[rebel-builders] Rebel Amphib Height
Post by Walter Klatt » Sun Feb 19, 2012 8:03 pm
These eye bolts, I assume they are not AN? I use one on each strut for
ropes. Are these the type you are referring to?
I should really try a higher float angle, especially now that I have the VGs
and with the stronger engine. The VGs take advantage of a higher angle of
attack on the wing, and the extra power overcomes the added drag on take-off
with the more lift. I can now again start my take-offs with full flaps on
the water, and get full advantage of the extra lift right from the start.
Even on land now, I can get some ridiculously short take-offs, if I am not
too heavy. Before the VGs, I would raise the nose at about 30 mph, and it
would run at that angle a bit before slowly rising into the air. Now, it
often hops right into the air, as soon as I raise the nose, even at that
speed. I need to get someone to video tape me, but am sure I am off some
times in 200 feet, or so it seems.
G. O'Shea
Sent: November 23, 2008 7:42 AM
Subject: Re: [rebel-builders] Rebel Amphib Height
Pretty cheap Walter... I've had to pay as much as $16 A PAD at times just to
get stock.
I dropped Howard's1 hole and had just enough TBuckle thread left to
retighten the cables. When the new owner wanted more throat angle.. I got
rid of the "tangs" at the top attach fitting and replaced the bolt with an
eye bolt.. then used it's eye to attach the TBuckle clevis pin...giving me
full turnbuckle thread usage again without making new cables.
Sent: Sunday, November 23, 2008 9:49 AM
Subject: RE: [rebel-builders] Rebel Amphib Height
Yes, I had purposely left holes on top and bottom. But I didn't want to
have
to redo cables, which is why I was waiting for a down time opportunity.
Maybe this winter, as I want to take the floats off some time for a
thorough
inspection and replacement of the hydraulic and brake lines.
I got my pads replaced, as you suggested, at the local shop on the field,
and they didn't gouge me too bad, I think, at 61 bucks incl tax for all
four. Brakes are good now.
G. O'Shea
Sent: November 22, 2008 8:32 PM
Can't help with the tail height vs angle,Walter, as my mounting struts are
shorter than MAM spec...and my spreaders a tad narrower as well to
maintain
the load angles of the struts.
Do you have any holes left on your rear strut fittings? One hole seems to
about 0.4 degrees or so...and if you have any turnbuckle thread left
lowering doesn't change the cable lengths too much.
Sent: Saturday, November 22, 2008 11:23 PM
Bruce's was at 3.5 degrees, which I thought was the largest angle anyone
was
using at the time. Mine is still at 2.5. It has been my intention for a
while now to move it to 3* next time I have the floats off, but still
haven't done it. The other locals here are still using 2.5, too, although
told them to try 3.
I also measured my tail height recently, and it is at 9 feet 3 inches.
Does
that sound like a 2.5* angle? With the 360, I am getting off the water
pretty fast now, but what the hey, if it can be even better, I'll try it.
still haven't tried it this year at a high elevation lake with a good
load.
That will be the real test.
Did a flight out to the lake today, actually. Just installed a new Icom
A210, and was testing it, and adjusting my VOX squelches.
G. O'Shea
Sent: November 22, 2008 7:51 PM
Quite possible Ken. I still drag my keels on some days while trying to
horse
it off the water in less than 9 or 10 seconds..which of course makes the
run
15 instead. With CYP Howard always said it was great at 2.3*... but then
when I sold it the new owner (with 30+ thousand hours) complained it
wouldn't leave the water without lifting a float as he couldn't rotate it
climb out. We made it exactly the same as mine @ 3.4/3.5 and it was like
night and day. It jumped off the water... unfortunately it jumped thru a
soya bean field in July as well to end CYP's life! Bob White's Elite, in
hangar, is on Clamar 2200's and I mounted it at 3.5*'s as well... and it
very quick off the water. He gets out just as short as I do with my
Rebel.
I think Bruce Georgen is mounted at 4 or 4.5* with his Rebel. Don't think
he
has the Angus cuff and he is happy with his performance as well.
I just can't see getting a Rebel or Elite off the water in any efficient
manner at only 1.7* throat angle.
