 2000 9:08 PM
Dave,
nuts.
Blue skies,
Wayne G.O'Shea
background ofBob
Fair to err on the side of caution, particularly when you don't know the
Wayne would havethe party you are giving advice to. I suspected someone, particularly
sure I didn'tbeen down that road before and come up with the right work around. For
that sounded awant to get into the "bend the trailing edge" routine if I could help it,
Elite rather thanbit too much outside the envelope for my taste!
BTW, the gear legs I was talking about were the aluminum parts on the
-the SR.
Dave R
------------------------------orig.---------------------------------------Dave,
definitive answer.
approach.
if needed......
pointAt 04:02 PM 11/5/00 -0400, you wrote:ductilityBob
The extrusions are made from an alloy which permits a certain amount ofextruded I would beotherwise they wouldn't extrude well. If they were cast rather thandone to themore concerned about them. The bending would also be much less than isspring gear legs (made from bar stock) if you want to use that as a
programmedof reference.Sorry about the Engineerese but I can't help that, we are just
Waynethat way!Actually, I was expecting the solution would be along the lines that
concern.has suggestedbut knowing whether to bias the position up or down was an important
recommendThanks
Dave R
extrusions,
have a
this
in the
the match
is
spar
bend the
having a
resolve
suggestions?
perhaps more
Canada
http://www.dcsol.com/murphy-rebel/lists/default.htm---------*
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
David Ricker
Bob
Fair to err on the side of caution, particularly when you don't know the background of
the party you are giving advice to. I suspected someone, particularly Wayne would have
been down that road before and come up with the right work around. For sure I didn't
want to get into the "bend the trailing edge" routine if I could help it, that sounded a
BTW, the gear legs I was talking about were the aluminum parts on the Elite rather than
the SR.
Dave R
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
the SR.
Dave R
--Dave,
definitive answer.
approach.
if needed......
The extrusions are made from an alloy which permits a certain amount ofextruded I would beotherwise they wouldn't extrude well. If they were cast rather thandone to themore concerned about them. The bending would also be much less than isof reference.spring gear legs (made from bar stock) if you want to use that as a pointthat way!Sorry about the Engineerese but I can't help that, we are just programmedhas suggestedActually, I was expecting the solution would be along the lines that Wayne*---------------------------------------------------------------------------but knowing whether to bias the position up or down was an important concern.
Dave R
Hi Dave !
At 02:35 PM 11/4/00 -0400, you wrote: question about applies to all backing plates up to the 3.940" while the correct spacing and centres out to the hinges to poor fit of it? Wayne, (Murphy should about that ---------* ---------*
Canada
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
the list murphy-rebel@dcsol.com at 08:07:28 on 7 Nov 2000.
SORRY DAVE, ONLY ON THE SR2500!
Sent: Tuesday, November 07, 2000 12:11 AM
andWayne,
Dave Klimas
Ramona, CA
Dave,
tosome don't, due to minor pre-punch variances to the trailing edge etc. I
placeinstall one lug anchor nuts on the inside of the rear spar, so the hinge
aand the wing closed up). They are especially helpfull for the ones inside
nuts.
Iwing, because as soon as you touch one spot it will "wow" somewhere else.
*-------------------------------------------------------------------------------snip----know, because I have been <STUPID> enough to try it!
Blue skies,
Wayne G.O'Shea
Hi Dave !
Bending the trailing edge of the top skin is a pretty common
thing - most Rebels have had some amount of it required. It's not
a big deal - the extended top skin is just a fairing, so think of
it as fitting a fairing, like the wing root fairings....
Re-quoting Darry "It's not a Swiss watch !" :-) :-)
background ofBob
would havethe party you are giving advice to. I suspected someone, particularly Wayne
concern.the SR.
Dave R
Dave,
definitive answer.
approach.
if needed......
The extrusions are made from an alloy which permits a certain amount ofextruded I would beotherwise they wouldn't extrude well. If they were cast rather thandone to themore concerned about them. The bending would also be much less than isof reference.spring gear legs (made from bar stock) if you want to use that as a pointthat way!Sorry about the Engineerese but I can't help that, we are just programmedhas suggestedActually, I was expecting the solution would be along the lines that Waynebut knowing whether to bias the position up or down was an important
-------------------------------orig.---------------------------------------Thanks
Dave R
in the
match
bend the
having a
resolve
perhaps more
Canada
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
AGT
One method of accomplishing a uniform bend that was suggested to me is to
rivet a long piece of angle aluminum to a long aluminum tube. Stick the
trailing edge of the wing skin in where the angle aluminum meets the tube
and roll the skin to the desired amount of bend. Get at least one other
person to help and you could do a long section. Maybe even the whole thing.
I'd use a good size tube, say 2 inch diameter or so. I'm concerned about
this because you won't believe what I did. I accidentally installed regular
rivets where flush rivets should be on the leading edge of the flaps.
Anybody know how to blind-side dimple? If so, I'd drill out the regular
rivets and put flush rivets there like it's supposed to be. Flush rivets
without dimpling might be worse. The sharp edge sticking up might want to
catch more than the curved edge of the regular rivet, even though the flush
rivet would sit lower.
SR2500
Sent: Tuesday, November 07, 2000 8:45 PM
Hi Dave !
SR2500
Hi Dave !
background ofBob
--the SR.
Dave R
Dave,
definitive answer.
approach.
if needed......
recommendThanks
Dave R
extrusions,
have a
in the
match
spar
bend the
having a
resolve
suggestions?
perhaps more
Canada
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
David Ricker
Yes, I remembered hearing about the shim hinge/bend trailing edge thing, that was the
start of my wanting to ask what others had done on the hinge positioning. I sure didn't
want to start bending the skin, it just sounded like asking for trouble. Once you start
warping sheet metal you can get into all sorts of fun!
Good idea on the hinge anchor nuts, I can just picture re-shimming the hinges a few years
down the road or trying to replace a worn pivot.
Dave R.
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
Dave R.
--Dave,
nuts.
Blue skies,
Wayne G.O'Shea
background ofBob
Fair to err on the side of caution, particularly when you don't know theWayne would havethe party you are giving advice to. I suspected someone, particularlysure I didn'tbeen down that road before and come up with the right work around. Forthat sounded awant to get into the "bend the trailing edge" routine if I could help it,Elite rather thanbit too much outside the envelope for my taste!
BTW, the gear legs I was talking about were the aluminum parts on the-the SR.
Dave R
definitive answer.
approach.
if needed......
pointAt 04:02 PM 11/5/00 -0400, you wrote: ductility extruded I would be done to theprogrammedof reference.Waynethat way!concern.has suggestedrecommendextrusions,---------------------------------orig.-------------------------------------have athisin thethe matchisthesparbend thehaving aresolvesuggestions?perhaps more*---------------------------------------------------------------------------*--------------------------------------------------------------------------*--------------------------------------------------------------------------*-----------------------------------------------------------------------------------**---------------------------------------------------------------------------*----------------------------------------------------------------------------------**-----------------------------------------------------------------------------------*---------*
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
3 Tamarac Drive
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
