[rebel-builders] Jabiru engines
Post by Ken » Sun Feb 19, 2012 7:26 pm
Something is fishy. A regular 912 cruises well under 73 hp and so do I
with my subaru if I'm not in a hurry.
C&P Kucera wrote:
Hi Jean,
I spoke with the guys at Great Plains about a year ago. They said not to put
their VW engine into the Rebel, apparently it would have to work extra hard
to keep the Rebel flying, engine would not last. I was disappointed because
their engine looks great. It is 2275 cc, 110 hp take-off, 73 hp continuous,
with 2:1 redrive, can swing up to 84" prop, weight with nikasil cylinders,
redrive and all accessories is 175lb, cost of the kit is $US 6000, or they
will assemble.
paul
C&P Kucera
Post by C&P Kucera » Sun Feb 19, 2012 7:26 pm
I don't know Ken, they must think the Rebel is a heavy beast, typically they
put this engine in Avids and Zenair 701s.
paul
Sent: Saturday, March 08, 2008 10:58 PM
Subject: Re: [rebel-builders] Jabiru engines
C&P Kucera wrote:
Hi Jean,
put
hard
because
continuous,
cylinders,
they
will assemble.
paul
bransom
Post by bransom » Sun Feb 19, 2012 7:26 pm
I think this all started with Ron saying ' ...and I don't want to start
another Jab discussion' :). It's like politics or religion! Of course
the long standing concern about the Jab is simply that it's power comes at
too high an rpm for a bush plane (where presumably low speed thrust is more
important). Instead of working (don't tell) I just looked at the factory
performance curves:
Jab 3300 has about 206 ft-lbs torque at 2750rpm and 199 ft-lbs at 2300rpm.
Rotax 912ULS already peaked max torque at 4800rpm (1975rpm at the prop)
where it makes 231 ft-lbs torque
For comparison at 2300rpm, the Rotax is about 219ft-lbs at the prop.
Interestingly, both engines put out about the same HP (87-88hp) at 2300rpm.
Up at 2750rpm the Jab is making 107hp and for the right prop and airplane
(read sonex), it will go fast.
It's almost kinda silly to debate torque as the facts speak for themselves.
If one is not concerned about a super short ground roll or steep
climb-out, and hmmm, maybe just likes the sound of 6 cylinders at 2500rpm
as opposed to 4 cyl at 5300, and maybe wants a Rebel instead of a Sonex to
stay LSA, then maybe the Jab is a fine choice. My personal choice is to
still get all the low-end bush plane performance I can, as that is how I
want to use this plane. Btw, I don't get that notion from Great Plains.
Technically, that power should be great for a 750-800 lb empty wt rebel.
...and at $6k?! ...you could buy 3 before matching Rotax cost!
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 7:26 pm
OK, Ben, the incoming has drawn me out of my foxhole. :-)
The Jabiru 3300 static RPM should be ~2750, which is also the approx.
optimal continuous cruise RPM. Top speed WOT RPM should reach 3200-3300.
Other than being a random data point, I'm not sure what real world
relevance a 2300 RPM comparison has with the Jabiru.
Yes, I do like the Jabiru's sound a lot better (would _anyone_ ever
choose the Rotax for its sound?), and simpler engineering, and no prop
gears, and not having to pull the prop to check oil level, and not so
much plumbing, and no dual carbs to sync and maintain, and no viable
option for manual mixture carb for those who might prefer that, and....
The Rotax is a fine engine, if you don't mind such things, but strictly
as a matter of personal preference, I'd rather not deal with them.
FWIW, a shorter prop also means more ground clearance. I _know_ that's
not a trade off most people would chose, nor would I, with an otherwise
desirable design. I raise it as but a mere minor offsetting advantage to
the dire implications of shorter prop and higher tip speed.
To each his own.
performance curves:
Ron Shannon
Oops, too many negative clauses. For clarity, should have been:
"...and with the Jabiru, unlike the Rotax, having viable
options for manual mixture for those who might prefer that...."
bransom
On 3/10/2008 8:54 AM, rshannon@cruzcom.com wrote to rebel-builders:
Sorry about that. Gotta admit, you raise a lot of good points. BTW tho,
the 912S clutch protects the engine from a prop strike, so IMO the shorter
prop on the Jab is no advantage (besides cost of prop).
Oooh a tri-motor Rebel...
I love it.
snip
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 7:27 pm
No problem, Ben. As apparently the only Jabiru powered plane builder on the
list, it's hard to stay mum when others are touting only the advantages of
the Rotax, in a completely unbalanced way. As the thread began, I had hoped
to avoid regurgitating the archives on this... but some people don't get
around to reading those, so... the bell rings and we go. :-)
Surely max torque at "X" RPM is only one desirable spec in a Rebel/bush
plane. Others may have different opinions, but if I am 300 miles from the
nearest airport, I'd rather be servicing a simple air-cooled Jabiru, which
in my case will also have a very simple, manual mixture carb. (Yes, I'll
have to duck again, but... have you seen the exploded parts view of the
constant depression Bing? Do you really want to be overhauling that on a
rock at 8000 ft. with the sun going down?) Similarly, at high density
altitude, I would rather have the possibility of compensating with both an
adjustable prop _and_ manual mixture control, not just the former.
