tomorrow.. BUT the issue is they bottom on the 7/16 diameter of the lord
mounts hole JUST as they come out the other side...so aren't gonna help you
line up the case holes. I'd suggest getting the bottom bolts in and then
using a large "Gray" or similar taper punch. I tried one in the shop...think
it was a G30...and it would work perfect.
Sent: Tuesday, December 04, 2007 6:54 PM
Subject: Re: RE: [rebel-builders] Dynalfocal mount installation
Walter... I'll go see what I have in the hangar. Have a few trays of taper
pins.
Sent: Tuesday, December 04, 2007 6:36 PM
Well, I'm glad to hear that I am not the only one that had to resort to
extra means (like the tapered pins) to install these dynafocal mounts.
Now
I have to figure out how to evenly grind a bolt down to a tapered tip. I
don't want uneven edges to gouge the hole on the engine. Or is it
possible
to buy a tapered 7/16 pin, and just cut it down to the right length?
Date: Tuesday, December 4, 2007 3:07 pm
Subject: RE: [rebel-builders] Dynalfocal mount installation
Walter,
I helped my brother change the rubber bushings on his Grumman a couple
years ago. He had the tapered pins. We got good at
it by the 4th hole and
just a modest amount of cussin. I recall getting some of
the pins or bolts
in, bottom ones first I think, then lifting the engine so that
it tilted
back from the bottom mounts and pressed into the top
bushings. I winced a
bit when lifting brought the front wheel off the ground, but of
course that
was really not too big a deal. Just need to move
things around with a bit
of fine tuning on the amount of lift till the next hole lines
up. Probably
way easier with an assistant.
-Ben
Behalf Of Ronald get the mount clamp "skinny" by then used to hold inside the front side on the if you'd like situation, but it ordered on the trying to fit couldn't get the and use it to -- --