Sent: Saturday, November 22, 2008 10:42 PM
Hmmm
So maybe 4.5 with the Mackenzie drooped leading edge then since it
lowers the wing angle of incidence about 1.5* ??
Wayne G. O'Shea wrote:
I used to fly a lot side by side with Bruce Georgian on trips. His were 3.5
compared to mine at 2.5. Our speeds were pretty well the same. So at 3, I am
not expecting any penalty.
I have the same concern, though, as I do a lot of flying now at 110 -120
mph. Also, I believe floats give you some lift, so you would put more stress
on your wings and tail, with less lift from the floats.
Dalgleish
Sent: November 23, 2008 7:51 AM
My floats are at 2.5 and if I rush my take off it will drag the heels
unless I lift one float out first. I've resisted increasing the angle
because I believed my cruise speed would suffer. Any idea how much the
extra drag slows you down?
horse
run
very quick off the water. He gets out just as short as I do with my Rebel.
he
Hmmm
Eric... have you tried getting your Elite to fly off the water yet @
only
1.7 degrees? Even at 2.3* hard to get them to part the surface as trying
rotate the "wing" to get airborne will have you dragging the rear keel.
3
3.5* seems to work best and I've adjusted more than a few and always end
up
at 3.3 to 3.5*'s
Sent: Saturday, November 22, 2008 7:35 PM
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:03 pm
I don't think you'll see any cruise difference Drew... you might even get a
surprise and see it go up.
Sent: Sunday, November 23, 2008 10:50 AM
horse
run
he
Hmmm
AN44-14A or -15A I believe was the length. 5/16 shank... 1/4" hole. I've got
pics somewhere... I'll fwd to you.
Sent: Sunday, November 23, 2008 11:16 AM
VGs
take-off
G. O'Shea
get stock.
have
thorough
G. O'Shea
are
maintain
was
although
told them to try 3.
Does
it.
load.
G. O'Shea
horse
run
it
Rebel.
think
he
Post by Drew Dalgleish » Sun Feb 19, 2012 8:03 pm
Going up would be nice. I'm not even close to Walter. More like 95-105 mph.
Does it make any difference raising the front or lowering the rear. I think
my front turnbuckles are almost bottomed out so maybe there's enough travel
to raise up the front without having to do anything with the wires.
That's what I was with my 320. The new engine gives me an extra 10 - 15 mph
cruise.
Dalgleish
Sent: November 23, 2008 9:22 AM
Ya...but don't forget Walter's cheating with 180HP !
Issue with the front fittings is when you raise/lower them a hole... it
changes the distance of fusleage attachment in relation to the floats due to
the strut being on an angle. I'm sure you can do it.. it will just tweek
your set up a bit. Rear one goes up and down no issue... but of couse this
also twists the front fitting attach area due to the angel change.. but
nothing that seems to stress/effect anything.
Sent: Sunday, November 23, 2008 12:21 PM
mph.
think
travel
I went to the camp 2 weeks ago @ 115 KNOTS !... of course I came back at
only 60 !
;O)
mph.
think
travel
It's actually more than 180, based on rpm comparisons on the same prop with
Dennis'. I get 100+ rpm more in climb than he does with the same prop (we
switched). His is a standard Lycoming.
Just the same, his heavier Elite with his 180 hp still performs better on
water than a Rebel with 150/160 hp. I wouldn't have believed it before he
had his flying. He also has the VGs. I have flown it, and it is a very nice
flyer, too, with landings, stalls, etc. Of course he did all the mods with
the tail and elevator to make it better, too.
Still keep pre-flighting my tail religiously, and no signs of any stress
there. I am keeping my speed down though, to be flying more like a Rebel on
wheels. I think climb is about the same too now, as a Rebel on wheels.
G. O'Shea
Sent: November 23, 2008 10:01 AM
mph.
think
travel
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 8:03 pm
I have a half dozen water flights since first flight a few weeks ago. I like
the performance. I have not flown full gross weight yet, but I can get off
the water (sea level) at 1900 lbs, light to calm wind (small water ripples),
at 55F in 10-12 seconds with 2 notches of flaps.
Power has been brought in smoothly and I'm just getting to full power before
liftoff. I haven't tried a high performance, more flap takeoff which should
be real short.