After all, the good thing about the constant depression Bing carb is you
don't have to adjust the mixture. _One_ of the bad things is -- you can't
adjust the mixture! When paying who knows how much for fuel, I would rather
be able to fine tune mixture instead of having to rely on what is likely to
be an unmanageable (automatic) compromise in pressure/prop load compensation
across a wide performance range with the Bing(s). Imagine a Bing and a
manual are both trying to take off at high density. They've both adjusted
their props. Now what else is the Bing driver going to be able to do? Or,
suppose the adjustable prop or alignment tools have broken and they're both
stuck with whatever prop pitch they rode in on.
The Jabiru may not have the published torque of the Rotax -- especially when
cherry picking points in the power curve. But last I heard, HP is still
relevant, particularly at the top end of the speed range. As a matter of
personal preference, in the boonies (or anywhere for that matter) I'd rather
sacrifice a little torque somewhere for what I see as some of these other
advantages.
IMHO, to claim that the Rotax is per se, absolutely, positively, in all
conditions and under all considerations, a better lightweight (LSA) engine
than the Jabiru is, well, narrow minded at best. What is best for some, may
be relatively undesirable for others.
The defense rests, but reserves rebuttal time. :-)
Post by Walter Klatt » Sun Feb 19, 2012 7:27 pm
Hey, Ron, looking forward to seeing you fly your Jab Rebel. Are you going to
be at Arlington again this year?
Theoretically, the Jab sounds good, light weight, smooth, and if you can
harness as many of those 120 ponies as possible on take-off, you could have
a great performer for your money (and simplicity as you mention). I think
your choice of propeller will be very important. What you have to watch is
that this engine is used in many faster airplanes. With those, they need a
prop with a lower static rpm so they don't over rev for top speed. Instead
you want a prop that gives the highest static rpm, and still reaches only 32
or 3300 rpm WOT straight and level at Rebel speeds.
That's what I found with my last 150 hp 0320 and the metal Sensenich. Many
with this engine only get 2400 or 2450 static. But this prop allowed 2500 on
take-off but would only hit 2720 flat out, so it was very well matched to
the plane and engine. And according to the 0320 power charts, it produced
140 hp at 2500 rpm full throttle, which means I didn't lose much given the
max of 150 at 2700.
I tried to choose a similar set-up with my new 180 hp engine, with a prop
size that should give me 2500 on take-off. And it's power charts are even
better, with 170 hp at 2500 with a max of 180 at 2700.
If you can get 108 hp at 2750, and find a prop that can efficiently transfer
that to thrust, you should at least be equal to the 912S on take-off and be
better at cruise. Do they use Warp props on the Jabs? At least they are
ground adjustable and you can play around with the static rpm.
Anyway, look forward to seeing you again this summer, if you can make it.
Shannon
Sent: March 10, 2008 1:22 PM
advantages.
Post by Ken » Sun Feb 19, 2012 7:27 pm
6 cylinder smoothness kind of suits Ron anyway don't you think?
No negative torque pulses between power strokes either eh Ron ;)
max of 150 at 2700.
Geez, Ken, you're starting to sound like Wayne now... Never thought of Ron
as a smooth stroker... And no negative torque pulses... Hmmm... What were
you guys up to there in Arlington, last summer... LOL
Sent: March 10, 2008 7:27 PM
have
32
on
max of 150 at 2700.
transfer
be
Ron Shannon
Thanks, Walter. I look forward to pow-wowing with you again too. I'll be
there one way or another. Whether it will be in 254R or not, hard to tell at
this point, but it's possible. Still hoping you'll visit WA59 sometime too.
Those are some good data points you've presented. I'm not aware of many
people using Warp props on Jabirus, though of course, out of the several
thousand engines now flying, there probably are some. Jabiru dealers have
found the Sensenich carbon fiber ground adjustable has worked well on
several airframes. It seems to be the hot ticket for ground adj. props on
Jabirus at the moment. As I've noted before, I'm starting with a fixed 68x38
fully realizing I may want to try something else eventually.
have
32
on
max of 150 at 2700.
transfer
be
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 7:31 pm
I'm going to take that as _some_ kind of compliment, even though
sincerity/sarcasm levels remain unknown. :-)
Not sure about that one, but I sense some of your always welcome and
consistently reliable erudition may yet be forthcoming on this topic. :-)
Ron
Post by Drew Dalgleish » Sun Feb 19, 2012 7:31 pm
Shorter props are cheaper but really the rebel gear is more than long
enough that prop strikes during normal operations are pretty much
impossible.
Post by Ken » Sun Feb 19, 2012 7:31 pm
Nothing intended but encouragement Ron.
Experimental aviation would be pretty boring if we all did the same
thing. In theory you have more power than a rotax so the challenge is
whether you can make it available on a Rebel. The Kitchener crew was
comparing a 4 cylinder Jab to the rotax rather than your 6 cylinder engine.
I actually prefer the 6 cylinder 0-300 to the more popular 4 cylinder
0-320. Smoother and cheaper to operate IMO.
As previously mentioned, a 4 cycle, 4 cylinder engine does not have
overlapping power pulses like a 6 cylinder engine. Between every power
stroke, the 4 cylinder engine slows down a bit which decelerates the
prop and flexes the engine mount rubbers in the opposite direction etc.
Much like a paint shaker... ;)
Ron