Rear of floats are not dragging. I've experimented with technique, but not
using full elevator on initial start, just aft of neutral, the floats pop up
on step, no real hump, planes and then liftoff. Nice.
My angle may work due to horsepower and constant speed prop. I'm running the
Superior XP-O-360 180HP with an MT constant speed prop. My cruise at 75%
power (2500rpm, 25" MP) is about 100kts IAS. My pitot system seems pretty
accurate at cruise.
Plenty more testing to do, so I'll post results when there is something more
conclusive.
Below is a YouTube video showing a landing and takeoff run. The takeoff is
near the end of the 3.5 minute video. It shows pretty well the float
attitude through the takeoff run.
http://www.youtube.com/watch?v=54olsv7kbyc
Elite 645E
G. O'Shea
Sent: Saturday, November 22, 2008 6:47 PM
Eric... have you tried getting your Elite to fly off the water yet @ only
1.7 degrees? Even at 2.3* hard to get them to part the surface as trying to
rotate the "wing" to get airborne will have you dragging the rear keel. 3 to
3.5* seems to work best and I've adjusted more than a few and always end up
at 3.3 to 3.5*'s
My Elite on Murphy 1800 amphibs is 10'-1" to top of the tail. The Comm
antenna on the cabin roof is nearly the same. The tail height can vary
depending on what angle you set your floats.
I set my floats at 1.7 degrees (top of float compared to bottom of main
cabin. Others are setting higher angles: 2, 2.5, 3 and 3+ degrees. The
greater the angle, the lower your tail (by quite a bit).
Elite 645E
snowyrvr@mtaonline.net
Sent: Monday, November 17, 2008 10:31 PM
Thanks, fellas; we're looking at a hanger with a 10' door so it sounds
pretty good. Craig
Original Message:
Date: Mon, 17 Nov 2008 21:06:22 +0000
My Elite on MFC 2200's is also just under 10' w/ the top of the rudder
being the tallest point.
Cheers, Bob 612e
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Nov 17, 2008 12:46 PM
My Rebel is 9"5" on the Amphibs. MAM 1800"s.
The Highest point is actually the Com antenna on the Cabin Roof. Tail is
about 9'4".
Curt Martin
N97MR
**************Get the Moviefone Toolbar. Showtimes, theaters, movie news &
more!(http://pr.atwola.com/promoclk/100000075 ... 7/aol?redi
r=htt
p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001)
Sent via BlackBerry by AT&T
mail2web.com - What can On Demand Business Solutions do for you?
http://link.mail2web.com/Business/SharePoint
Thanks Eric. Yes HP does allow for a lower throat angle for sure...but you
can go larger throat angle and use that HP even more to your advantage and
jump out of the water almost skipping the step run stage. If you find you
are going into shorter and shorter lakes give dropping the rear struts a
hole or two a try...you'll be surprised at the difference.
Sent: Sunday, November 23, 2008 3:15 PM
like
ripples),
before
should
be real short.
up
accurate at cruise.
more
conclusive.
Elite 645E
G. O'Shea
up
at 3.3 to 3.5*'s
Elite 645E
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
Looks pretty good, Eric. Your performance is very close to what Dennis gets
with his on take-off. I have timed his with a passenger and 3/4 fuel at the
lake, and it was less than 15 seconds.
One thing I noticed when flying the Elite on water, is that the nose does
not come up as high on initial power, even with full up elevator as with my
Rebel. With Dennis', it is more of a gradual transition onto the step and
then plane it to lift-off. I don't know if he doesn't have as much elevator
travel or it is just because of the bigger tail of the Elite.
With my Rebel, the nose really swings high on power up, and then with
forward elevator just hops straight onto the step, and lifts off right after
that. Best I could get with the 320, with a good headwind, was about 10
seconds. But with the 360, I think it is closer to 5, although haven't had a
chance to video it yet. Of course, I am talking solo with a light load. A
passenger and full fuel makes quite a difference.
But I do want to try the 3 degrees and see what it does.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Eric
Fogelin
Sent: November 23, 2008 12:16 PM
be real short.
accurate at cruise.
conclusive.
Elite 645E
G. O'Shea
at 3.3 to 3.5*'s
Elite 645E
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
Eric Fogelin
I understand your recommendation. Just to be contrary, I am going to try and
tighten the throat to see if it helps bump up my cruise speed to...200kts.
Just kidding.
I will try raising the rear strut up one or two holes and see what the
cruise speed increase is. I think it will be small to nil. But I'd like to
try.
I say I'm pleased with current water performance because almost all of my
100 hours of float flying has been in straight float Beavers at gross
weight. There have been occasions when I have pushed up against the 1 minute
full power limit before getting off the water. One minute is a long time to
coerce a plane off the water.
So, I'm amazed at how quick this Elite gets off the water as it nears gross
weight.
Great fun.
G. O'Shea
Sent: Sunday, November 23, 2008 12:28 PM
like
ripples),
before
should
be real short.
up
accurate at cruise.
more
conclusive.
Elite 645E
G. O'Shea
up
at 3.3 to 3.5*'s
Elite 645E
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
Eric Fogelin
I did generate a pretty high nose angle when I tried a stick back takeoff in
the Elite. But, it doesn't seem necessary. Since it gets up on step quickly
with a more neutral stick, I don't think I'll normally use the technique.
But, to simulate higher elevation takeoffs, I'll use lower power. Initial
full stick back may be necessary, with stick forward to get over the hump.
Sounds like I get to have a bunch of fun trying things out on the water.
First I need to deal with cooling issues with my speed cowl. Sound familiar?
I've got lots of archive email and photos printed out as I fix mine.
Elite 645E
Klatt
Sent: Sunday, November 23, 2008 1:20 PM
Fogelin
be real short.
accurate at cruise.
conclusive.
Elite 645E
G. O'Shea
at 3.3 to 3.5*'s
Elite 645E
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 8:03 pm
Yes, and that is what I had before with my old 320. No question, there are challenges with this one. The stock one from MAM might work for a wheeled Rebel or Elite, but not a chance on floats. On my first one I ended up changing first the exit, and then opening up the inlets a bit, too. With this one, I got away with just changing the bottom.
Date: Monday, November 24, 2008 11:16 am
Walter,
Are you using a "speed" cowl?
-Ben
Well, after all the cooling battles I had with my last cowl on
the 320, have
to say that I finally got it right the first time with this
360. It cools
beautifully, even better than the best that I finally saw with
the 320. And
I really put it to the test last summer in the interior (+35 C).
With the old engine (Lycoming), I had trouble cooling #3 and
4. Not this
one; all cylinders are even in cruise. On climb-out, it is
actually #1 and 2
that run a bit higher, but then cool right down with cruise.
What's interesting, though, is that on Dennis' (360 Lycoming),
his #3 runs
highest on climb-out (same as my old 320). Yet we have the
exact same model
carb on our 360s now. I wonder if this is a difference between
Superior and
Lycoming with the Superior sump intakes providing more even mixture
distribution.
Behalf Of Eric
Fogelin
Sent: November 23, 2008 9:12 PM
back takeoff in
step quickly
technique.>
power. Initial
over the hump.
the water.
Sound familiar?
Elite 645E
Behalf Of Walter
Klatt
what Dennis gets
3/4 fuel at the
the nose does
elevator as with my
the step and
much elevator
then with
off right after
about 10
haven't had a
light load. A
Behalf Of Eric
Fogelin
weeks ago. I like
can get off
water ripples),
full power before
which should
be real short.
technique, but not
floats pop up
I'm running the
cruise at 75%
seems pretty
accurate at cruise.
something more
conclusive.
The takeoff is
Elite 645E
Behalf Of Wayne
G. O'Shea
yet @ only
as trying to
rear keel. 3 to
always end up
at 3.3 to 3.5*'s
tail. The Comm
height can vary
bottom of main
degrees. The
Elite 645E
Behalf Of
it sounds
pretty good. Craig
Original Message:
the rudder
Cheers, Bob 612e
Roof. Tail is
about 9'4".
Curt Martin
N97MR
more!(http://pr.atwola.com/promoclk/100000075 ... 7/aol?redi> > r=htt
p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001)> >
